Camera Lenses
Panasonic Lumix G 12.5mm / F12 3D Lens
World's First Interchangeable 3D Lens
Panasonic today announced the world's first interchangeable 3D lens, the LUMIX G 12.5mm / F12 (H-FT012) for the Micro Four Thirds System cameras. The 3D lens features two optical systems installed within the diameter of the lens mount, creating stereo images from the left and right lenses that are then processed with a 3D image processing system. Panasonic's advanced technologies in optical technology, image processing systems, and lens barrel design, allow the 3D lens to be compact.
Previously, 3D shooting with an interchangeable lens system camera was possible only by using panorama systems or by combining two lenses and two CCDs. However, these systems are not ideal and have difficulty capturing moving objects. Panasonic's new 3D-capable interchangeable lens allows instant 3D shooting (35 mm camera equivalent: 65 mm, without time lag between left and right images — even when shooting objects in motion. As part of Panasonic's 3D ecosystem of 3D-capable VIERA® televisions and Blu-ray 3D Disc Players, the 3D images taken with this lens — even close-up shots — are easily viewed on Panasonic's 3D VIERA televisions.
MSRP: LUMIX G 12.5mm / F12 (H-FT012): $249.95 (Available Fall 2010)
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
