DSLR Cameras
Pentax K-70 is Rugged, Affordable DSLR Camera
PENTAX K-70 DSLR camera in silver
Ricoh today announced the PENTAX K-70, a rugged DSLR camera with an advanced feature-set optimized for outdoor shooting, plus an incredibly compact, lightweight and weather-resistant 55-300mm zoom lens. The dustproof and weather-resistant camera incorporates features designed to work in a wide variety of challenging conditions, including low light and temperatures as low as 14°F (-10°C). The camera’s weather-resistant capabilities and compact design make it an ideal photographic companion for hikers, climbers and snow sports enthusiasts, as well as for nature and landscape photographers.
The K-70 shoots 24-megapixel photos along with a newly developed image accelerator unit providing a top sensitivity of ISO 102,400, plus the PENTAX-developed PRIME MII image processor, the PENTAX K-70 is capable of capturing high-quality images in extremely low-light conditions. A new Hybrid Autofocus (AF) system, integrating both image-plane phase-matching and contrast-detection autofocus technologies, delivers speedy and accurate autofocus while also providing continuous auto focus for HD video recording.
PENTAX K-70 Flip out LCD
The PENTAX K-70 provides a variety of advanced features found only in Ricoh’s high-grade PENTAX K-series models, such as the PENTAX Pixel Shift Resolution System, which produces high-resolution, finely detailed images. These also include an AA Filter Simulator that effectively eliminates moiré without the need for an anti-aliasing filter, a variable-tilt LCD monitor, and an in-body shake-reduction mechanism that reduces the effects of camera shake up to 4.5 shutter steps. The K-70 also incorporates built-in Wi-Fi for remote shooting and easy transfer to smart devices using Ricoh’s dedicated Image Sync app.
The PENTAX K-70’s exterior is designed with outdoor operations in mind. Features such as a newly designed grip, mode dial and control buttons on the camera’s top and back panels are designed to be easy and intuitive to operate, even with a gloved hand. It also comes equipped with an outdoor-friendly LCD monitor with an illumination control that can be instantly adjusted to the lighting level of any shooting location. The K-70 also has a red-lighted monitor display function which keeps ambient light from interfering with astrophotography.
PENTAX K-70 DSLR camera rear view
In conjunction with the PENTAX K-70 camera, Ricoh Imaging is announcing the HD PENTAX-DA 55-300mm f/4.5-6.3ED PLM WR RE lens, a compact, weather-resistant telephoto zoom; plus the Cable Switch CS-310, a remote shutter release designed especially for use with the K-70.
Pricing and Availability
The PENTAX K-70 camera will be available for $649.95 in black or silver finishes at the beginning of July, 2016.
Features
Super-high-resolution images captured with approximately 24.24 effective megapixels and a top sensitivity of ISO 102,400
The PENTAX K-70 features a state-of-the-art CMOS image sensor with approximately 24.24 effective megapixels to assure high-speed, 14-bit image data readout. Combined with an AA-filter-free optical design, this image sensor delivers super-high-resolution images. Also, by coupling a newly developed accelerator unit with the high-speed PRIME MII imaging engine, the PENTAX K-70 effectively minimizes noise at all sensitivity levels, and captures richly gradated, finely detailed images at high ISO.
Hybrid AF system for high-speed AF operation during Live View shooting
The PENTAX K-70 employs PENTAX’s first Hybrid AF system during Live View autofocus operation. By positioning a contrast-detection AF sensor with superior focusing accuracy and a phase-matching AF sensor on the image sensor’s surface, this innovative hybrid system optimizes the benefits of both AF systems to assure high-speed and accurate auto focus.
Dustproof, weather-resistant body perfect for rugged outdoor photography
The PENTAX K-70 combines a compact, body with dustproof, weather-resistant construction and outstanding cold-weather performance at temperatures down to 14° F (-10°C). It features a new contoured grip design and easy access to mode dial and control buttons. The LCD monitor features a brightness level that can be instantly adjusted to any environment, and also red-light mode which keeps ambient light from interfering with astronomical photography.
High-precision autofocus system with the SAFOX X module
The PENTAX K-70 features the high-precision SAFOX X AF sensor module, which assures responsive, dependable autofocus operation. With its 11 sensors, including nine cross-type sensors in the middle, this AF module assures pinpoint focus on the subject at a minimum brightness level as low as -3 EV. The PENTAX K-70 assures outstanding AF tracking performance with subjects on the move, thanks to such advanced features as the Select-area Expansion function, which automatically refocuses on a moving subject after it moves away from the initial point, with the help of the neighboring points; and an AF Hold function that maintains the initial in-focus point even when the module loses sight of the subject.
PENTAX-original shake-reduction (SR) system featuring the Pixel Shift Resolution System
(1) In-body SR mechanism
Using the built-in PENTAX-original SR (Shake Reduction) mechanism, the PENTAX K-70 effectively minimizes camera shake and delivers sharp, blur-free images, even in camera-shake-prone conditions.
(2) Pixel Shift Resolution System with motion correction function
Capturing four images of the same scene by shifting the image sensor by a single pixel for each image, the Pixel Shift Resolution System* then synthesizes them into a single composite image. This innovative system obtains all color data in each pixel to deliver super-high-resolution images with far more truthful colors and much finer details than those produced by conventional APS-C-size image sensors. A motion correction function**, which automatically detects a moving object during the synthesizing process, to accommodate a wider range of scenes and subjects.
(3) Innovative AA filter simulator to minimize moiré
By applying microscopic vibrations to the image sensor unit at the sub-pixel level during image exposure, the PENTAX K-70’s AA (anti-aliasing) filter simulator*** provides the same level of moiré reduction as an optical AA filter. Unlike an optical AA filter, this innovative simulator lets the user adjust the level of the moire correction.
(4) Supportive shooting functions
Since the PENTAX K-70’s SR unit has a flexible design that shifts the image sensor unit in all directions, it provides a host of handy shooting functions, including ASTRO TRACER, which simplifies advanced astronomical photography when combined with the optional O-GPS1 GPS Unit.
* When using this system, the user is advised to stabilize the camera firmly on a tripod. When a moving subject is captured in the camera’s image field, its image may not be reproduced clearly, either in part or as a whole.
** The movement may not be sufficiently corrected when the object is moving in a certain direction and/or pattern. This function does not guarantee that the movement is properly corrected with all subjects.
*** This function works most effectively with a shutter speed of 1/1000 second or slower. This function may not be combined with some shooting modes, including the Pixel Shift Resolution system.
Optical viewfinder with nearly 100-percent field of view
Within its compact body, the PENTAX K-70 incorporates a glass prism finder featuring the same optics and coatings as those used in higher-level models. A nearly 100-percent field of view and a magnification of approximately 0.95 times provides a wide, bright image field for easy focusing and framing.
High-speed shutter to capture fast-moving subjects in crisp focus
With a top shutter speed of 1/6000 second coupled with its high-speed continuous shooting function of up to six images per second, the K-70 is is perfect for capturing fast moving subjects at sporting events or wildlife.
Upgraded Full HD movie recording
The PENTAX K-70 captures high-resolution, Full HD movies with stereo sound using a built-in stereo microphone. In combination with compatible lenses, it allows the user to use the Continuous AF (AF-C) mode* to keep accurate focus on a moving subject, or take advantage of a new aperture control function** to automatically assure a proper exposure level even in fluctuating lighting conditions during movie recording. It also provides a host of distinctive visual effects for movie production, including the 4K Interval Movie mode that connects a series of 4K-resolution still images at a fixed interval to create a single movie file, and a Star Stream mode to fade in and out the traces of stars to recorded movies.
* During movie recording, the Continuous AF (AF-C) mode can be used in combination with the HD PENTAX-DA 55-300mm F4.5-6.3ED PLM WR RE or smc PENTAX-DA 18-135mm F3.5-5.6ED AL[IF] DC WR lens. Access the RICOH IMAGING official website for details.
** During movie recording, the aperture control function is available only in combination with the HD PENTAX-DA 55-300mm F4.5-6.3ED PLM WR RE lens.
Vari-angle LCD monitor for easy image viewing from all angles
The PENTAX K-70’s vari-angle LCD monitor allows for the positioning of the monitor at any desired angle, making it easier to compose the image in a wide variety of applications.
An array of functional customization options
The PENTAX K-70 provides three USER modes and two Fx (Function) buttons, to which the user can assign desired camera settings depending on their shooting preferences. Three settings (CLEAR TONE, HDR LANDSCAPE and ASTROPHOTO) are preprogrammed in the camera as default.
Wireless LAN connection to support smartphone operation
By installing the dedicated ImageSync application on a mobile device, the user can remotely check the Live View image, capture still images, adjust such camera settings as aperture, shutter speed and ISO sensitivity to the desired level through the mobile device, as well as download captured images onto the mobile device, then upload them on social networking service websites.
Other features
77-segment multi-pattern metering system for high-precision light metering
DR (Dust Removal) mechanism
Clarity control and Skin Tone correction functions —the latest image processing technologies developed by RICOH Central Laboratory
Timed exposure for capturing exposures up to 20 minutes in Bulb mode
A selection of imaging tools such as Custom Images, Digital Filters and Scene Modes
Optional Accessory: CS-310 Cable Switch
Attached to the PENTAX K-70’s microphone terminal, this one-meter-long cable switch helps prevent camera shake when using a macro or telephoto lens, allowing the user to release the camera’s shutter without touching the camera.
Note: The PENTAX K-70 does not accept cable switches other than the CS-310.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
