Camera Lenses
Panasonic LEICA DG SUMMILUX 15mm / F1.7 ASPH Lens
Panasonic just announced the LEICA DG SUMMILUX 15mm / F1.7 ASPH. high speed prime wide-angle lens for the Micro Four Thirds format (35mm camera equivalent: 30mm), which offers beautiful defocus features, while being very compact and lightweight.
The new $600 lens system is comprised of nine elements in seven groups and uses three aspherical lenses. The aspherical lenses suppress spherical aberration and distortion effectively while realizing downsizing of the lens unit. Panasonic’s Nano Surface Coating technology is adopted to minimize the reflection at entire visual light range (380nm-780nm) by applying the extra-low refractive index coating with nano-sized structure on the surface of the lens. It results in a super clear picture with a dramatic reduction of ghost and flare. The lens incorporates a superior inner focus system, which enables excellent resolution and contrast from close-up to infinity. The inclusion of a newly developed stepping motor makes the focusing action smooth and silent for use in both photo and video recording. Notably the performance of Auto Focus (AF) is by far superior to the phase-difference AF when a fast lens with smaller aperture value is used. It is also compatible with the sensor drive at max.240 fps to take maximum advantage of cameras with high-speed AF when mounted on the cameras of LUMIX G system.
The LEICA DG SUMMILUX 15mm / F1.7 ASPH. comes equipped with aperture ring and AF/MF switch for direct, intuitive operation. The sophisticated metal design of SUMMILUX 15mm / F1.7 ASPH., including the hood, deserves to bear the prestigious LEICA name. Highly reliable metal mount is durable enough for repeated exchange of lens.
Price and Availability
The Panasonic LEICA DG SUMMILUX 15mm / F1.7 ASPH lens will be available May 2014 in black for $599.99.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
HDTV 4K & 8K TV
North American videophiles are out of luck again when it comes to Panasonic's OLED, Mini-LED, and LED TVs for 2023. Japanese, European, and Middle...
Headphones
Qatar Airlines will be the first to offer in-flight spatial audio, but will passengers flock to it?
HDTV 4K & 8K TV
2023 European energy regulations have put the future of 8K TVs (and some 4K TVs) in jeopardy due to their high power consumption.
HDTV 4K & 8K TV
Despite its reputation for making excellent TVs, Panasonic has retreated from several TV markets over the past several years, including the U.S. Now it...
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use...
Panasonic today announced four new sleek, compact stereo systems, two of which play Internet radio and boast a remarkable Bluetooth function and Bluetooth Re-Master...
HDTV 4K & 8K TV
For 2011 Panasonic introduced three VIERA Full HD 3D Plasma model lines, the VT30 series, GT30 and ST30 series. Panasonic's Full HD 3D televisions...
