Parasound Halo A 31 THX Ultra2 Power Amplifier
Parasound announced a three-channel home theater power amplifier to its premium Halo product family. The THX Ultra2 certified Parasound Halo A 31, which is rated at 250 RMS watts per channel, is sonically identical to the company’s five channel Halo A 51 and two channel Halo A 21 amplifiers.
The A 31 was developed for Parasound customers who want their surround systems to include uncompromised reproduction of stereo music. The A 31 is ideal for this because it also provides matched amplification for the center channel speaker.
The Parasound Halo A 31 provides high-bias Class A/AB operation with pure Class A operation up to 7 watts per channel. It easily delivers 250 watts per channel into 8 ohms and 400 watts into 4 ohms, all channels driven. Exceptional sound quality is maintained with XLR balanced inputs as a step-up alternative to the RCA single-ended inputs. Parasound’s traditional Halo topology employs matched pairs of complementary JFETs for its input-pre-driver stages, matched pairs of complementary MOSFETs in its driver stages and 8 beta-matched 15 amp, 60 MHz bipolar output transistors for each channel.
The A 31 is direct coupled, and uses no capacitors or inductors in signal path with full power output down to 5 Hz. The loudspeakers are connected via heavy-duty 24k gold-plated five-way speaker terminals, and each is relay protected.
The power supply consists of a 1.35kVA encapsulated toroid power transformer with independent secondary windings for each channel. Power stability is maintained by four premium power-supply filter capacitors per channel totaling 94,000µF, and protected by DC servos and relay protection circuits.
The Parasound A 31 provides a gain control for each channel offering ±6db relative to THX reference level. This enables the A 31 to play louder in very large rooms and facilitates level matching with other amplifiers. Other features include: auto turn-on options by an audio signal with a threshold adjust or a 12v trigger with input and loop out jacks plus indicators for AC power, channel status, and high temperature. The heavy-duty 4u chassis has rear carry handles, and an included rack-mounting adaptor. The front panel is anodized aluminum.
Possible uses for 3-channel amps:
  • Powering the C, LS, and RS channel speakers when a separate two-channel amplifier (or pair of monoblocks) is used for the L and R channel speakers.
  • For L, C and R “one wall” theater systems without surround speakers.
  • Powering the LS, RS and single back channel speaker in a 6.1 system.
Price and Availability
The Parasound Halo A 31 will be available in April 2012 for $3,000.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
As of December 8, 2022, Parasound is in new hands. Find out the reason why and what the future may hold.
Does the $3,200 Parasound HINT 6 deliver on its promise of excellent sound quality, reliability, and features galore? We take it for a spin.
SAN FRANCISCO (3/1/05) — Parasound has announced the introduction of five new power amplifiers and a 7.1 channel A/V surround controller as the first...
Parasound has introduced the Zpre2, a high-quality two-channel audio/video preamplifier with a wide array of connectivity and control features, including two-way RS-232 control, making...
Zhd allows high definition video display owners to add five-source HDMI switching capabilities to audio/video processors from Parasound and others. More images and high...
High resolution image files available at: http://www.gspr.com/parasound/ztunerv2.html SAN FRANCISCO (May 16, 2006) — Parasound has introduced its third generation half-rack width tuner. The Ztuner...
Parasound Debuts John Curl-designed Halo JC 2 Stereo Preamplifier Parasound, one of the world’s most respected manufacturers of high performance audio/video components, is now...
Parasound Model 2100 Preamplifier. For high resolution JPEG files, visit http://www.gspr.com/parasound/2100.html SAN FRANCISCO (7/24/07) — Parasound has introduced the precision Model 2100 stereo preamplifier...
