Peerless Mountfinder Delivers Interactive Screen-To-Mount Compatibility Tool
-Industry’s Most Comprehensive Compatibility Tool Provides 24/7 Access to Comprehensive Selection of Mounting Solutions —
CHICAGO, IL –May 6, 2008 — Peerless Industries, Inc., the industry leader in professional grade
audio/visual mounting solutions provides the easiest way to find the ideal mounting solutions with its screen-to-mount compatibility tool, MountFinder. Access this free resource at www.peerlessmounts.com.
Mount to Screen Compatibility With a Comprehensive Easy-To-Use Tool — MountFinder
Peerless’ MountFinder is an easy-to-use tool that will not only match the display to its compatible mount, it will also provide various mounting options that are available for flat panel displays making ideal mount selection easy. The MountFinder requires no downloads, simply navigate to www.peerlessmounts.com and locate the MountFinder. From there, enter in the model number –use the Auto Text or search via the dropdown menus for manufacturer and model. After that, a comprehensive selection of mounting possibilities is displayed.
For more information about Peerless’ professional-grade mounting solutions, visit www.peerlessmounts.com or call (800) 865-8010.
About Peerless Industries, Inc.
Peerless has designed and manufactured the most comprehensive line of audio/visual mounting
solutions for over 40 years. Today, Peerless designs and manufactures mounts for current and
emerging visual display technologies, including LCD and plasma flat panel displays, projectors, CRT
televisions and other electronic equipment used in the commercial and consumer markets. Built on
decades of experience and proven expertise, Peerless Industries is ISO 9001 certified and is an
approved Underwriters Laboratories testing site. For more information, visit
http://www.peerlessmounts.com.
©2008 Peerless Industries, Inc., All rights reserved.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
