Parasound Improves Stereo Amplifiers for 2019
Parasound Halo A 21+ Stereo Amplifier (2019)
Parasound has announced a more-powerful “plus” versions of their A 21 and A 23 power amplifiers that were in continuous production since 2003. The new Parasound Halo A 21+ (pictured above) and Halo A 23+ stereo amps employ higher-capacity power supplies to increase output from 250 to 300 watts and 125 to 160 watts respectively.
Parasound and John Curl, their primary design consultant for the past 30 years, targeted power supply transformers and filter capacitors as the foundation for power output increases. They also further refined audio quality in the signal-path and related circuitry with upgraded gold-on-gold internal connections to improve resolution and increase transparency. In fact, the design team consensus is that the sonic improvements are as impressive as the power increases.
Parasound Halo A 21+ Stereo Amplifier Back (2019)
With its larger 1.3kVA power transformer and 108,000 uF power supply capacitance, the Parasound Halo A 21+ output has jumped from 250 to 300 watts into 8 ohm loads, 400 to 500 watts into 4 ohms, and from 750 to 1000 watts in bridged mode. Further improvements have increased the signal-to-noise ratio from 112 dB to 115 dB, increased crosstalk from 63 dB to 70 dB, while the THD (total harmonic distortion) at full rated power output has decreased from 0.2% to 0.1%. Not surprisingly, these improvements pushed its net weight over 18% from 60 to 71 pounds. Like the original A 21, the new A 21+ amplifier gives users a choice of balanced and unbalanced inputs with loop outputs, and variable gain controls. The most visible rear-panel difference on the A 21+ is new CHK Infinium heavy duty speaker terminals originally developed for the top-of-the-line 2 x 400w Halo JC 5.
Parasound Halo A 23+ Stereo Amplifier (2019)
The new Parasound Halo A 23+ is similarly improved, with a larger 1.1kVA power transformer and 54,400 uF power supply capacitance. This supports increasing power output from 125 to 160 watts into 8-ohm loads, 225 to 240 watts into 4 ohms, and from 400 to 500 watts in mono bridged mode. The A 23+ has balanced and unbalanced inputs with adjustable gain controls, loop outputs, and new higher-performance speaker terminals adapted from the popular Parasound HINT 6 integrated amplifier.
Parasound Halo A 23+ Stereo Amplifier Back (2019)
Both new amplifier models feature more-refined Halo styling, including solid aluminum end caps with gold highlights. Both models include 12-volt DC triggers with loop outputs, plus more sensitive audio auto turn-on.
Price & Availability
The new 2019 “plus” amplifiers are now available in silver or black finishes through Parasound dealers with suggested retail prices of:
  • Parasound Halo A 21+ (2 x 300w) – $3,149
  • Parasound Halo A 23+ (2 x 160w) – $1,495
About Parasound: Founded in 1981, Parasound Products, Inc., is a privately owned U.S. company that specializes in providing affordable audio components to the critical listener. The company’s ever-improving line of audio products has garnered a reputation for performance, value, and reliability. The highest quality standards are assured by Parasound’s relationships with their Taiwan audio manufacturers that date back to 1982.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
As of December 8, 2022, Parasound is in new hands. Find out the reason why and what the future may hold.
Does the $3,200 Parasound HINT 6 deliver on its promise of excellent sound quality, reliability, and features galore? We take it for a spin.
SAN FRANCISCO (3/1/05) — Parasound has announced the introduction of five new power amplifiers and a 7.1 channel A/V surround controller as the first...
Parasound has introduced the Zpre2, a high-quality two-channel audio/video preamplifier with a wide array of connectivity and control features, including two-way RS-232 control, making...
Zhd allows high definition video display owners to add five-source HDMI switching capabilities to audio/video processors from Parasound and others. More images and high...
High resolution image files available at: http://www.gspr.com/parasound/ztunerv2.html SAN FRANCISCO (May 16, 2006) — Parasound has introduced its third generation half-rack width tuner. The Ztuner...
Parasound Debuts John Curl-designed Halo JC 2 Stereo Preamplifier Parasound, one of the world’s most respected manufacturers of high performance audio/video components, is now...
Parasound Model 2100 Preamplifier. For high resolution JPEG files, visit http://www.gspr.com/parasound/2100.html SAN FRANCISCO (7/24/07) — Parasound has introduced the precision Model 2100 stereo preamplifier...
