Parasound Zpre3 Stereo Preamplifier Announced
Parasound just introduced the Zpre3, its third generation stereo preamplifier for custom installation, in its Z-Custom half-rack-width product line. It succeeds the Zpre2 from 11 years ago.
The compact Parasound Zpre3 is a five-source stereo preamplifier designed to deliver full-size audiophile sound. It will be useful to professional custom installers, with a unique feature set that includes discrete IR remote commands, a rear panel IR input, 12V trigger output and two-way RS-232 with direct volume control in 1dB increments. Automatic RS-232 feedback allows for easy integration with keypads or touch-screen control systems such as Crestron, AMX, Control4, Savant, and Elan.
Parasound Zpre3 - front
Additional features include turn-on volume level select plus the choice of a favorite volume memory, making it easy for the user to jump directly to his/her most common listening level. A separate bypass input integrates with audio sources that have their own volume controls, such as AV receivers and streaming devices like the Sonos Connect. The bypass input is automatically selected when the Zpre3 is powered off, allowing users to operate their streaming devices without the need to turn the Zpre3 on first.
Parasound Zpre3 - back
The Parasound Zpre3 has four line level audio inputs, a bypass input and a 3.5mm front panel auxiliary input. It offers separate fixed and variable level stereo outputs, plus separate fixed and variable mono outputs for subwoofers and architectural speakers. Each of the inputs on the front panel display can be conveniently renamed from a list of words the user can select rather than having to enter one character at a time. A single knob adjusts volume, selects sources, and adjusts bass, treble and balance. The remote control has buttons for the above selections plus recall of a favorite volume memory and dimming the front panel display.
Parasound President Richard Schram states “We challenged ourselves in developing a line stage preamp with unique user interface features to make it an exceptionally useful tool for custom installers while endowing it with sound quality that will delight audio enthusiasts.”
Price and Availability
The Parasound Z-Custom Zpre3 will be available in September 2016 for MSRP $449.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
As of December 8, 2022, Parasound is in new hands. Find out the reason why and what the future may hold.
Does the $3,200 Parasound HINT 6 deliver on its promise of excellent sound quality, reliability, and features galore? We take it for a spin.
SAN FRANCISCO (3/1/05) — Parasound has announced the introduction of five new power amplifiers and a 7.1 channel A/V surround controller as the first...
Parasound has introduced the Zpre2, a high-quality two-channel audio/video preamplifier with a wide array of connectivity and control features, including two-way RS-232 control, making...
Zhd allows high definition video display owners to add five-source HDMI switching capabilities to audio/video processors from Parasound and others. More images and high...
High resolution image files available at: http://www.gspr.com/parasound/ztunerv2.html SAN FRANCISCO (May 16, 2006) — Parasound has introduced its third generation half-rack width tuner. The Ztuner...
Parasound Debuts John Curl-designed Halo JC 2 Stereo Preamplifier Parasound, one of the world’s most respected manufacturers of high performance audio/video components, is now...
Parasound Model 2100 Preamplifier. For high resolution JPEG files, visit http://www.gspr.com/parasound/2100.html SAN FRANCISCO (7/24/07) — Parasound has introduced the precision Model 2100 stereo preamplifier...
