Parasound NewClassic 5250 v.2 Five Channel THX Ultra2 Power Amplifier
Parasound has redesigned its Model 5250 power amplifier after six years as the flagship of its popular NewClassic family of products. The new Parasound NewClassic Model 5250 v.2 is ideal for home theater enthusiasts who want the performance of a very high-powered amplifier, while pairing it with an affordable state-of-the-art surround receiver that has all the latest technology.
The Parasound NewClassic 5250 v.2 offers the same THX Ultra 2 Certified, five-channel, 250-watts per channel power ratings as its predecessor, but with a more graceful front panel design, adjustable gain for each channel making it compatible with the preamp outputs of any AVR, and more than 60 other improvements to its operating features and circuitry.
Like its predecessor, the new Model 5250 v.2 delivers exceptional power output and low noise performance capabilities. With discrete power transistors, dual toroid power transformers, and large storage capacitors, the 5250 v.2 can deliver peak currents of 45 amps per channel, and sustain 385 watts per channel into 4-ohm loads. Despite this high-energy operation, the amplifier does not run hot, and is designed for cool running even in relatively confined spaces.
Unlike its predecessor, which had fixed gain at the THX reference level, the NewClassic 5250 v.2 allows independent +/- 10 dB gain adjustment for each channel relative to the THX level. This allows home theater systems to reach higher SPLs in very large rooms or when using less sensitive speakers. Plus, it gives custom installers greater control over fine-tuning of the system, especially when connected to an AV receiver. Additionally, the NewClassic 5250 v.2 has a new simplified and more effective audio turn-on trigger that eliminates the need for a separate sensitivity control. Also eliminated is the ground-lift switch, which has been rendered unnecessary by a new internal grounding scheme.
Price and Availability
The Parasound NewClassic Model 5250 v.2 is now shipping to dealers, and has a manufacturer's suggested retail price of $2,850.
Parasound NewClassic 5250 v.2 Five Channel THX Ultra2 Power Amplifier - Rear
“The NC 5250 v.2 provides a terrific solution for home theater enthusiasts who want great performance but worry about the cost of updating a new top-of-the line surround receiver every few years to keep pace with changing technology,” said Richard Schram, Parasound's president and founder. “A high quality and powerful amplifier will never really become obsolete. Rather than spend $2,500 to $5,000 for a high power surround receiver every time technology changes, why not spend $800-$1200 for a lower powered surround receiver which has the same decoding and most of the same useful features, while connecting its preamp outputs to a 5250 v.2 to give the system a significant increase in audio power?”
Parasound NewClassic NC 5250 v.2 Power Amplifier Specifications
Continuous RMS Power Output 20 Hz – 20 kHz, Five Channels Driven
250 watts x 5, 8 Ω
385 watts x 5, 4 Ω
Current Capacity 45 amps peak per channel
Frequency Response 20 Hz – 50 kHz, +0/-3 dB, 1 watt
Dynamic Headroom 1.6 dB
Total Harmonic Distortion 0.025% at full rated output
0.02% at average listening levels
IM Distortion 0.05 %
Transient IM Distortion Not measurable
S/N Ratio 114 dB at rated output, IHF A-weighted
106 dB at rated output, unweighted
93 dB at 2.828 V output, IHF A-weighted
84 dB at 2.828 V output, unweighted
Input Impedance 33 k Ω
Input Sensitivity 1 V in for 28.28 V out, THX reference level
1.6 V for full rated output, adjustable from 500mV to 5V
Inter-Channel Crosstalk 85 dB, 1 kHz
73 dB, 10 kHz
67 dB, 20 kHz
Damping Factor Over 150 at 20 Hz
Auto Turn On – DC 9 – 12V, 15 mA
Auto Turn On – Audio 1mV sensitivity
15 minute turn off delay
AC Power Requirement 110 – 120 V / 220 -240 V, 50 – 60 Hz
1 watt standby; 2500 watts full output
Dimensions 17-1/4″ Wide
19″ Deep with gain control knobs,
7-5/8″ High with feet, 7″ panel only
437 x 470 x 193mm, 176mm panel only
Net Weight 69 lbs., 31.4 kg
Rack Mount Accessory RMK44 – May be Purchased Separately
MSRP $2,850
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
As of December 8, 2022, Parasound is in new hands. Find out the reason why and what the future may hold.
Does the $3,200 Parasound HINT 6 deliver on its promise of excellent sound quality, reliability, and features galore? We take it for a spin.
SAN FRANCISCO (3/1/05) — Parasound has announced the introduction of five new power amplifiers and a 7.1 channel A/V surround controller as the first...
Parasound has introduced the Zpre2, a high-quality two-channel audio/video preamplifier with a wide array of connectivity and control features, including two-way RS-232 control, making...
Zhd allows high definition video display owners to add five-source HDMI switching capabilities to audio/video processors from Parasound and others. More images and high...
High resolution image files available at: http://www.gspr.com/parasound/ztunerv2.html SAN FRANCISCO (May 16, 2006) — Parasound has introduced its third generation half-rack width tuner. The Ztuner...
Parasound Debuts John Curl-designed Halo JC 2 Stereo Preamplifier Parasound, one of the world’s most respected manufacturers of high performance audio/video components, is now...
Parasound Model 2100 Preamplifier. For high resolution JPEG files, visit http://www.gspr.com/parasound/2100.html SAN FRANCISCO (7/24/07) — Parasound has introduced the precision Model 2100 stereo preamplifier...
