Compact Cameras
Pentax MX-1 Digital Camera Announced
PENTAX MX-1 Digital Camera
PENTAX just announced the MX-1, a retro designed, advanced digital compact camera with fast F1.8-2.5 lens and 1/1.7 inch, 12.0 effective megapixel backlit CMOS sensor for impressive low-light performance. Encased in brass covers with an ergonomically-pleasing, texturized grip, the MX-1’s body is a tactile experience. The brass panels are cool to the touch and its high-end composition feels substantial in the hand, enabling simple and intuitive handling. Thanks to its beautiful styling and premium materials, the MX-1 develops a stunning patina impressing a history on the camera with each use.
The camera captures images in a wide variety of settings and its fast lens makes creating beautiful focusing effects and bokeh achievable, enabling heightened creative expression and artistic personalization. The MX-1’s 4X zoom offers a versatile and highly-useable range, from a wide 28mm to telephoto 112mm (in 35mm format), its dual shake-reduction system enables sharp, blur-free images in even the most demanding circumstances.
PENTAX MX-1 Digital Camera - top
Whether it is the seasoned and well-practiced veteran who is brought back to the heart of his passion with the touch and feel of the cool brass panels, or the design-conscious novice who’s inspired by retro character and design, the MX-1 delivers on their hunger to produce beautiful photos through defining optics, electronics and design.
Major features of the MX-1 include:
Expanding photographic horizons with fast lens and versatile zoom
The PENTAX MX-1 features a 4X optical zoom lens offering a large maximum aperture of F1.8 to F2.5 and 28mm wide-angle coverage (in the 35mm format). When set at maximum aperture and widest angle of view the photographer can use fast shutter speeds in dimly lit locations and take advantage of a beautiful bokeh (out-of-focus) effect in the background. The MX-1 also provides a Macro mode to capture dramatic close-up images of subjects from as little as one centimeter away. Additionally, the Intelligent Zoom (digital zoom) function extends the zoom coverage up to approximately 7.8 times (for a focal length of approximately 218mm (in the 35mm format) without compromising image quality by optimizing the resolution to match the zoom length.
PENTAX MX-1 Digital Camera - left
Newly engineered backlit CMOS image sensor ensures super-high-resolution images in high-sensitivity shooting
The MX-1 incorporates a newly designed back-illuminated CMOS image sensor. With a top sensitivity of ISO 12800 and approximately 12.0 effective megapixels, it boasts remarkable high-sensitivity, low-noise capabilities and assures high-speed image data readout to deliver high-resolution images. The MX-1 also features a state-of-the-art imaging engine. Supported by the latest Super Resolution technology, this engine offers outstanding image-processing performance to produce clear, high-quality images with well-defined details. In addition, the MX-1’s unique Handheld Night snap mode helps the photographer capture blur-free night-time images by taking multiple images at one time, then synthesizing them into a single composite picture.
Classic and refined design
With its textured-rubber grip, and brass top and bottom covers that develop a distinctive appearance after years of use, the MX-1 offers a classic design reminiscent of traditional film cameras. It also features a number of metallic accents, including the lens ring, to further complete the tasteful, high-class finish down to the fine details.
PENTAX MX-1 Digital Camera - right
DSLR operability including in-body RAW data development and dedicated exposure compensation dial enhance the shooting experience
Thanks to a dedicated exposure compensation dial, the MX-1 assures user-friendly, direct-access shift of the exposure compensation setting without the need to recall the menu screen. It also features a mode dial for swift, effortless setting of 10 different shooting modes — ranging from the hands-off Auto Picture and the all-purpose Programmed AE, to the more creative Aperture-priority AE, Shutter-priority AE and Metered Manual. As the result, the photographer is assured of outstanding creative freedom to choose the most appropriate shooting mode for a particular scene or subject without delay. Additionally, the MX-1 comes equipped with a host of SLR-like features to optimize its operability, including advanced UI (user interface) functions, easy-to-access controls and in-body RAW data development.
Dual shake-reduction system produces sharp, blur-free images
The MX-1’s dual shake-reduction system couples the PENTAX-developed sensor-shift-type SR (Shake Reduction) mechanism with a digital SR mode to more effectively compensate for camera shake. This hybrid system guarantees the photographer sharp, blur-free images even under demanding shooting conditions prone to camera shake, such as when using a telephoto lens, shooting with incident light in poorly lit locations, or photographing sunset scenes.
PENTAX MX-1 Digital Camera - tilt LCD
Large, articulated LCD display simplifies capturing images at challenging angles
The MX-1 comes equipped with a large 3.0-inch, high-definition LCD display with approximately 921,000 dots. Its articulated design allows the photographer to adjust the display vertically and set it to the angle easiest for capturing and viewing. It also provides a clear view of images and menus displayed on the screen to assure quick, effortless review of recorded images and swift, error-free setting changes.
Full HD video captures high-quality movies with the push of a button
The MX-1 features Full HD movie recording functionality employing the H.264 recording format, to capture high-quality, extended movie clips (with 1920 x 1080 pixels, at a 16:9 aspect ratio, and at a frame rate of 30 frames per second). Switching to video mode is simple and intuitive; with the push of a dedicated button, the MX-1 instantly begins recording video from any shooting mode.  It also offers creative movie capture modes — including a High-speed Movie mode* for slow-motion playback and a Time-lapse Movie mode* for fast-forward playback — to make movie capturing and viewing more fun and exciting. A micro-HDMI terminal (Type D) is also included on the camera body for quick and efficient output of recorded movies and sound to external devices.
* In these modes, the recorded size is fixed at VGA dimensions (640 x 480 pixels).
PENTAX MX-1 Digital Camera - back
Other features
  • Dual-axial digital level for accurate horizontal and vertical alignment
  • Pop-up auto flash for perfectly exposed images and fill light
  • Remote control sensors on front and back panels
  • 15 digital filters, including Miniature and Toy Camera, to add creative touches to captured images
  • A choice of four aspect ratios (4:3, 16:9. 3:2, 1:1) to accommodate specific applications
  • SILKYPIX Developer Studio 3.0 LE for PENTAX RICOH IMAGING RAW data development software (designed by Ichikawa Soft Laboratory) included, in addition to in-body RAW data development
  • Compatibility with Eye-Fi wireless LAN SD memory cards
[youtube id=”xDPOHlvqyEw” width=”610″ height=”373″]
Pricing and Availability
The Pentax MX-1 advanced digital compact camera will be available February 2013 for $499.95 in black/black or black/silver (as pictured).
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
