Pass Labs Introduces the INT-150 Integrated Amp, Boasting 150 No-Nonsense Watts/Channel
Company’s First Integrated Amp Features Low-Noise Super-
Symmetry Circuitry, Plus Outstanding Audiophile Performance
FORESTHILL, CA, Dec. 11, 2007 — Pass Laboratories, Inc., an audio innovator renowned for its unique high-performance products, will introduce the INT-150 Integrated Amplifier at the 2008 International Consumer Electronics Show, Jan. 7, in Las Vegas. The INT-150 expands the ranks of audiophile products to a broader spectrum of demanding consumers with a no-nonsense, user-friendly amplifier that delivers outstanding performance and a high level of user satisfaction.
The INT-150 is Pass Labs’ first integrated amplifier. Based on the company’s acclaimed X-150.5 Stereo Amplifier, the INT-150 embodies the design technology and refinements — including patented Super-Symmetry circuit — of the X150.5 and Pass Labs’ larger X.5-Series amplifiers.
In performance, the INT-150 boasts an excellent dynamic range and fast response. Rated at 150 watts-per-channel into 8 ohms, and 300 watts into 4 ohms, it moves easily from black background to explosive transients, then back again, adding realism and authenticity to recorded materials. It performs with authority and stability regardless of loudspeaker load. Smooth and transparent, the INT-150 provides clean, expansive sound at an affordable price.
The Super-Symmetry topology developed by Nelson Pass improves performance by precisely matching characteristics of the two halves of a balanced amplifier. To the extent that distortion and noise can be made to appear identical at the two output connections, they will not be detected at the balanced output. In conventional amplifiers, ordinary matching techniques can achieve improvements by a factor of about 10 under ideal conditions. In the INT-150, Super-Symmetry lowers distortion and noise by an additional order of magnitude.
Input, output and AC connectors are on the rear of the amplifier. The main power switch is also on the rear, but a convenient standby switch is available on the front panel. The INT-150 accepts four single-ended inputs via RCA connectors, and two balanced XLR inputs. The speaker outputs are equipped with heavy-duty, international safety-rated, five-way binding posts.
In appearance, the INT-150 resembles the X150.5, without the meter. The faceplate is machined from thick aluminum stock, then anodized instrument-gray. The satisfyingly solid remote is also made from machined aluminum, and visually matches the front of the amplifier.
The INT-150 Integrated Amplifier is available now from authorized dealers at a suggested price of $6,500. It can be seen with Pass Labs’ other outstanding products in Suite 140, Venetian Tower 29, during the show.
About Pass Labs
Founded in 1991 by legendary audio designer Nelson Pass, Pass Laboratories, Inc. markets its unique amplifiers, preamplifiers and speakers throughout the world. The company has been based in Foresthill, California, since its beginning, and is widely regarded as one of the most innovative audio brands in the world. Its critically acclaimed Aleph, X and XA-Series products have won numerous awards, and Founder and CEO Nelson Pass holds numerous audio patents. His achievements include developing the first dynamically biased Class A amplifier circuit, developing a fully cascode audio power amplifier, and developing the Stasis amplifier in 1977. He helped popularize solid-state, single-ended Class A power amplifiers, and developed the very successful Aleph series of products, and the Super-Symmetry circuit, which achieves exceptionally low distortion and noise levels. The company is now poised to introduce a new generation of amplifiers and other high-performance audio products.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Prestigious power, glorious grace, and terrific transparency.
Proof positive that not all watts are created equal. Especially those designed by Nelson Pass.
Nine New Class-A Amps Boast More Power, Fewer Stages, Lower Distortion and Less Feedback Pass Laboratories just introduced the X.8 (or “Point 8“) Series Amplifiers, which deliver more...
Five New Class A Amps Deliver Unparalleled Power, Stability, Elegance, Range and Control Plus Acclaimed Low-Noise Super-Symmetry Circuitry CES ’08, LAS VEGAS Jan. 7,...
Uncompromising Speaker Emphasizes Performance, Accuracy, Power Pass Laboratories, Inc., an audio innovator renowned for its unique high-performance products, introduces the SR1 Loudspeaker, a high-performance...
Exceptional Accuracy, Clarity and Refinements, Like an External Power Supply for the XP-20, Deliver Unmatched Quality and Sophistication FORESTHILL, CA, Oct. 24, 2008 —...
Exceptional Accuracy, Clarity and Refinements, Like External Power Supply for the XP-20, Deliver Unmatched Quality and Sophistication Pass Laboratories, Inc., an audio innovator renowned...
Four-Way Floorstanding Listening System for Audiophiles; Uncompromising Speaker Emphasizes Performance, Accuracy and Power Pass Laboratories, Inc., an audio innovator renowned for its unique high-performance...
