Monitors
Philips 32-inch Monitor Feature Packed for $450
Philips BDM3270QP2 32-inch Monitor on desk
The new Philips Crystalclear BDM3270QP2 32-inch monitor features 2560×1440 resolution with DisplayPort, HDMI, and Dual link DVI connectivity for $450. The feature packed display includes MultiView technology, which enables active dual connect to view multiple devices like a PC and Notebook side-by-side simultaneously. You can also watch live sports from your set-top box or follow breaking news feeds on one side of the screen, all while browsing the Internet from your notebook or while working on your latest blog post on the other side of the display.
A Philips AMVA LED panel uses an advanced multi-domain vertical alignment technology to give you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web-browsing, films, gaming and demanding graphical applications. Its optimized pixel management technology gives you 178/178 degree extra wide viewing angle, resulting in crisp images even in 90-degree pivot mode. The 10-bit display delivers rich color depth with 1.074 billion colors and 12-bit internal processing for recreating smooth, natural colors without gradations and color banding.
The display comes with Philips Flicker-Free technology to regulate brightness, a SmartErgoBase for ergonomic adjustments, built-in stereo speakers, and a low bezel-to-table height for maximum reading comfort. Two USB 3.0 inputs deliver super speedy data transfers with a 5.0 gbit/s transfer rate and two USB 2.0 inputs are ideal for low speed peripherals. Finally, an integrated MHL port allows users to connect compatible phones and tablets directly to the monitor to mirror content to the widescreen display while charging the mobile device at the same time.
Philips BDM3270QP2 Monitor Side View
Price and Availability
The Philips Crystalclear Quad HD 2560 x 1440 32-inch display is now available for $449 at Amazon.com.
SPECIFICATION BDM3270QP2
LCD panel type AMVA LCD
Backlight type W-LED system
Panel Size 32 inch
Aspect ratio 16:9
Optimum resolution 2560 x 1440 @ 60Hz
Response time (typical) 4 ms (Grey to Grey)
Brightness (typical) 250 cd/m²
SmartContrast 50M:1
Contrast Ratio 3000:1
Viewing angle 178º (H)/178º (V)@ C/R > 10
Display colors 10-bit ColorColor support 1.07 billion colors
MHL 1080P @ 60 Hz
Signal Input VGA (Analog)
Display Port
MHL-HDMI (Digital, HDCP)
DVI-Dual Link (digital, HDCP)
Audio In/Out PC audio-in, headphone out
Built-in speakers 3W x 2
Power supply Built-in, 100-240VAC, 50-60Hz
Color Black
Finish Texture
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
