Parasound Drops The HINT 6 Integrated Amplifier
Parasound Hint 6 Integrated Amplifier
Parasound has introduced the HINT 6, an improved version of its popular Halo Integrated Amplifier. After the original Halo Integrated Amplifier was introduced, it quickly became known as “HINT” in the Parasound community, and that name is now adopted in the new model. The sound quality and musicality of the original Halo Integrated (HINT) carries on in the HINT 6. The new model features a Burr-Brown volume control with easy-to-read front panel display. It also adds an upgraded USB receiver with plug and play functionality for Windows and Mac, a second optical input, increased phono gain, greater channel separation, and some pleasing refinements to its appearance.
Parasound Hint 6 Integrated Amplifier Rear
The Parasound HINT 6 uses the same powerful John Curl designed power amplifier. This 160-watt per channel (240-watts @ 4 ohms) amplifier is based on Curl’s Class direct coupled A/AB circuit topology found in Parasound’s renowned separate power amplifiers. These capabilities are further enhanced with a home-theater bypass function, 2.1-channel analog bass management, a dedicated high-current headphone amplifier, and MM/MC phono stage.
Parasound Hint 6 Integrated Amplifier Inside
The Parasound HINT 6 volume control replaces the original model’s motorized potentiometer and sliding mechanical contacts with a Burr-Brown electronically controlled analog resistor ladder volume control. Technical advancements in the new volume control offer a more distinct sound stage by increasing the dynamic range, lowering the noise floor, improving left-right separation and maintaining absolute left-right channel tracking at any volume level. The solid aluminum volume knob is supported on ball bearings to rotate with exceptional smoothness, while the dimmable two-digit display shows volume level in increments from 0-99. This advanced volume control enables users to program both a default turn-on volume level as well as a favorite-volume level with remote control button.
Parasound Hint 6 Remote Control
The Parasound HINT 6 uses a proven ESS Sabre32 Reference DAC to decode a wide range of digital music files via two optical, one coaxial, and a new upgraded USB receiver; now with plug and play support for Windows 10 in addition to Mac. The asynchronous USB 2.0 input supports PCM up to 384 kHz/32-bit, native DSD256 and DoP DSD bit streams. The coax and optical inputs accept PCM up to 192 kHz/24-bit.
Among other circuit improvements are an upgraded op-amp in the preamp gain stage, improved L-R channel separation, and increased gain for the MC and MM phono inputs.
The new chassis is available in either black or silver finish, with its visual appeal enhanced by the addition of subtle gold highlights and sand-blasted solid aluminum end caps.
Price and Availability
The Parasound HINT 6 will ship to dealers in July 2018, with a suggested retail price of $2,995.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
As of December 8, 2022, Parasound is in new hands. Find out the reason why and what the future may hold.
Does the $3,200 Parasound HINT 6 deliver on its promise of excellent sound quality, reliability, and features galore? We take it for a spin.
SAN FRANCISCO (3/1/05) — Parasound has announced the introduction of five new power amplifiers and a 7.1 channel A/V surround controller as the first...
Parasound has introduced the Zpre2, a high-quality two-channel audio/video preamplifier with a wide array of connectivity and control features, including two-way RS-232 control, making...
Zhd allows high definition video display owners to add five-source HDMI switching capabilities to audio/video processors from Parasound and others. More images and high...
High resolution image files available at: http://www.gspr.com/parasound/ztunerv2.html SAN FRANCISCO (May 16, 2006) — Parasound has introduced its third generation half-rack width tuner. The Ztuner...
Parasound Debuts John Curl-designed Halo JC 2 Stereo Preamplifier Parasound, one of the world’s most respected manufacturers of high performance audio/video components, is now...
Parasound Model 2100 Preamplifier. For high resolution JPEG files, visit http://www.gspr.com/parasound/2100.html SAN FRANCISCO (7/24/07) — Parasound has introduced the precision Model 2100 stereo preamplifier...
