Pass Labs Introduces SR1 Loudspeaker, Four-Way Floorstanding Listening System for Audiophiles
Uncompromising Speaker Emphasizes Performance, Accuracy, Power
Pass Laboratories, Inc., an audio innovator renowned for its unique high-performance products, introduces the SR1 Loudspeaker, a high-performance listening system using the highest quality drivers available.
The new SR1 is Pass Labs’ second loudspeaker, following and replacing the Rushmore, its exceptionally dynamic introductory speaker. The new SR1, a four-way floorstanding system, is equally uncompromising. Its highly refined sound stage, deep awareness of micro-detail, and effortless dynamics deliver superb, accurate musical reproduction.
The SR1 has been designed to harness the classic “mass controlled piston” model, in which the speaker’s radiating surface behaves as a rigid surface. This yields a well-defined characteristic in the spectral region where the sound is proportional to the electrical current through the voice coil. At the boundaries of this frequency band, the response falls off in a predictable manner.
The trick to making it work is to find a perfect piston driver. The cone surface must maintain its shape over the frequency band without breaking up into resonant vibrational modes. The suspension and motor system must remain linear with high excursion. Most speakers, however, allow the cone to flex in a way that gives some extension at higher frequencies at the cost of an irregular response in the frequency response and phase performance.
The SR1’s drivers are the best available, and employ Nextel-coated cones and a Crescendo tweeter from the renowned Seas of Norway. They present the best combination of low distortion, high dynamics, and predictable performance. It takes a minimum of four sizes of these drivers to span the SR1’s 10-octave audio range without significantly leaving the “piston” region.
The SR1 uses dual enclosures. A large bass enclosure with ten-inch and eight-inch drivers handles the bottom four octaves, and an adjustable smaller enclosure carries the midrange and the tweeter. The Seas of Norway drivers are complemented by a set of crossover and equalization electronics created to elicit the drivers’ best performance.
The SR1 is available as a bi-amplified or quad-amplified system, complete with active crossover filters. Upgrades and conversions between the systems are easily accomplished, and the speaker is compatible with a wide range of power amplifiers. The impedance does not dip below 4 ohms, and the sensitivity is approximately 90 dB for a 2.8V input.
The SR1 Loudspeaker will be available in February from authorized Pass Labs dealers at a suggested price of $25,000.
About Pass Labs
Founded in 1991 by legendary audio designer Nelson Pass, Pass Laboratories, Inc. markets its unique amplifiers, preamplifiers and speakers throughout the world. The company has been based in Foresthill, California, since its beginning, and is widely regarded as one of the most innovative audio brands in the world. Its critically acclaimed Aleph, X and XA-Series products have won numerous awards, and Founder Nelson Pass holds numerous audio patents. His achievements include developing the first dynamically biased Class A amplifier circuit, developing a fully cascode audio power amplifier, and developing the Stasis amplifier in 1977. He helped popularize solid-state, single-ended Class A power amplifiers, and developed the very successful Aleph series of products, and the Super-Symmetry™ circuit, which achieves exceptionally low distortion and noise levels. The company is now poised to introduce a new generation of amplifiers and other high-performance audio products.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Prestigious power, glorious grace, and terrific transparency.
Proof positive that not all watts are created equal. Especially those designed by Nelson Pass.
Nine New Class-A Amps Boast More Power, Fewer Stages, Lower Distortion and Less Feedback Pass Laboratories just introduced the X.8 (or “Point 8“) Series Amplifiers, which deliver more...
Company’s First Integrated Amp Features Low-Noise Super- Symmetry Circuitry, Plus Outstanding Audiophile Performance FORESTHILL, CA, Dec. 11, 2007 — Pass Laboratories, Inc., an audio...
Five New Class A Amps Deliver Unparalleled Power, Stability, Elegance, Range and Control Plus Acclaimed Low-Noise Super-Symmetry Circuitry CES ’08, LAS VEGAS Jan. 7,...
Exceptional Accuracy, Clarity and Refinements, Like an External Power Supply for the XP-20, Deliver Unmatched Quality and Sophistication FORESTHILL, CA, Oct. 24, 2008 —...
Exceptional Accuracy, Clarity and Refinements, Like External Power Supply for the XP-20, Deliver Unmatched Quality and Sophistication Pass Laboratories, Inc., an audio innovator renowned...
Four-Way Floorstanding Listening System for Audiophiles; Uncompromising Speaker Emphasizes Performance, Accuracy and Power Pass Laboratories, Inc., an audio innovator renowned for its unique high-performance...
