Pass Labs X.8 Amplifiers
Nine New Class-A Amps Boast More Power, Fewer Stages, Lower Distortion and Less Feedback
Pass Laboratories just introduced the X.8 (or “Point 8“) Series Amplifiers, which deliver more power, fewer stages, lower distortion and less feedback than ever before. They more accurately represent recording venues through a soundstage whose dimensionality does not change no matter the complexity of the material. In addition, the layering of orchestral instruments by Point 8 Amps allows the orchestra to seem present in the listening room, but with more space and air around the instruments, leading to a greater sensation of musical ease and flow. The bass goes very deep, while the highs extend outward without sounding edgy.
The series consists of five Class-A amplifiers and four Class AB amplifiers, four two-channel and five monoblock models. The two-channel amps include the X150.8, the X250.8, the X350.8 and the XA30.8. The mono models include the X600.8, the XA60.8, the XA100.8, the XA160.8 and the XA200.8. Their per-channel power ratings range from 30 for the two-channel XA30.8 to 600 for the single-channel X600.8.
Pass Labs’ new amplifiers refine superb objective measurements with subjective perceptions. They represent a summation of the company’s knowledge of and expertise in designing amplifiers, while elegantly expressing its philosophy of more amplifier, more progress and more music.
They also demonstrate Pass Labs’ belief that the best products must be carefully adjusted until its various components operate in harmony then subjectively fine-tuned. As a result, Pass Labs subjected the Point.8 amplifiers’ state-of-the-art engineering to an extensive, rigorous listening process using six different sound systems to deliver peak musical experiences.
Inspired by Pass Labs’ X.5 Series amplifiers from 2006, the output stages of the larger Point.8 Series have been designed to bias more deeply into the Class-A operating region. They feature large push-pull Class-A operating envelopes for low distortion and good loudspeaker control at ordinary listening levels.
Head of the Class-A
Pass Labs successfully increased the amplifiers’ Class-A operation by employing higher power Toshiba MOSFETs (metal-oxide semiconductor field-effect transistors) than in its earlier amps. MOSFETs are typically used to convert voltage. Those in the Point.8 Series run at a fraction of their stated specs to enhance both performance and reliability.
Pass Labs also installed many more MOSFETs than usual on most Point.8 models. The X250.8 and XA100.8 amplifiers each use 56, while the X350.8, X600.8, XA160.8 and XA200.8 models each use 72.
Pass Labs also improved the amplifiers’ front ends, which house the input and voltage gain stages. Each of the nine Point.8 models has a front end uniquely molded to the specifics of its output stage so that the nine front ends vary in size, voltage, bias current, dissipation, and the distribution of single-ended vs. push-pull bias.
The improvements yield directly coupled (DC) front ends that boast very high stability, low distortion, low noise, 100-Khz open-loop bandwidths, and very high input impedances. Direct coupling in this manner maximizes the performance of each model’s output stage, while imparting to each model its own subtle and unique sonic signature. With the Point.8 Series, Pass Labs moves beyond cookie-cutter circuits.
Power to Spare
The power supplies are also larger than those of earlier amplifiers. The X150.8, X250.8, XA30.8, XA60.8, XA100.8, X350.8 and X600.8 models have a third more storage capacitance as well as new CRC (capacitor-resistor-capacitor) filtering to round out the edges of the supply ripple.
The power supplies still use paralleled fast/soft rectifiers and very large toroidal transformers from Plitron, but the AC primary circuits now incorporate additional RF filtering. Power on/off switching and a stand-by draw are also new.
The amplifiers’ front-end circuits boast massively larger power supply decoupling and low-noise shunt regulators that enable unprecedentedly more precise reference voltages for the cascode circuits. In addition, Pass Labs improved the amplifiers’ output noise by more than 10 dB, and made the amplifiers much more resistant to variations in the AC power line.
The smaller Point.8 models — the X150.8, the X250.8, the XA30.8, the XA60.8 and the XA100.8 — also feature new and larger heat sinks, an upgrade that lowers distortion and dissipates the energy of the larger bias currents.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
For $25K, TAD's Evolution Series 250-watt per channel stereo power amplifier promises even greater purity, responsiveness, and accuracy.
Using GaN technology, Starkrimson Mono Ultra Premium power amplifier boasts 250-watts of power at 8 ohms, 500-watts at 4 ohms.
The Marantz AV 10 Preamp/Processor and AMP 10 Power Amplifier are capable of delivering 15.4 channels of surround sound.
With 300-watts per channel RMS, Goldmund claims Telos 800 is one of the finest Stereo Power Amplifiers ever crafted.
With fully balanced and improved circuitry throughout, the BAT VK-85 Preamp and REX 300 Amp claim pure musicality from a $27,500 combo.
Leema Acoustics makes its case for stereo separates. The new Quantum series combo is £2,800 and made in the U.K.
Naim Audio makes a very subtle visual change to its 500 Series of high-end audio components as of October 2023.
Ask an Expert
Understand the basic audio components of a Hi-Fi stereo system so you know what to look for when shopping for audiophile equipment.
