Panasonic PT-LB3U Micro-Portable LCD Projector
Panasonic today announced the PT-LB3U, a lightweight micro-portable projector featuring a resolution of 1,024 x 768 pixels and up to 3,200 lumens of brightness. With its compact size and ease of use, the PT-LB3U is ideal for multiple environments, including education and corporate settings.
The PT-LB3U projector includes a number of advanced technologies, including a proprietary new lamp drive system. This technology increases lamp performance and gives the projector a lamp cycle of up to 5,000 hours. The Intelligent Power Management function controls the power supply, allowing the projector to handle sudden power fluctuations. This enables the PT-LB3U to continue running smoothly despite momentary power outages.
Additionally, the PT-LB3U comes with Panasonic's Daylight View Basic technology, enabling the projector to produce clear, easy-to-see images even in well-lit rooms. With a built-in sensor, the projector can measure ambient light and adjusts the halftone color and brightness level according to surrounding illuminations.
Panasonic's PT-LB3U projector is also designed with ease of use and simplified maintenance in mind. The projector has a wired LAN network terminal input that, when connected to a computer, enables users to remotely operate and check the status of projector(s). The LAN function can also send out an email notification when it is time to replace the lamp, reducing the need for service checks from the IT department. Replacing lamps and filters is also a simple process, as the PT-LB3U projector lamp and air filter are easily accessible. The lamp is located on the top-panel and the air filter is conveniently located on the side panel.
Panasonic strives to minimize impact on the environment and the PT-LB3U has been designed to reduce power consumption. When in Eco Standby mode, the power consumption is only at 0.3W, which reduces operating costs. This new projector also includes Panasonic's Direct Power Off feature, which has a built-in capacitor and provides continuous power to cool the internal components, even after the projector has been turned off and put away. This allows users to turn off the main power as soon as the presentation is over. Not only does this provide a quieter environment, it also prevents damage to the bulb from insufficient lamp cooling.
PT-LB3U Specifications:
  • Model: PT-LB3U
  • Lumens: 3,200
  • Aspect Ratio: 4:3
  • Contrast: 600:1
  • Resolution: 1,024 x 768 pixels
  • Lamp: 220 W UHM
  • Lens: Manual zoom (1:1-1:1.2), manual focus F 1.64-1.87, f 18.80-22.56mm
  • Weight: Approximately 5.07lbs
  • MSRP: $1,399.00 (available now)
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
HDTV 4K & 8K TV
North American videophiles are out of luck again when it comes to Panasonic's OLED, Mini-LED, and LED TVs for 2023. Japanese, European, and Middle...
Headphones
Qatar Airlines will be the first to offer in-flight spatial audio, but will passengers flock to it?
HDTV 4K & 8K TV
2023 European energy regulations have put the future of 8K TVs (and some 4K TVs) in jeopardy due to their high power consumption.
HDTV 4K & 8K TV
Despite its reputation for making excellent TVs, Panasonic has retreated from several TV markets over the past several years, including the U.S. Now it...
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use...
Panasonic today announced four new sleek, compact stereo systems, two of which play Internet radio and boast a remarkable Bluetooth function and Bluetooth Re-Master...
HDTV 4K & 8K TV
For 2011 Panasonic introduced three VIERA Full HD 3D Plasma model lines, the VT30 series, GT30 and ST30 series. Panasonic's Full HD 3D televisions...
