Phorus PS10 Wireless Speaker with Alexa, DTS Play-Fi
Phorus PS10 DTS Play-Fi Amazon Alexa Wireless Speaker
The Phorus PS10 is the first DTS Play-Fi enabled wireless speaker with Amazon Alexa Voice Service. The $250 tabletop speaker targets would-be Amazon Echo buyers with audiophile ears thanks to its support for hi-res audio 24-bit/192kHz music streaming. With the inclusion of DTS Play-Fi technology, the PS10 can connect to more than 200 DTS Play-Fi-compatible products to form an Alexa-powered whole-home audio system, regardless of brand.
The Phorus PS10 is powered by a built-in 30-watt amplifier with DTS Sound post processing, two 65mm Neodymium full range transducers, and two four-inch bass radiators in a sealed enclosure. The PS10 supports playback of high-resolution audio files wirelessly via DTS Play-Fi technology and features four hard button music station presets, allowing for easy, one-touch access of a user’s favorite streaming music stations.
Multi-room music control on the Phorus PS10 is easy using the Phorus Apps for Android, iOS, and Kindle. When compatible DTS Play-Fi products, including the Phorus PS5 speaker and Phorus PR5 receiver, are grouped with the PS10, music simultaneously plays to the group with playback controlled by Alexa. Each member of a family can also use the Phorus app on their smartphone or tablet to listen to music in their own room or groups of rooms. Users can also control their system using their Apple Watch or Android Wear device.
The Phorus PS10 supports playback through Airplay, and Spotify Connect, includes a 3.5mm input for connecting any analog source, and a line-level audiophile grade output for connections to high-performance audio components. Using DTS Play-Fi, the 3.5mm input can be streamed wirelessly to DTS Play-Fi enabled products in other rooms of the home. The line out features variable volume output control and a Wolfson high-resolution DAC for improved sound quality. Additionally, the PS10 will support Amazon’s Connected Speaker API with a future firmware update. This will enable the PS10 to select and control the playback of music on all DTS Play-Fi enabled speakers throughout the home.
DTS Play-Fi technology enables lossless multi-room wireless audio streaming from the world’s most popular music services including Amazon Music, Deezer, iHeartRadio, Juke, KKBox, Napster, Qobuz, QQ Music, Pandora, SiriusXM, Spotify and Tidal, thousands of Internet radio stations, as well as personal music libraries, on any supported product. It should be noted voice controls only work with streams started or originating from Alexa Voice Services.
Price and Availability
Phorus PS10 with Amazon Alexa Voice Service is available now for $249.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
