Parasound Zphono-USB Preamplifier and Digital Interface
Parasound introduced the Zphono-USB Preamp and Digital Interface, a compact preamplifier for moving coil and moving magnet (MC/MM) phonograph cartridges and line-level analog sources. The Zphono-USB also adds an analog-to-digital (A/D) converter with a USB port to transfer audio from vinyl LPs onto Mac and PC as digital media. Zphono-USB is the newest of the company's Z-Series family of half-rack-width components.
The Parasound Zphono-USB is a high-quality analog phono preamplifier engineered for the optimum in playback quality for vinyl LPs. Like its predecessor, the Zphono analog phono preamplifier, which continues in the line, Zphono-USB uses high quality parts and precision RIAA equalization to achieve extremely low levels of noise and distortion, and accurate frequency response.
Parasound Zphono-USB Preamplifier - front
Parasound Zphono-USB Preamplifier - back
For the digital realm, the Parasound Zphono-USB also includes an adjustable USB gain control and defeatable RIAA equalization to improve the quality of audio transfers from LPs to digital media. The USB gain control and USB clipping indicator are used to optimize the digital record-output levels for the optimum signal-to-noise ratio with all recording software programs. For those using sophisticated digital music software in their PCs or Macs, the rear-panel RIAA defeat switch allows users to bypass the internal hardware-based RIAA phono equalization in favor of software-based digital equalization. These capabilities are provided only for the rear panel USB digital output.
The Parasound Zphono-USB has a stereo input for an MC or MM phonograph cartridge, and two stereo line-level inputs to facilitate digital transfers of analog sources such as a tuner, CD player or tape deck. Rear-panel settings for MM-47 k, MC-47 k or MC-100 cartridges allow the user to select the ideal impedance matching for their phono cartridge. Front panel rumble-filter and mono/stereo switches are also available to refine the quality of phono playback for older LPs and mono LPs.
There is a single pair of fixed-level line-level outputs and a headphone output. The Zphono-USB has dual power transformers and analog power supplies to minimize noise and an AC polarity reverse switch to combat hum issues related to power line polarity.
Price and Availability
The Parasound Zphono-USB will be available in the first week of September for $350.
Parasound Zphono-USB Preamplifier - inside
Specifications:
  • Frequency Response: 20 Hz – 20 kHz, ±0.5 dB
  • Total Harmonic Distortion: < 0.1% at 20 kHz
  • S/N Ratio MM:
    > 74 dB, input shorted, IHF A-weighted
    > 65 dB, input shorted, unweighted
  • S/N Ratio MC:
    > 63 dB, input shorted, IHF A-weighted
    > 56 dB, input shorted, unweighted
  • S/N Ratio Line Inputs:
    > 103 dB, input shorted, IHF A-weighted
    > 83 dB, input shorted, unweighted
  • Output Impedance: < 100
  • Phono Input Impedance:
    MM setting: 47 k
    MC setting: 47 k or 100
  • Input Sensitivity, 1 kHz:
    MM: 5 mV in for 1.1 V output
    MC: 0.5 mV in for 1.1V output
  • USB A/D Converter: 44.1kHz / 16 bit (CD Quality)
  • AC Power Requirement:
    110-130 VAC, 60 Hz
    220-240 VAC, 50 Hz
    (Voltage is selected on the chassis bottom side)
  • 30 watts
  • Dimensions:
    Width: 9.5″ (242 mm)
    Depth: 10″ (254 mm)
    Height, with feet: 2″ (51 mm)
    Height, without feet: 1.75″ (44 mm)
  • Weight:
    Net: 5 lbs. (2.3 kg)
    Shipping: 8 lbs. (3.6 kg)
  • Rack Mount Accessory:
    SBS — Side by Side Mounting bracket (May be purchased separately)
    Blank panel extender (May be purchased separately)
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
As of December 8, 2022, Parasound is in new hands. Find out the reason why and what the future may hold.
Does the $3,200 Parasound HINT 6 deliver on its promise of excellent sound quality, reliability, and features galore? We take it for a spin.
SAN FRANCISCO (3/1/05) — Parasound has announced the introduction of five new power amplifiers and a 7.1 channel A/V surround controller as the first...
Parasound has introduced the Zpre2, a high-quality two-channel audio/video preamplifier with a wide array of connectivity and control features, including two-way RS-232 control, making...
Zhd allows high definition video display owners to add five-source HDMI switching capabilities to audio/video processors from Parasound and others. More images and high...
High resolution image files available at: http://www.gspr.com/parasound/ztunerv2.html SAN FRANCISCO (May 16, 2006) — Parasound has introduced its third generation half-rack width tuner. The Ztuner...
Parasound Debuts John Curl-designed Halo JC 2 Stereo Preamplifier Parasound, one of the world’s most respected manufacturers of high performance audio/video components, is now...
Parasound Model 2100 Preamplifier. For high resolution JPEG files, visit http://www.gspr.com/parasound/2100.html SAN FRANCISCO (7/24/07) — Parasound has introduced the precision Model 2100 stereo preamplifier...
