Pandigital PANSCN06 Personal Photo Scanner/Converter
Pandigital announced today that it has expanded its line of innovative photo scanners with a new model — the Pandigital PANSCN06 Personal Photo Scanner/Converter — that can scan print photos up to 8 ½ x 11-inches large.
Incredibly simple to use, the Pandigital Personal Photo Scanner/Converter requires no PC to convert print photos into digital images. Consumers can simply plug it in, insert their photo through the slim device, and, with a single touch of a button, scan photos onto the included SD card. Consumers can then insert the SD card loaded with full-color JPEG images into their computer to upload the photos or insert the card into their Pandigital digital photo frame to immediately view the images.
While the Pandigital Personal Photo Scanner/Converter (PANSCN06) can accommodate photos up to 8 ½ x 11-inches large, it can also scan in photos as small as wallet-sized or any size in-between.
The Pandigital scanner does not require any expensive or confusing software and employs a new twin-roller feeding system to ensure that the photos are scanned evenly each time. Further optimizing the quality, images are scanned at up to 600 optical dpi for resulting scans that have a crisp and clear 3800×7200 24-bit color depth resolution. In addition to being able to scan images onto the included SD memory card, the scanner accepts other popular memory cards (SD, MS, MS Pro, MMS, XD) and can also be connected directly to either a Mac or PC computer via its mini-USB port.
Weighing in at less than a pound at only 13.79 ounces and measuring only 10.59(L) x 1.73(H) x 2.32(D) inches, the Pandigital Personal Photo Scanner/Converter is incredibly portable and can be taken nearly anywhere to quickly and simply preserve images.
The new Pandigital Personal Photo Scanner/Converter extends Pandigital's line of photo scanners which also includes the Pandigital PhotoLink One-Touch 5×7 Scanner and the Pandigital Photo & Negative Scanner that can scan print images up to 4×6-inches large as well as negatives.
Availability and Pricing
The Pandigital Personal Photo Scanner/Converter is available now for a Manufacturer's Suggested Retail Price of $149.99.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
