Parasound Zphono XRM Phono Preamplifier Includes Rumble Filter
Parasound introduced the new Zphono XRM phono preamplifier at $599 to bridge the price gap between their entry-level $200 Zphono and higher-end $1,495 Halo JC 3 Jr. The new model includes balanced XLR outputs, a switchable rumble filter, a mono-stereo switch, plus continuously variable load adjustment for moving coil cartridges. Separate input jacks and independent circuitry for MC and MM cartridges allows it to accommodate two turntables. Like other Parasound Z models, the Zphono XRM uses the company’s compact 1U high x 8-1/2 inches wide chassis.
Parasound Zphono XRM Phono Preamplifier Front
“Our current Zphono is the ideal product for entry-level vinyl lovers” said Richard Schram, Parasound’s president and founder. “We’ve noticed the fast-growing popularity of more expensive turntables and increasingly high-performance MM and MC cartridges. With the Zphono XRM’s adjustable load impedance knob (rather than DIP switches) MC cartridge users can easily make on-the-fly adjustments to achieve the best sound. With its rumble filter and mono-stereo switch, the Zphono XRM provides even more control to the increasingly serious vinyl lover.”
Parasound Zphono XRM Phono Preamplifier Rear
A front panel input switch selects MM and MC input jacks. Each of these jacks has its own circuitry optimized for the cartridge type. This improves the signal-to-noise ratio and overall performance for MM and for both low-output and high-output MC cartridges. A bonus of having separate input jacks with their own circuits is the capability to connect two turntables (or two tonearms mounted on a single turntable). The Stereo/Mono switch combines L and R channels so users can optimize sound quality of mono LPs as well as reducing background noise on worn or poorly stamped pressings. This useful feature is rarely found on even high priced phono preamps, much less at the Zphono XRM’s modest price point. Another significant feature is the Rumble Filter switch which selects a steep 18 dB per octave high-pass filter which “cleans up” the low end by preventing feedback from mechanically transmitted vibrations.
Parasound Zphono XRM Phono Preamplifier Inside
The Zphono XRM has gold-plated single-ended RCA output jacks and balanced gold-plated XLR outputs with a high common mode rejection ratio (CMRR) to reject external sources of noise An internal linear high-capacity/low-noise power supply is a a significant improvement over the competitions’ typical “wall-wart” power supplies.
Price and Availability
The Parasound Zphono XRM will be available by the end of December 2018 with a suggested retail price of $599.
2 Comments
2 Comments
  1. Ed B.
    December 12, 2024 at 1:50 pm
    Great phono amp, recently purchased direct from Parasound for $249.00 … couldn’t pass that price up on a new Zphono XRM, couldn’t be happier. I use it with my Technics 1210GR2 w/ MoFi Master Tracker cartridge and PrimaLuna EVO300 Integrated, couldn’t be happier.
    • Ian White
      December 13, 2024 at 5:03 pm
      Ed,
      We love Parasound. Getting review samples has become a real problem.
      Best,
      IW
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
As of December 8, 2022, Parasound is in new hands. Find out the reason why and what the future may hold.
Does the $3,200 Parasound HINT 6 deliver on its promise of excellent sound quality, reliability, and features galore? We take it for a spin.
SAN FRANCISCO (3/1/05) — Parasound has announced the introduction of five new power amplifiers and a 7.1 channel A/V surround controller as the first...
Parasound has introduced the Zpre2, a high-quality two-channel audio/video preamplifier with a wide array of connectivity and control features, including two-way RS-232 control, making...
Zhd allows high definition video display owners to add five-source HDMI switching capabilities to audio/video processors from Parasound and others. More images and high...
High resolution image files available at: http://www.gspr.com/parasound/ztunerv2.html SAN FRANCISCO (May 16, 2006) — Parasound has introduced its third generation half-rack width tuner. The Ztuner...
Parasound Debuts John Curl-designed Halo JC 2 Stereo Preamplifier Parasound, one of the world’s most respected manufacturers of high performance audio/video components, is now...
Parasound Model 2100 Preamplifier. For high resolution JPEG files, visit http://www.gspr.com/parasound/2100.html SAN FRANCISCO (7/24/07) — Parasound has introduced the precision Model 2100 stereo preamplifier...
