Panasonic PT-AE7000U 3D HD LCD Projector
Panasonic announced their first Full HD 3D home theater LCD projector with 1080p (1920×1080 pixel) resolution, model PT-AE7000U. Panasonic says it is the world's first 3D projector to use transparent LCD panels driven at 480Hz that minimize crosstalk for an immersive 3D viewing experience at home.
The newly-developed optical system of the PT-AE7000U features a new 200-Watt Red-Rich Lamp and new LCD panels with larger aperture ratio for increased red luminance and brightness output. The combination of fully-optimized Pure Contrast Plates, Pure Color Filter Pro and Dynamic Iris Pro has resulted in a 300,000:1 contrast ratio and 2,000 lumens of brightness. This produces brighter images with excellent coloring and deep blacks with fine shadow details.
The PT-AE7000U uses frame sequential technology for 3D image projection. The Overdrive Technology has been carefully tuned together with the 480Hz LCD Panel that greatly reduces 3D crosstalk, or double images, for comfortable 3D content viewing. The projector is also equipped with a newly-developed dual-core processing engine so that the projector can process 3D signals with all of the benefits of 2D image enhancements. Frame Creation, Detail Clarity Processor and other innovative image processing technologies are optimized for 3D images in the same manner as for 2D images. They bring out fine details and three dimensionality for natural, life-like visuals with excellent clarity, and create sharp, clear images of fast-moving scenes in sports and action movies.
Comfortable 3D viewing can also be adjusted with the 3D Viewing Monitor and the 3D Picture Balance features. Because the 3D effect changes with varying screen sizes, the 3D Viewing Monitor ensures that the viewer's stereoscopic effect is within the safety zone set forth by the 3D Consortium Committee. The left and right eye images can be displayed side by side on the PT-AE7000U with the individual Waveform Monitor to adjust 3D picture balance.
Other 3D features include 2D-3D Conversion, which converts 2D content into 3D images for 3D projection with five different 3D effect modes.
The projector is equipped with a built-in 3D IR transmitter that lets the user enjoy large-screen 3D images with optional eyewear, which is sold separately. The models, TY-EW3D10U, TY-EW3D2LU, TY-EW3D2MU and TY-EW3D2SU, also used for the Panasonic VIERA 3DTV, are convenient for those looking to enjoy 3D content on both their Panasonic TVs and projectors. An optional IR transmitter (ET-TRM110) is available for extended transmission distance.
The PT-AE7000U comes rich with features for those looking to customize their home theaters. Many Blu-ray Discs and DVDs come in aspect ratios that are even wider than the projector's 16:9 aspect ratio to match the image size (2.35:1) seen in movie theaters. The projector's Intelligent Lens Memory feature makes it possible for the user to easily program up to six different zoom/focus positions. Automatic switching between 16:9 and 2.35:1 video content is also possible thanks to the signal aspect detection capability on the PT-AE7000U.
More theater automation, such as lighting and a motorized screen, is possible with the PT-AE7000U because it comes equipped with two programmable 12-volt trigger terminals and VIERA Link. VIERA Link provides seamless operation of multiple VIERA Link compatible Panasonic devices by using the PT-AE7000U remote control with backlit buttons.
The PT-AE7000U is also equipped with three HDMI inputs (supporting x.v.Color and Deep Color), so multiple HD sources can be connected without an HDMI switcher. Initial setup and installation are quick and easy, because the 2x zoom can cast a 120-inch diagonal image from as close as 3.6 meters (about 11 feet) to 7 meters (24 feet) from the screen. The projector's lens shift capability enables 100 percent vertical adjustment and 26 percent horizontal adjustment, so the user can suspend the projector either close to the ceiling or mount it to a wall.
The new PT-AE7000U is also an eco-conscious product. Its intelligent power management system reduces the lamp power to the exact required level of brightness depending on the content being displayed. Advanced Panasonic digital circuitry intelligently determines the necessary power output by analyzing more than 3 billion different image patterns. This advanced analysis process reduces the main power consumption by as much as 10 percent when the Dynamic Iris function is operating, thus saving energy.
Other ecological considerations include an off-timer that reduces wasteful power consumption, an extremely low standby power consumption of 0.08 watts, and a 4,000 hour (normal mode)/5,000 hour (eco mode) lamp life.
Price and Availability
The Panasonic PT-AE7000U Full HD 3D home theater projector is made in Japan and will be available in September 2011 for $3,499.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
HDTV 4K & 8K TV
North American videophiles are out of luck again when it comes to Panasonic's OLED, Mini-LED, and LED TVs for 2023. Japanese, European, and Middle...
Headphones
Qatar Airlines will be the first to offer in-flight spatial audio, but will passengers flock to it?
HDTV 4K & 8K TV
2023 European energy regulations have put the future of 8K TVs (and some 4K TVs) in jeopardy due to their high power consumption.
HDTV 4K & 8K TV
Despite its reputation for making excellent TVs, Panasonic has retreated from several TV markets over the past several years, including the U.S. Now it...
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use...
Panasonic today announced four new sleek, compact stereo systems, two of which play Internet radio and boast a remarkable Bluetooth function and Bluetooth Re-Master...
HDTV 4K & 8K TV
For 2011 Panasonic introduced three VIERA Full HD 3D Plasma model lines, the VT30 series, GT30 and ST30 series. Panasonic's Full HD 3D televisions...
