DAPs
Panasonic SC-SP100 iPod Audio System
Panasonic just introduced the new SC-SP100, an ultra compact, high-quality 2.1-channel audio system that plays music from an iPod while also charging the iPod battery. Its unique design is compatible with the iPod and iPhone. Boasting a sleek, compact design, the SC-SP100 fits easily into a small area, such as a desktop, and is ideal for use in rooms with limited space. It employs advanced proprietary audio technologies to deliver maximum iPod listening enjoyment.
With its integrated subwoofer and Dual Passive Radiator, the SC-SP100 delivers robust bass and generates low-frequency sounds. A special Down-Firing structure disperses the sound facing downward, resulting in dynamic bass sounds belying its compact chassis.
Music data can be transferred from a computer to a docked iPod or iPhone by simply connecting the SC-SP100 with a USB cable. There is no need to remove the iPod or iPhone from the dock. With these and other convenience features, the SC-SP100 makes it easy to enjoy high-fidelity music from an iPod, making it ideal for home, dorm or office settings.
Features of the SC-SP100 include:
  • Total output power: 20W (RMS)
  • Integrated Universal Dock for iPod (Works with iPhone)
  • PC Synchronization with iPhone / iPod (USB Mini Type B)
  • Analog Audio Input: Music Port
  • Bass/Surround
  • Down Firing Structure
  • Speaker: 1.5-inch Cone Full Range x2
  • Integrated Subwoofer: 2.5-inch Cone Woofer, Dual Passive Radiators
The Panasonic SC-SP100 will be available in January 2010.
