Loudspeakers
Paradigm Reference Millenia LP On-Wall LCR Speaker
A mountable on-wall LCR speaker for AV minimalists who want the in-wall aesthetic without the light construction
Paradigm just announced the Millenia LP on-wall LCR speaker to their Reference series. The ultra-thin (1-1/2″) cabinet profile is slim enough to hang with the sleekest LED, LCD, or plasma flat-panel displays, even meshing with projector screens while reproducing music, soundtracks and dialogue with accurate ease.
Lifestyle speakers are in demand and the Millenia LP caters to audio enthusiasts building a system piece by piece since each speaker can be used for left/right or center channel sound, just by configuring vertically or horizontally, depending on preference. The Millenia LP LCR delivers for those in search of non-architectural, minimalistic, audio options since it requires no custom speaker cut-out holes. Simply cut out small holes for the speaker wire and mount the speakers to the wall for a clean LCR set up.
Built with Paradigm Reference technology, the Millenia LP features convex S-PAL satin-anodized pure aluminum domes, curved mineral-filled polypropylene bass/midrange cones and other award-winning design elements. Three Reference Millenia LPs can be paired with the sonically-matched Millenia ADP surrounds and a Millenia Sub or Seismic 110 to create an acoustically immersive and aesthetically pleasing 5.1 surround sound set-up.
“With HD displays getting thinner, some people want high-performance speakers like the Millenia LP that hang with an equally low profile and yet do not require invasive construction.”
— Mark Aling, Director of Marketing for Paradigm
Availability
The Millenia LP comes in Black Gloss finish and will be available spring 2011. Check price.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Paradigm Electronics Inc. announced the MilleniaSub, a Reference subwoofer in unconventional design that boasts performance and affordability all in one sleek and unique cabinet....
Paradigm Electronics Inc. announced its fifth version (v.5) of the PDR subwoofer series. The performance and value PDR series offers superb definition and deep...
Monitors
Paradigm introduced three new subwoofers featuring the same new streamlined aesthetics and smaller footprint that define the updated Monitor 7 Series Speakers. The new...
Paradigm introduced their new line of 5.1 Compact Theater systems — Cinema 70 CT, Cinema 90 CT and Cinema 110 CT. These are Paradigm’s...
PRESS RELEASE Contact: Caster Communications, Inc. at 401.792.7080 Paradigm Is Thinking “Outside The Box” With Its New Compact Theater Line ONTARIO, CANADA — November...
PARADIGM’S NEW COMPACT THEATER LINE — FILLING A DEMAND IN THE MARKET AND SHIPPING NOW! ONTARIO, CANADA — March 24, 2005 — Paradigm’s hot...
‘Must have technology’ the focus for upgraded line of in-wall/in-ceiling speakers from high-end Paradigm Reference. ONTARIO, CANADA — March 30, 2007 —Paradigm Electronics Inc....
