Panasonic SC-HTB520 Slim Bar Speaker System
Panasonic today unveiled a new slim bar home theater speaker system with wireless subwoofer and 3D pass through, model SC-HTB520 which neatly mounts on a wall by a TV and offers an easy to install, stylish alternative to a home theater sound system. The SC-HTB520 supports Stream Out for 3D image signals and Audio Return Channel, making it easy to configure a FULL HD 3D home theater system by combining it with a 3D Blu-ray Disc player and 3D VIERA TV. The SC-HTB520 ideally matches large panel displays 42-inches and above and includes a separate, wireless Down Firing subwoofer.
The front of the SC-HTB520 features a black stainless mesh material with a luxurious mirror finish and a special coating that resists dust and fingerprints. A unique design concept boosts the ambience of the SC-HTB520's high-quality sounds by making the speaker units partially visible through the mesh, so listeners can almost visualize the sound.
The SC-HTB520 system delivers dialog that is crisp and clear. This is made possible by the Clear-Mode Dialog, which makes the sound seem like it is coming from the center of the TV display. With more precise linking of the picture and the sound, the result is clean, pure sound for dialog voices on video and vocals on music. Virtual surround technology also reproduces surround sounds from the front speakers that seem to wrap around the listening position. And dynamic, deep bass sounds are achieved by the Down Firing Subwoofer. The subwoofer is equipped with a wireless system, so there is no need to connect it to the main unit by cables. Lack of wiring keeps the room interior uncluttered and enables a simple and flexible layout.
Connection and installation could not be easier, thanks to the system's compatibility with ARC* (Audio Return Channel), which allows receiving audio signals from the TV. Simply place it by the television or wall mount for a custom installation (via supplied wall mounts) and connect it with just one HDMI cable.
The SC-HTB520 will be available in April 2011 for $399.99.
* An ARC-compatible TV is required.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
