Panasonic SC-ZT2 Wireless Speaker System
Delivers Full Sound Without Cables
Panasonic just announced the launch of its first fully wireless home theater audio system made for Full HD 3D. The new SC-ZT2 can transmit Full HD 3D signals from the Full HD 3D Blu-ray Disc™ Player to the Full HD 3D TV, without the need for speaker cables. With the SC-ZT2, home theater enthusiasts, including those with 3D theater systems, can do away with speaker cables and arrange speakers throughout the room without worrying about tripping hazards or unsightly cables crossing the floor.
The SC-ZT2 is compatible with Audio Return Channel (ARC), which allows receiving audio signal from the TV through a single HDMI cable. This new feature simplifies the set-up by eliminating the need for a separate optical audio connection. It also supports 3D images and Full HD video.
Panasonic’s advanced proprietary virtual technology lets users enjoy Dolby TrueHD and DTS™-HD 7.1-channel surround sound with only two speakers. Each speaker houses four one-inch tweeters. These tweeters are vertically aligned and emit sounds parallel to the floor enabling one to listen from anywhere in the room, regardless of lying down or sitting on a sofa. Also with the ultra-slim pole design for minimal unwanted sound reflections, the SC-ZT2 delivers crisp, clear sounds directly to the listeners.
The speakers also boast an integrated long-stroke woofer, with a diameter of approximately five inches, which generates sounds from the low-frequency range to deep bass that is typically produced by subwoofers. It uses a Down-Fire structure which uses the floor as an acoustical reflector to produce dynamic bass sounds that are extremely robust for the size of the speakers. With woofers in both speaker stands, listeners experience rich bass sounds from the front, back, left and right sides of the system.
Elegant and space-saving, the Panasonic SC-ZT2 wireless audio system includes two ultra slim pole speakers and a wireless receiver. It is an ideal complement to a flat-panel TV and Blu-ray player. The SC-ZT2 will be available in June 2010.
June 1, 2010 Update
The SC-ZT2 is now available with a suggested retail price of $999.95.
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
