Perlisten Audio R-Series THX Loudspeakers Debut at Florida Audio Expo 2022
Priced from $7,000 to $10,000 a pair, the Perlisten R5t and R7t loudspeakers are THX Dominus Certified with trickle down technology from the S-series.
Perlisten R Series Loudspeakers 2022
Perlisten Audio, a relative newcomer in the speaker space is starting off 2022 with the introduction of its R series speakers. The R Series loudspeakers will debut at the Florida Audio Expo, February 18-20, in Tampa, FL.
The flagship model of the series profiled in this article is the R7t. This speaker features a four-way bass reflex/acoustic suspension design that features some of the performance characteristics of its larger Perlisten Audio cousin, the S7t.
The R-Series & THX
The R-series speakers have also gone through the THX certification process, earning both THX Ultra and THX Dominus Certifications.
THX Certification Process
According to Dan Roemer, Perlisten Audio CEO: “Since we first appeared on the scene early last year, the S series – and the S7t in particular – has been continually lauded for its detail, range, and sense of realism, and the THX Certified Dominus achievement bridges the gap between home and commercial theater performance.  The R Series is a further expression of our commitment to creating the ultimate listening experience, with technologies and designs that are unique to Perlisten Audio products.
THX Certified Performance Classes
  • THX Ultra Certification means that the speaker is optimized for rooms to 3,000 cubic feet and a 12-foot viewing distance from the screen. The R7t is THX Certified Ultra when used as a left-center-right (LCR) channel speaker.
  • THX Dominus Certification means that the speaker is optimized for rooms as large as 6,500 cubic feet, and up to a 20-foot viewing distance from the screen. The R7t is THX Certified Dominus when used as a surround speaker.
DPC & HPF
One innovative feature incorporated into the R series speakers is the patent-pending Direct Pattern Control (DPC) waveguide. The waveguide uses three (3) 26mm domes, resulting in precise directivity control and timbre matching with all R-Series speakers. Three silk diaphragms are also used. This provides a smooth, effortless presentation of midrange and treble.
Four woofers are incorporated into the R7t and 2 in the R5t. Each one measures 165mm and is made from proprietary HPF (Hybrid Pulp Formulation) cone material. HPF is a  mix of long fiber hardwood, bamboo, and wool. Its strength, mass, and damping ensure a detailed, full-range response without coloration.
  • Tip: The woofers may be aligned as either bass reflex or acoustic suspension, depending upon the listener’s tastes or application.
For more details on the speaker technologies discussed above check out the Perlisten Audio Speaker Technology Page.
Perlisten R7t
Perlisten R7T Floorstanding Loudspeaker
Perlisten R7T
Here are the additional features and specifications provided for the Perlisten Audio R7t Speaker:
  • Enclosure alignment: 4-way bass-reflex/acoustic suspension
  • Driver compliment: The R7t incorporates a DPC (Direct Pattern Control) Array with (3) 26mm Silk dome tweeters and (4) Woofers with 165mm HPF diaphragms
  • Sensitivity: 90dB/2.83v/1.0m
  • Impedance: 4Ω nominal/3.1Ω min
  • Response Linearity: (+/-1.5dB) 80-20kHz
  • Frequency Response (-10dB): Bass reflex: 27-32kHz; Acoustic suspension: 38-32kHz
  • Typical in-room bass extension: Bass reflex — 19Hz, Acoustic suspension: 30Hz
  • Recommended Amplifier Power: 100-400W RMS
  • SPL (Sound Pressure Level) Output: (100-20kHz), 116dB peak <2%-2nd, 3rd Harmonics
  • Dimensions (HxWxD): 1268x230x350mm (49.9×9.0x13.7-inches)
  • Available finishes: High Gloss Black, Gloss White forthcoming.
  • Weight: 48 kg (105.6 lbs.)
  • Price: $4,995 each.
Perlisten R5t
Perlisten R5T Floorstanding Loudspeaker
Perlisten R5T
In addition to the R7t, Perlisten will be following up with another R-series model, the R5t. Here is a look at its features and specifications.
  • Enclosure alignment: 3-way bass reflex/acoustic suspension
  • Driver compliment: The R7t incorporates a DPC (Direct Pattern Control) Array with (3) 26mm Silk dome tweeters and (2) Woofers with 165mm HPF diaphragms.
  • Sensitivity: 89dB/2.83v/1.0m
  • Impedance: 4Ω nominal/3.2Ω min
  • Crossover Frequency: 1.25Hz, 4.4kHz
  • Frequency Response (+/-2dB): 80-20kHz Listening window
  • Frequency Response (-10dB):Bass reflex: 24-32kHz
  • Acoustic suspension: 38-32kHz
  • Typical in-room bass extension: Bass reflex: 21Hz, Acoustic suspension: 32Hz
  • Recommended Amplifier Power: 100-250W RMS
  • SPL (Sound Pressure Level) output capability (100-20kHz): 111dB peak <2%-2nd, 3rd Harmonics
  • Dimensions (HxWxD): 1100x230x350mm (43.3×9.0x13.7-inches).
  • Weight: 26.5 kg (58.3 lbs.)
  • Available finishes: Piano black, Gloss white, Cherry (gloss or matte), Mahogany (gloss or matte), Oak (gloss or matte), Ebony (gloss or matte)
  • Price: The reported tentative price of R5t tower is $3,495 each.
Price & Availability
The features and specifications of the remaining speakers in the Perlisten R-series speaker line will announcement upon product release. The R7t and R5t are available via Authorized Dealers/Distribution Partners
  • Perlisten R7t – $9,990/pair
  • Perlisten R5t – $6,990/pair
Check out our previous reports on Perlisten Audio speakers and subwoofers.
Perlisten Audio S Series of Speakers Now Available in the U.S.
Perlisten Audio Debuts 4 Audiophile Subwoofers
PerListen Audio THX Dominus Home Theater Speakers Launch in the USA
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
Priced from $600 to $2,200 per pair, KEF's most affordable loudspeaker range includes 8 models featuring 12th generation Uni-Q drivers.
Discover audio nirvana with some of the highest performing audiophile products in the world.
Reporting from Munich, we got the scoop on dozens of new high-end audio products coming out in 2024
Standing only 28-inches tall, the Q Acoustics M40 micro-towers soar over the wireless speaker competition priced under $1,000.
The top-of-the-line Atlantic Technology 8600i Series includes a new tower and center channel speaker for home theater or stereo listening.
