Parasound ZoneMaster 250, 450, 650 Multi-channel Amplifiers
Parasound ZoneMaster 250, 450, 650 Amplifiers
Parasound has expanded its ZoneMaster custom installation amplifier line with the introduction of three new models: the two-channel ZoneMaster 250, four-channel ZoneMaster 450, and six-channel ZoneMaster 650. Each uses the same 50-watt bridgeable amplifier circuits, offer the same quality sound, and deliver the same high levels of dependability as the company’s ZoneMaster 1250 Universal 12-channel amplifier, which was introduced last year.
Every ZoneMaster model uses the same Parasound-designed discrete Class AB input stage and specially selected Class D power stage to achieve sonic performance consistent with Parasound’s audiophile heritage, while meeting industry demand for absolute dependability. Each 2-ohm stable, high-current channel pair is rated at 50 watts per channel into 8 ohms, and 90 watts into 4 ohms; bridged mode can deliver 160 watts RMS into 8 ohms and 200 watts RMS into 4 ohms. Each channel pair has an independent oversized power supply for exceptional high-current capabilities.
This combination of high power and low-impedance stability enables each channel to drive multiple speakers. Detachable Phoenix-style speaker connectors accept up to 12-gauge wire, with separate connections for two speakers per channel; up to 24 in the case of the ZoneMaster 1250. The three new models are 1U (1 rack space) high and the 1250 is 2U high. Models 250 and 450 are one-half rack space wide, while the 650 and 1250 are full rack width.
In addition to full-range applications, the ZoneMaster 250 can also be configured to drive in-wall and passive subwoofers thanks to its built-in 18dB/octave low-pass crossover.
All ZoneMaster amplifiers include independent level controls for each channel as well as a speaker-level input making them compatible with any receiver or existing audio system. Installers can choose between a 12-volt turn-on trigger or audio-detection trigger for each zone independently. The 650 and 1250 also include bus inputs with loop outputs. All ZoneMaster models offer exceptionally “green” power consumption with minimal standby power consumption meeting Energy Star and European Union specifications.
Pricing
ZoneMaster 250 $475
ZoneMaster 450 $795
ZoneMaster 650 $1,350
ZoneMaster 1250 $2,395 (previously announced, shipping now)
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
As of December 8, 2022, Parasound is in new hands. Find out the reason why and what the future may hold.
Does the $3,200 Parasound HINT 6 deliver on its promise of excellent sound quality, reliability, and features galore? We take it for a spin.
SAN FRANCISCO (3/1/05) — Parasound has announced the introduction of five new power amplifiers and a 7.1 channel A/V surround controller as the first...
Parasound has introduced the Zpre2, a high-quality two-channel audio/video preamplifier with a wide array of connectivity and control features, including two-way RS-232 control, making...
Zhd allows high definition video display owners to add five-source HDMI switching capabilities to audio/video processors from Parasound and others. More images and high...
High resolution image files available at: http://www.gspr.com/parasound/ztunerv2.html SAN FRANCISCO (May 16, 2006) — Parasound has introduced its third generation half-rack width tuner. The Ztuner...
Parasound Debuts John Curl-designed Halo JC 2 Stereo Preamplifier Parasound, one of the world’s most respected manufacturers of high performance audio/video components, is now...
Parasound Model 2100 Preamplifier. For high resolution JPEG files, visit http://www.gspr.com/parasound/2100.html SAN FRANCISCO (7/24/07) — Parasound has introduced the precision Model 2100 stereo preamplifier...
