In-Wall Speakers
Perlisten Audio Announces World’s First In-Wall Speakers with THX Dominus Certification
Perlisten Audio is the first company to earn THX Dominus Certification for their new in-wall speakers.
Perlisten THX Dominus Certified In-Wall Speakers Lifestyle
We covered the launch of Perlisten Audio last summer and we’ve been waiting with bated breath for their actual availability in the United States and Canada. While certainly not inexpensive, the technology behind this very impressive new loudspeaker company merits some serious attention.
The Perlisten speaker brand has already made a positive impact on serious music listeners and home theater fans with its excellent standalone loudspeakers and subwoofers. However, Perlisten is venturing into new territory by adding a line of in-wall speakers, bringing new options to both home theater installers and enthusiasts.
In total there are 8 new in-wall speakers divided between the S-series (5 models) and R-series (3 models). Each line uses the same technology from their award-winning corresponding floorstanding models, the Perlisten S7t and R7t tower speakers. That should not only translate into exceptional sound but allow flexibility and true timbre matching if mixing and matching. The S-series models are larger and more expensive.
However, the big news about the new S and R series is that they are the first in-wall speakers that are THX Dominus Certified. Also, some Perlisten S and R series in-wall speakers are both Dominus and Ultra THX certified depending on the scenario.
  • THX Dominus Certification means that the speaker is optimized for rooms as large as 6,500 cubic feet, and up to a 20-foot viewing distance from the screen.
  • THX Ultra Certification means that the speaker is optimized for rooms to 3,000 cubic feet and a 12-foot viewing distance from the screen.
THX Certified Performance Classes
THX Certification Process
Core Features
Although there are some differences between each of the speakers in Perlisten’s in-wall line-up, core features include the following:
Shallow Cabinet: Each speaker has a shallow 4-inch self-enclosed aluminum cabinet with a bituminous damping layer with frameless magnetic grills.
Directivity Pattern Control (DPC) waveguide. This means that sound is centered by three “beamforming” tweeters and midranges to accurately control vertical and horizontal dispersion. The DPC array is the result of extensive simulation and prototype design. This has resulted in very accurate tweeter/waveguide technology implementation.
TPCD (Thin Ply Carbon Diaphram (Textreme). This technology is used (S-series only) to optimize a tweeter(s) so that frequencies extend more than an octave lower than with typical dome diaphragms. Small, lightweight construction limits unneeded beaming caused by larger tweeter diaphragms.
Timbre: Acoustic timbre matching across all speakers.
Perlisten S4i-LCRS THX Dominus Certified In-Wall Speaker
Perlisten S4i-LCRS
Additional Perlisten Terminology
LR: The speaker is designed and optimized for Left/Right channel placement.
LCRS: The speaker is designed and optimized for use as either a left, center, right, or surround channel speaker.
C: The speaker is designed and optimized for Center Channel placement.
HPF (Hybrid Pulp Formulation): This is a  mix of long fiber hardwood, bamboo, and wool. Its strength, mass, and damping ensure a detailed, full-range response without coloration.
Perlisten S7i-LR THX Dominus Certified In-Wall Speaker
Perlisten S7i-LR
Perlisten S-Series In-Wall Speakers
Note: Specifications Subject To Change
S-Series ModelS7i-LRS7i-CS5i-LRS5i-CS4i-LCRS
THX CertificationDominusDominusDominusDominusDominus (Surround)/ Ultra (LCR)
Enclosure Alignment4-way acoustic suspension4-way acoustic suspension3-way acoustic suspension3-way acoustic suspension3-way acoustic suspension
DCP-Array28mm Beryllium28mmTextreme TPCD28mm Beryllium28mmTextreme TPCD28mm Beryllium28mmTextreme TPCD28mm Beryllium28mm Textreme TPCD28mm Beryllium28mmTextreme TPCD
Woofers(4) 180mm Textreme TPCD(4) 180mm Textreme TPCD(2) 180mm Textreme TPCD(2) 180mm Textreme TPCD(2) 180mm Textreme TPCD
Sensitivity91.9dB92.0dB91.9dB91.6dB88.0dB
Impedance4 ohms4 ohms4 ohms4 ohms4 ohms
Frequency Response (+/-1.5dB)80 – 20kHz 80 – 20kHz 80 – 20kHz 80 – 20kHz 80 – 20kHz
Frequency Response(-10dB)45 – 37kHz47 – 37kHz52 – 37kHz50 – 37kHz42 – 37kHz
Typical In-Room Bass Extension37Hz39Hz46Hz42Hz38Hz
Recommended Amplifier Power (RMS)100 – 350W 100 – 600W 100 – 350W100 – 350W50 – 250W
SPL capability (100-20kHz)119.7dB peak119.8dB peak117.3dB peak117.0dB peak112.0dB peak
Dimensions (HWD)1036.6 x 298.6 x 111.2mm (40.8 x 11.8 x 4.4-inches)298.6 x 1036.6 x 111.2mm (11.8 x 40.8 x 4.4-inches)665 x 298 x 111mm (26.2 x 11.8 x 4.4-inches)298 x 665 x 111mm (11.8 x 26.2 x 4.4-inches)479 x 298 x 111mm (18.9 x 11.8 x 4.4-inches)
Mounting Dimensions (HWD)996 x 257 x 101.7mm (39.2 x 10.1 x 4.0-inches)257 x 996 x 101.7mm (10.1 x 39.2 x 4.0-inches)624 x 257 x 101.7mm(24.6 x 10.1 x 4.0-inches)257 x 624 x 101.7mm (10.1 x 24.6 x 4.0-inches)438 x 257 x 101.7mm (17.2 x 10.1 x 4.0-inches)
Weight26.4 kg (58.0 lbs.)26.4 kg (58.0 lbs.)15.9 kg (35.0 lbs.)15.9 kg (35.0 lbs.)11.2 kg (24.6 lbs.)
Available FinishesWhite grille, Black baffleWhite grille, Black baffleWhite grille, Black baffleWhite grille, Black baffleWhite grille, Black baffle
Perlisten R5i-C THX Dominus Certified In-Wall Center Speaker
Perlisten R5i-C
Perlisten R-Series In-Wall Speakers
R-Series ModelR5i-LRR5i-CR4i-LCRS
THX CertificationDominus (Surround), Ultra (LCR)Dominus (Surround), Ultra (LCR)Dominus (Surround), Ultra (LCR)
Enclosure Alignment3-way acoustic suspension3-way acoustic suspension3-way acoustic suspension
DCP-Array26mm Silk Dome26mm Silk Dome(3) 26mm Silk Dome
Woofers(2) 160mm HPF Diaphrams(2) 165mm HPF Diaphrams(2) 165mm HPF Diaphrams
Sensitivity89.4dB89.4dB88.8dB
Frequency Response (+/-1.5dB) 80Hz – 20kHz 80Hz – 20kHz 80Hz – 20kHz
Frequency Response (-10B)40Hz – 32kHz40Hz – 32kHz46Hz – 37kHz
Typical In-Room Bass Extension34Hz34Hz40Hz
Recommended Amplifier Power (RMS)100 – 350W 50 – 250W 50 – 200W
SPL capability (100-20kHz)113.4dB peak113.4dB peak111.8dB peak
Dimensions (HWD)298 x 665 x 111mm (11.8 x 26.2 x 4.4inches)298 x 665 x 111mm (11.8 x 26.2 x 4.4-inches)479 x 298 x 111mm (18.9 x 11.8 x 4.4-inches)
Mounting Dimensions (HWD)257 x 624 x 101.7mm (10.1 x 24.6 x 4.0-inches)257 x 624  x 101.7mm (10.1 x 24.6 x 4.0-inches)
Weight15.9 kg (35.0 lbs.)15.9 kg (35.0 lbs.)11.2 kg (24.6 lbs)
Perlisten S5i-C THX Dominus Certified In-Wall Center Speaker
Perlisten S5i-C
Availability and Pricing
Availability and pricing are available through Authorized Perlisten Audio dealers and installers
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
The Focal Utopia CINEMA LCR and Subwoofer are designed for luxury home theater set-ups in large spaces.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
Our favorite in-ceiling and in-wall speakers and subwoofers for distributed audio and home theater will be heard, but not seen.
Ask an Expert
A professional installer reveals everything you need to know about installing in-ceiling speakers for Dolby Atmos height effects or music.
From headphones to home theater, these high performance audio gifts will exceed the expectation of any movie or music lover on your list.
A/V Furniture & Accessories
Do expensive video cables really make a difference? The $45 THX HDMI Interconnects prove you don't have to spend a fortune to achieve all...
Cyber Monday 2024 deals you won't want to miss out on from SVS, RSL, THX, Technics, Creative, Denon, Samsung and more.
In-Wall Speakers
Enjoy low bass performance down to 30Hz from subwoofers hidden in your wall that are only 4-inches deep.
