Parasound Zdac D/A Converter
zdac_silver_front_300
Parasound just introduced the Zdac, a 192 kHz Digital to Analog Converter that gives consumers the highest possible sound quality when playing digital music files from computers via USB, or from a CD player, Sonos, or other digital media players via optical or coaxial digital connections. Zdac is the newest addition to Parasound’s compact ‘half-width’ Z-Series product family, and it is available in either a black finish with rack-mounting tabs or the new silver finish without rack-mount tabs.
Parasound claims the Zdac sounds more natural and less “digital” than DACs selling for far more because of its innovative design and high quality parts. Its unique re-clocking system preserves the original source audio data by eliminating jitter contamination that is picked up along the digital signal chain. This is accomplished through the synergy of two premium parts, an Analog Devices AD1895 asynchronous sample rate converter and an AD1853 DAC IC, the same DAC IC that Holm selected for our Halo CD 1 CD player. To further improve sound quality the signal is up-sampled to 422kHz. This highly effective jitter-reduction system works on all inputs, not just the USB input, as in many other DACs.
Like all Z Series components, Zdac has a high-quality built-in power supply rather than a typical ‘wall wart.’ In the case of Zdac, an oversized toroid power transformer assures unrestrained dynamics and unparalleled bass extension and authority. All of this quality is available at both unbalanced gold-plated RCA jacks and balanced XLR outputs.
“With the help of acclaimed Danish digital experts Holm Acoustics, Parasound’s Zdac brings digital audio converter (DAC) technology to an entirely higher level of performance at a price comparable to many conventional aftermarket DACs,” said Richard Schram, President of Parasound. “The Zdac is an ideal upgrade for many components such as digital media players with less-than-optimal on-board DACs, or computer audio, TV audio, CD or other player with digital outputs. It’s rugged, reliable, and easy to hook up. Once it is up and running there is little to do but enjoy the music.”
The Zdac headphone output is driven by a low-noise/high current amplifier that will drive nearly any high quality 32- to 600-ohm headphone with ease. A dedicated precision volume control for headphone listening adds to the Zdac’s convenience.
The Zdac includes fast-acting muting relays — usually found only on premium-priced DAC — to eliminate any hint of transient pops or thump noises during turn on/off and when selecting inputs.
The Parasound Zdac is available in the traditional Z-Series black rack-mount configuration and the new Z-Series silver finish without rack tabs. Both versions are one rack-space high. The black Zdac is 9-1/2 inches wide — half of a standard rack width — and the silver Zdac is 8-1/2 inches wide.
The black Zdac can be used with Parasound’s SBS side-by-side bracket to link two Z Custom units together, or Zblank for mounting across one standard rack space. Parasound also offers its half-width Zrack for mounting up to five Z Custom components.
Price and Availability
Both versions of the Parasound Zdac Digital to Analog Converter will be available the second week of November 2012 for $475.
Specifications:
Supports Incoming Digital Word Lengths: 16 bit – 24 bit
Supports Incoming Digital Sampling Frequencies:
Opt & Coax: 8 kHz, 11.025 kHz, 16 kHz, 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz.
USB: 44.1 kHz, 48 kHz, 88.2 kHz and 96 kHz
USB Streaming Controller: Texas Instruments TAS1020B
Upsampling Frequency: 422 kHz / 24 bit (all inputs)
Sample Rate Converter: Analog Devices AD1895
D to A Converter: Analog Devices AD1853
Frequency Response: 20 Hz to 20 kHz +/-0.2 dB
Channel Balance: < 0.05 dB, 20 Hz - 20 kHz Channel Separation: > 95 dB, 20 Hz – 20 kHz
Signal to Noise Ratio: 110 dB, A-weighted
THD + Noise: < 0.015 % Audio Output Level: Unbalanced: 2.1 V rms Balanced: 4.2 V rms Output Impedance: Line out: 160 ohms, balanced or unbalanced Headphone out: 40 ohms AC Power Requirement: 10 watts 110-130 VAC 60 Hz 220-240 VAC 50 Hz voltage is selected on the chassis bottom Dimensions: Width: 9.5" - 241 mm (black); 8.5” - 220 mm (silver) Depth: 10" - 254 mm Height, with feet: 2" - 51 mm; without feet: 1.75" - 45 mm Weight: Net: 5 lbs (2.3kg) Shipping: 8 lbs (3.7kg) Rack Mount Accessory (Black Zdac only): SBS: Side by Side Mounting bracket, purchased separately Zblank: Panel extender, purchased separately (Silver Zdacs cannot be rack mounted)
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
As of December 8, 2022, Parasound is in new hands. Find out the reason why and what the future may hold.
Does the $3,200 Parasound HINT 6 deliver on its promise of excellent sound quality, reliability, and features galore? We take it for a spin.
SAN FRANCISCO (3/1/05) — Parasound has announced the introduction of five new power amplifiers and a 7.1 channel A/V surround controller as the first...
Parasound has introduced the Zpre2, a high-quality two-channel audio/video preamplifier with a wide array of connectivity and control features, including two-way RS-232 control, making...
Zhd allows high definition video display owners to add five-source HDMI switching capabilities to audio/video processors from Parasound and others. More images and high...
High resolution image files available at: http://www.gspr.com/parasound/ztunerv2.html SAN FRANCISCO (May 16, 2006) — Parasound has introduced its third generation half-rack width tuner. The Ztuner...
Parasound Debuts John Curl-designed Halo JC 2 Stereo Preamplifier Parasound, one of the world’s most respected manufacturers of high performance audio/video components, is now...
Parasound Model 2100 Preamplifier. For high resolution JPEG files, visit http://www.gspr.com/parasound/2100.html SAN FRANCISCO (7/24/07) — Parasound has introduced the precision Model 2100 stereo preamplifier...
