Mirrorless Cameras
Panasonic LUMIX G9 Digital Camera Shoots 80-megapixels
Panasonic announced their flagship mirrorless digital camera for 2018, the LUMIX G9. The $1700 interchangeable lens camera shoots 20 fps (AFC) / 60 fps (AFS) at 20.3-megapixel full resolution or 4K/60p videos. In addition there’s a high resolution mode that provides 80-megapixel (10368 x 7776) equivalent images in JPEG/RAW formats in-camera. That’s made possible by synthesizing 8 consecutively shot images while shifting the sensor. Such capabilities are ideal for landscape and product photography using a tripod.
Evolving from the DMC-GH5‘s high performance, the LUMIX G9 achieves Panasonic’s highest-ever image quality in photo shooting by elevating resolution, gradation and color reproduction with its 20.3-megapixel Digital Live MOS Sensor without a low-pass filter.
The Body I.S. (Image Stabilizer) in the LUMIX G9 is dramatically improved, making it possible to use 6.5 stops of compensation with or without Dual I.S.2.0 compatible Lumix lenses. This is achieved by a more accurate calculation of shake in various shooting conditions, utilizing information of angular velocity and motion vector acquired not only from the gyro sensor but also from the image sensor and accelerometer sensor. The high-speed, high-precision AF with DFD technology offers ultra fast AF speed of 0.04 sec.
Thanks to the high processing performance of the Venus Engine 10, the LUMIX G9 incorporates Deep Learning technology that detects a human body in addition to the conventional face and eye detection. The AF Point Scope function is also new on the LUMIX G9. It magnifies subjects that are far away to capture them in clear focus.
For more precise focusing, the focus areas are increased from 49 to 225-areas in addition to the conventional Face/Eye Recognition, Tracking AF, 1-area AF and Pinpoint AF. Users can make a group of 225 focus areas and move or change the size of it as they like according to the composition. All focusing operations are easily controlled with the newly adopted joystick located on the thumb position without taking the eyes off of the subject even when using an LVF or releasing the finger from the shutter button. The LUMIX G9 is equipped with AF Custom Settings with which users can set AF Sensitivity, AF Area Switching Sensitivity and Moving Object Prediction Level. Four patterns of presets are also available for frequently used situations.
The LUMIX G9 has a massive, super high-resolution 3,680k-dot OLED Live View Finder (LVF) with a high magnification ratio of approx. 1.66x / 0.83x (35mm camera equivalent). No blackouts occur even in high-speed burst shooting. Visibility is improved for framing subjects under direct sunlight. With Panasonic’s highest-level 0.83x magnification to date and a long 21mm eye point distance, it is excellent for people who wear glasses.
To withstand heavy field use, the LUMIX G9 is composed of a magnesium alloy full die-cast front / rear frame and is not only splash-proof and dust-proof but also freeze proof down to -10 degrees centigrade. The largest-in-class Status LCD on the top of the camera makes shooting even easier and more comfortable. For the rear monitor, a 3.0-inch free-angle LCD in 3:2 aspect ratio with 1,040K-dot high resolution is equipped. The G9 has a double SD Memory Card slot, compatible with the high-speed, high-capacity UHS-II.
The LUMIX G9 includes Bluetooth and Wi-Fi connectivity to offer a more flexible shooting experience and instant image sharing with easy operation. Compatibility with Bluetooth 4.2 (called BLE: Bluetooth Low Energy) enables constant connection with a smartphone or tablet with minimum power consumption. For Wi-Fi, 5GHz (IEEE802.11ac) can be selected in addition to the conventional 2.4GHz (IEEE 802.11b/g/n) for an even more secure and stable connection.
The Fn lever makes it possible to change the setting quickly once frequently-used settings are assigned. The LUMIX G9 also comes with a joystick at the optimal position to achieve intuitive focus area control without taking the eyes off of the viewfinder, together with a focus lever and AF mode button. Dials on the grip and Fn buttons are also located in the best position to operate unseen.
The LUMIX G9 enables not only power charging but also power feeding via USB, which enhances extended shooting time.
Price and Availability
The Panasonic LUMIX G9 (body only, model DC-G9KBODY) MSRP will be available January 2018 for $1699.99, along with all accessories.
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
HDTV 4K & 8K TV
North American videophiles are out of luck again when it comes to Panasonic's OLED, Mini-LED, and LED TVs for 2023. Japanese, European, and Middle...
Headphones
Qatar Airlines will be the first to offer in-flight spatial audio, but will passengers flock to it?
HDTV 4K & 8K TV
2023 European energy regulations have put the future of 8K TVs (and some 4K TVs) in jeopardy due to their high power consumption.
HDTV 4K & 8K TV
Despite its reputation for making excellent TVs, Panasonic has retreated from several TV markets over the past several years, including the U.S. Now it...
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use...
Panasonic today announced four new sleek, compact stereo systems, two of which play Internet radio and boast a remarkable Bluetooth function and Bluetooth Re-Master...
HDTV 4K & 8K TV
For 2011 Panasonic introduced three VIERA Full HD 3D Plasma model lines, the VT30 series, GT30 and ST30 series. Panasonic's Full HD 3D televisions...
