Paradigms Reference Signature SUB 25 has Brains to Match its Brawn
A range of features, such as universal input power, Power Factor Correction and optional integration of room correction technology, make the new subwoofer as smart as it is powerful.
Paradigm Electronics Inc., an international leader in speaker design and manufacturing, introduces its most powerful and intelligent subwoofer ever: the Signature SUB 25. Recognizing that on-demand power is the essence of subwoofer performance, Paradigm has designed the SUB 25 to effectively harness and optimize AC line current for optimal performance.
All AC line voltages are not created equal, and some A/V equipment has more robust power demands than others. Paradigm has equipped the SUB 25 with universal input power, which allows the subwoofer to operate intuitively on a 120 V or 230 V circuit. This is possible because the SUB 25 can handle the load from any line voltage between 108 V and 265 V.
This flexibility to accept a range of line voltages is welcome, but how this power is managed is even more critical. The SUB 25’s Power Factor Correction technology shapes the AC line input current to be sinusoidal and continuous in time. A unit without Power Factor Correction can only draw about 60 to 70 percent of the maximum available power because the current only flows at the peaks of the line voltage, essentially “choking” the line. The use of Power Factor Correction allows the SUB 25 to accept the maximum possible amount of input power, while its high-efficiency Ultra-Class D™ amplifier, rated at 7,500 watts Dynamic Peak and 3,000 watts sustained RMS, allows the maximum amount of output power. By combining both, the SUB 25 delivers the most power that can be obtained from the AC line.
The SUB 25’s new high-power 15-inch driver with three-inch peak-to-peak cone travel, improved high-efficiency motor assembly, massive shorting ring and all new FEA-optimized elliptical surround offer high linearity, greater excursion, lower distortion and greater effective cone area.
An optional yet valuable add-on for the SUB 25 is Paradigm’s Perfect Bass Kit (PBK-1™) interface, a state-of-the-art room correction system derived from sister company Anthem Electronics’ acclaimed ARC-1™ system. PBK-1 uses proprietary processing to compute in-room frequency response of up to four different SUB 25s before computing a target frequency response for each, yielding optimized in-room reproduction of low frequencies.
Additional Features of the Paradigm Reference Signature SUB 25:
  • L/R RCA Audio inputs
  • Subwoofer Input
  • Balanced XLR input
  • Independently adjustable output level, bandwidth and phase
  • Power modes: Off, Trigger and Auto
  • External Trigger input
  • Reconfigurable via USB port
The Reference Signature SUB 25 will ship in late Q3. It has a U.S. FMV of $3,999. The optional PBK-1 interface has a U.S. FMV of $299.
For more information on Paradigm, please visit www.paradigm.com.
Innovative design, advanced materials, in-house manufacturing and state-of-the-art engineering have made Paradigm an international leader in speaker design. With more than 250 industry awards for audio excellence and numerous rave reviews from around the world, Paradigm is committed to staying at the leading edge of speaker technology, consistently achieving the ultimate in sound for music and home theater.
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
Paradigm Electronics Inc. announced the MilleniaSub, a Reference subwoofer in unconventional design that boasts performance and affordability all in one sleek and unique cabinet....
Paradigm Electronics Inc. announced its fifth version (v.5) of the PDR subwoofer series. The performance and value PDR series offers superb definition and deep...
Monitors
Paradigm introduced three new subwoofers featuring the same new streamlined aesthetics and smaller footprint that define the updated Monitor 7 Series Speakers. The new...
Paradigm introduced their new line of 5.1 Compact Theater systems — Cinema 70 CT, Cinema 90 CT and Cinema 110 CT. These are Paradigm’s...
PRESS RELEASE Contact: Caster Communications, Inc. at 401.792.7080 Paradigm Is Thinking “Outside The Box” With Its New Compact Theater Line ONTARIO, CANADA — November...
PARADIGM’S NEW COMPACT THEATER LINE — FILLING A DEMAND IN THE MARKET AND SHIPPING NOW! ONTARIO, CANADA — March 24, 2005 — Paradigm’s hot...
‘Must have technology’ the focus for upgraded line of in-wall/in-ceiling speakers from high-end Paradigm Reference. ONTARIO, CANADA — March 30, 2007 —Paradigm Electronics Inc....
