Camera Lenses
Panasonic LUMIX G X Powered Tele-zoom Lens
Panasonic today announced their first digital interchangeable lens with power tele-zoom lens compatible with LUMIX G Series Micro Four Thirds digital cameras. The LUMIX G X VARIO PZ 45-175mm/F4.0-5.6 ASPH./POWER O.I.S. (H-PS45175) lens features superb image rendering for lifelike textures and crisp, edge-to-edge contrast. A unique Nano Surface Coating technology minimizes reflections at entire visual light range (380nm-780nm) for a dramatic reduction of ghosts and light flare, resulting in outstandingly clear picture quality.
Using a Multi-Actuator Floating Inner Focus System to control three lens groups separately the LUMIX G X VARIO PZ 45-175mm/F4.0-5.6 ASPH./POWER O.I.S. achieves a reduction in both size and weight without compromising picture quality. Boasting outstanding compactness, the lens is approximately 90mm in length and 7.4oz in weight, resulting in ultra-high mobility.
Offering a versatile zoom range of 45-175mm the LUMIX G X VARIO PZ 45-175mm/F4.0-5.6 ASPH./POWER O.I.S. allows distant subjects to be captured sharply at the tele-end. Also notable, the lens is extremely suitable for portrait and landscape shots, as its high contrast and resolution helps images shot at the wide end maintain exceptional quality, and the zoom lever allows for quick and stable zooming, even while shooting a moving object.
The new lens system features two Extra-low Dispersion (ED) lenses which suppress chromatic aberration and contribute to high descriptive performance across the entire zoom range 45-175mm. The POWER O.I.S. (Optical Image Stabilizer) integrated into the LUMIX G X VARIO PZ 45-175mm/F4.0-5.6 ASPH./POWER O.I.S. makes it easy to shoot sharp images even in low-lit situations. With improved sensitivity of the gyro sensor, the new POWER O.I.S. also suppresses large, slow movements two times more effectively** while small, fast movements are compensated for by the conventional MEGA O.I.S.
LUMIX G X VARIO PZ 45-175mm/F4.0-5.6 ASPH./POWER O.I.S. contains seven aperture blades to help produce an attractive smoothness in out-of-focus areas even while shooting at large aperture. Adopting an inner focus system driven by a stepping motor, the lens’ superior optical design supports Light Speed AF of approximately .15 seconds and fast aperture control results in a shortened shutter time lag of approximately 20% when compared to the LUMIX G VARIO 45-200mm/F4.0-5.6/MEGA O.I.S.
Price and Availability
The Panasonic LUMIX G X VARIO PZ 45-175mm/F4.0-5.6 ASPH./POWER O.I.S. (H-PS45175) will be available in black and silver starting September 2011 for $449.99.
*DMC-GF3X; and the DMC-GF3, DMC-G3, DMC-GF2 and DMC-GH2 with a firmware upgrade.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
HDTV 4K & 8K TV
North American videophiles are out of luck again when it comes to Panasonic's OLED, Mini-LED, and LED TVs for 2023. Japanese, European, and Middle...
Headphones
Qatar Airlines will be the first to offer in-flight spatial audio, but will passengers flock to it?
HDTV 4K & 8K TV
2023 European energy regulations have put the future of 8K TVs (and some 4K TVs) in jeopardy due to their high power consumption.
HDTV 4K & 8K TV
Despite its reputation for making excellent TVs, Panasonic has retreated from several TV markets over the past several years, including the U.S. Now it...
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use...
Panasonic today announced four new sleek, compact stereo systems, two of which play Internet radio and boast a remarkable Bluetooth function and Bluetooth Re-Master...
HDTV 4K & 8K TV
For 2011 Panasonic introduced three VIERA Full HD 3D Plasma model lines, the VT30 series, GT30 and ST30 series. Panasonic's Full HD 3D televisions...
