Loudspeakers
Paradigm Cinema 100, 200, 400, Trio Speakers
Paradigm announced the new value-based Cinema speakers for home theater, available as bookshelf/satellite speakers, on-walls and a subwoofer. Trickle-down technologies from the acclaimed Reference lines combined with best-in-class build materials make the new Cinema speakers a perfect entry point for aspiring audiophiles and home theater enthusiasts.
Reengineered and redesigned from head to toe, Cinema is comprised of all new models including: Cinema 100 satellite (table-top stand and wall-mount bracket included), Cinema 200 on-wall, Cinema 400 on-wall, Cinema Trio 3-in-1 LCR, Cinema Sub and the Cinema 100 CT 5.1 system. A seemingly endless array of audio configurations can be arranged with the combination of satellite, on-wall and 3-in-1 speakers, depending on customer preference.
Paradigm Cinema Series Trio Speakers
Starting with build materials, Paradigm infused Cinema speakers with Reference-quality crossovers, S-PAL satin-anodized pure-aluminum dome tweeters and wire-mesh tweeter guards with WaveGuideTM technology borrowed from the Reference Signature series, which encourage wide and spacious dispersion while protecting the sensitive dome surface. Mineral-filled polypropylene bass/midrange cones with added mineral content stiffen cone composition. Across the series, acoustic achievements include: lower frequency extension, flat response curves, further reduced distortion, sustained sensitivity and improved full dispersion.
Aesthetically, Cinema speakers include new curved and sculpted acoustic suspension cabinets with industrial high-gloss finish, offering a modern appeal. Push-through binding posts with new Easy-Glide wire channels allow for painless installation and banana plug access. For placement flexibility without sacrificing performance, Paradigm equipped new Cinema with the EasyMount wall-mounting system (and contemporary tabletop stand option – Cinema 100 only). Cinema speakers also feature removable self-aligning StayTight magnetic grilles (excluding Cinema 100) for fit-like-a-glove contact and perfect alignment.
Paradigm Cinema 400
Cinema 400 on-wall
While speakers get the most attention, the low-frequency contributions of the Cinema Sub are not to be ignored. With a dramatically increased dynamic range over the last Cinema Sub, this subwoofer features an 8″ high-excursion driver made of polymer composite, capable of producing 300 watts Dynamic Peak and 100 watts RMS sustained. The Cinema Sub is included in the Cinema 100 CT system or available a la carte and allows for two different placement options: gloss side up or cloth side up depending on your aesthetic preference.
The Paradigm MC-30 high-performance floor stand (sold separately) adds another sturdy set-up option for the Cinema 100 with its extruded aluminum post, polymer base and cast iron ballast. A customized bracket head and hidden cable channel ensure this stand will never attract more attention than the speaker it supports.
Paradigm Cinema 200
Cinema 200 on-wall
Pricing (per speaker)
$149Cinema 100 2-driver, 2-way — 1″ tweeter, 4″ bass/mid driver.
$249Cinema 200 3-driver, 2-way — 1″ tweeter, two 4″ bass/mid drivers.
$399Cinema 400 5-driver, 2-1/2 way — 1″ tweeter, one 4″ bass/mid driver, one 4″ bass driver.
$549Cinema Trio 7-driver, 3-channel, 2-way — three 1″ tweeters, four 4″ bass/mid drivers.
$349Cinema Sub 8-inch high-excursion driver, 300 watts Dynamic Peak, 100 watt RMS sustained.
$999Cinema 100 CT Five Cinema 100 satellite speakers and one Cinema Sub (pictured at top).
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
Paradigm Electronics Inc. announced the MilleniaSub, a Reference subwoofer in unconventional design that boasts performance and affordability all in one sleek and unique cabinet....
Paradigm Electronics Inc. announced its fifth version (v.5) of the PDR subwoofer series. The performance and value PDR series offers superb definition and deep...
Monitors
Paradigm introduced three new subwoofers featuring the same new streamlined aesthetics and smaller footprint that define the updated Monitor 7 Series Speakers. The new...
Paradigm introduced their new line of 5.1 Compact Theater systems — Cinema 70 CT, Cinema 90 CT and Cinema 110 CT. These are Paradigm’s...
PRESS RELEASE Contact: Caster Communications, Inc. at 401.792.7080 Paradigm Is Thinking “Outside The Box” With Its New Compact Theater Line ONTARIO, CANADA — November...
PARADIGM’S NEW COMPACT THEATER LINE — FILLING A DEMAND IN THE MARKET AND SHIPPING NOW! ONTARIO, CANADA — March 24, 2005 — Paradigm’s hot...
‘Must have technology’ the focus for upgraded line of in-wall/in-ceiling speakers from high-end Paradigm Reference. ONTARIO, CANADA — March 30, 2007 —Paradigm Electronics Inc....
