Camera Lenses
Panasonic Lumix G VARIO 100-300mm / F4.0-5.6 / MEGA O.I.S. Lens
Panasonic today announced LUMIX G VARIO 100-300mm / F4.0-5.6 / MEGA O.I.S. (H-FS100300) interchangeable lens for its LUMIX G Series of cameras. The lens is based on the Micro Four Thirds System standard and compatible with Panasonic's DSLM cameras, such as the newly-announced LUMIX DMC-GH2.
The new handheld telephoto zoom lens can photograph ultra-telephoto zoom shots at 300mm (35 mm camera equivalent: 600 mm), but is light enough to carry easily for everyday distance shooting, like sporting events. Because of its compact size, photographers can achieve a high compression effect in distance photography without any need for a heavy tripod. Panasonic's MEGA Optical Image Stabilizer (O.I.S.) suppresses blur by compensating for hand shaking that can severely affect zoom shots.
The telephoto zoom lens combines 17 elements in 12 groups including an ED lens. By incorporating the ED lens in the first lens group, the chromatic aberration is suppressed to render sharp, high contrast images with stable optical performance over the entire zoom range. The integration of a stepping motor with an exclusive zoom tracking control system and inner focus drive system create a quiet, accurate and high speed contrast AF.
The new LUMIX G VARIO 100-300mm / F4.0-5.6 / MEGA O.I.S. (H-FS100300) includes seven blades to give the aperture a rounded shape. This rounded aperture produces an attractively smooth effect in out-of-focus areas when shooting at larger aperture settings. A strong metal mount is durable for heavy use, and multi-coated lens elements minimize ghosts and flare.
MSRP: LUMIX G VARIO 100-300mm / F4.0-5.6 / MEGA O.I.S. (H-FS100300): $599.95
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
