Panasonic SC-NT10 Portable Bluetooth Speaker
Panasonic SC-NT10 Portable Wireless Speaker System
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use near water areas like the pool or beach; Dust Proof making it well suited for areas such as sandy beaches; Shock Proof (passing drop tests from a maximum of 30 inches) which allows impact resistance during use in sports; and Freeze/ Heat Proof which allows for the device to withstand severe climates, such as hot days under the scorching sun and cold winters on the ski slopes.
The Panasonic SC-NT10 incorporates two Full Range Speakers (1-3/ 8 inches) and a Passive Radiator (2 inches) to produce crystal clear audio. Additionally, XBS Master, a high-quality music technology developed by Panasonic, is filled with premium sound technology including XBS, which amplifies low-frequency sounds; Multi Band Gain Control, which eliminates unnatural sounds generated in the process of automatically controlling distortion; and H.BASS, which adds harmonics to enable the reproduction of bass sounds at low frequencies, such as 80 Hz or less, which were previously difficult to reproduce with this class of speaker. Using Boost Mode, the SC-NT10 can boost the midrange sounds that are naturally easy to hear, so music that was lost in surrounding noise is clear for comfortable listening.
Panasonic SC-NT10 on bench
The Panasonic SC-NT10 Smart Networking features allow for greater ease-of-use. NFC (Near Field Communication) enables easy Bluetooth pairing for connection to a smartphone or tablet device by simply passing the device over the SC-NT10. Audio signals that are lost during transmission from a smartphone or tablet are compensated by the Bluetooth Re-master function for a level of sound quality that virtually equals the originally transmitted sound. In addition to playing music, a built-in microphone allows for hands-free conversation when you get a phone call through your connected smartphone.
The Panasonic SC-NT10 operates on a rechargeable battery that operates continuously for up to eights hours. Users can also charge their smartphone or tablet device directly from the SC-NT10’s USB port.
Price and Availability
The Panasonic SC-NT10 Portable Wireless Speaker will be available in Orange/Black and Blue/Black in Fall 2013 for $99.99. A “body suit” accessory, available for $29.99, allows the SC-NT10 to easily clip virtually anywhere – on clothing, a bicycle, etc.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Bose just expanded its Bluetooth speaker lineup with one for home and another to take wherever your path leads you.
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
