Panasonic HX-A1 Wearable POV Action Cam
Panasonic HX-A1 Wearable POV Action-cam
Panasonic announced the HX-A1 (A1) wearable, ultra-compact, 1080p POV action camcorder that is lightweight at 1.6 ounces (45 grams) and can shoot in total darkness. Using an infrared (IR) light source (commercially-available) and an IR filter for night mode (included in packaging), you can capture video in caves with no light or nocturnal wildlife at night.
The 3.54-megapixel action cam shoots 1080p Full HD with crystal-clear AAC sound. The high-end, super-tough Panasonic 2.6mm, F2.8 lens easily withstands the elements to capture everything. And a super-compact 1/3-inch MOS image sensor makes shooting in low-light a snap. For fast-moving scenes, the camera can record slow motion at 1280×720 @ 60 fps (double the normal frame rate), or at 848×480 @ 120 fps (quadruple-speed).
The A1’s rugged structure keeps water and dust out and protects against impact and cold temperatures. Uniquely shaped, the cylindrical camera can be attached in numerous positions to suit a variety of shooting opportunities. You can also use the A1 as a computer webcam when connected via USB.
While recording, footage on the A1 you can send video to a sub-window on the Panasonic camcorder (W970 and W870) via Wi-Fi. It is combined with the main picture shot by the camcorder, allowing you to merge two simultaneously recorded videos into one. With this feature, you can combine multiple subjects in one video or combine the same subject viewed from different angles, giving you more possibilities for shooting in various situations.
Features
  • Built-in Wi-Fi
  • 0 Lux Night Mode Enables You to Capture in Total Darkness
  • Waterproof down to 5 ft (1.5 m) without a housing case (IPX8 compliant)
  • Shockproof up to 5 ft (1.5 m) (MIL-STD 810F Method 516.5-Shock compliant)
  • Dustproof (IP6X compliant)
  • Freeze-proof to 14 degrees F( -10 degrees C)
  • Multi Mount(VW-MKA1) – Attaches to goggles, shoulder bags or helmets
  • Tripod Mount (VW-CTA1) – Secures the camera to a tripod
  • Loop Recording
  • Slow Motion Video
  • Webcam
Optional Accessories
  • Twin Mount (VW-TMA1) – Attaches to the A1 and your light source for shooting in the dark. Also, two A1s can be attached facing in opposite directions to capture the action all around you
  • Extended Battery (VW-BTA1) – Enables approximately 2 hours and 45 minutes of continuous recording (with the A1, at 1920 x 1080 pixel / 30p).
    Lightweight and waterproof without a housing case (IPX8 compliant)
  • Strap Adaptor (VW-SAA1) – Attaches the camera to a strap or carabineer.
  • Head Mount (VW-HMA1) – The camera can be mounted on either side of your head ideal for the casual adventure.
  • Clip Mount (VW-CLA100) – Clips to a cap visor or similar surface.
  • Suction Cup Mount (VW-SCA100) – Attaches to flat surfaces such as a boat deck or surf board.
  • Handlebar Mount (RP-CMC10) – Ideal for mounting A1 to bicycle handlebar.
  • Wind Jammer (VW-WJA100) – Reduces wind noise on the microphone
Price and Availability
The Panasonic HX-A1 will be available June 2015 for $199.99 in black or orange.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
HDTV 4K & 8K TV
North American videophiles are out of luck again when it comes to Panasonic's OLED, Mini-LED, and LED TVs for 2023. Japanese, European, and Middle...
Headphones
Qatar Airlines will be the first to offer in-flight spatial audio, but will passengers flock to it?
HDTV 4K & 8K TV
2023 European energy regulations have put the future of 8K TVs (and some 4K TVs) in jeopardy due to their high power consumption.
HDTV 4K & 8K TV
Despite its reputation for making excellent TVs, Panasonic has retreated from several TV markets over the past several years, including the U.S. Now it...
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use...
Panasonic today announced four new sleek, compact stereo systems, two of which play Internet radio and boast a remarkable Bluetooth function and Bluetooth Re-Master...
HDTV 4K & 8K TV
For 2011 Panasonic introduced three VIERA Full HD 3D Plasma model lines, the VT30 series, GT30 and ST30 series. Panasonic's Full HD 3D televisions...
