Camcorders
Panasonic HDC-SDT750 3D Camcorder
PANASONIC FIRST 3D CONSUMER CAMCORDER
Panasonic today announced the Panasonic HDC-SDT750, the world's first consumer 3D camcorder, which includes a 3D conversion lens1 that enables the camcorder to shoot powerful and true-to-life 3D video content. The Panasonic SDT750 is a user-friendly consumer 3D camcorder that makes experiencing 3D at home easy and affordable2. In addition to shooting 3D, the SDT750 can record full 1080p High Definition (HD) in AVCHD, when the 3D conversion lens is unattached, and includes powerful features such as a 3MOS system, a Leica Dicomar lens and a 12x optical zoom.
To shoot 3D video with the Panasonic HDC-SDT750 camcorder, the user needs to attach the 3D conversion lens that comes included, to record dynamic images. The specially-designed 3D conversion lens records right-eye and left-eye images simultaneously through its two lenses, thus resulting in video that can be viewed in 3D. The right and left images (each with 960 x 1080 pixels) that enter through the lenses are recorded using the side-by-side method.
The Panasonic SDT750 features a Time Lapse Recording feature, which plays a scene such as a sunset or a blooming flower at an accelerated speed, similar to a fast-forward. By setting the recording interval to 1 second, 10 seconds, 30 seconds, 1 minute or 2 minutes, the user can view an otherwise long recording in a reduced time period. For example, when a scene is recorded at the 1-second interval setting, a 10-minute sunset scene can be played back in approximately 10 seconds, making the slow change in the subject appear as if it were taking place in a very short time. This interval recording feature is also available when the 3D conversion lens is attached to the SDT750.
Panasonic 3D Camcorder Conversion Lens
Panasonic offers a 5.1-channel audio recording sound system that uses five microphones, so when voices are recorded from the front, right, left and back are played on a 5.1-channel home cinema system, users are surrounded by clear, detailed sound that makes them feel as if they are right in the middle of the action. The Focus Microphone function, which has been made possible by five highly-directional microphones, picks up the sounds from sources in the area in front of the camcorder, regardless of whether the lens is focusing on a near or distant object. It also allows footage recorded in 3D to be enjoyed with lifelike and dynamic sounds.
The high-sensitivity 3MOS System has 7.59 million effective motion image pixels (2.53 megapixels x 3), so this advanced image sensor separates the light received through the lens into the three primary colors — red, green and blue — and processes each color independently. As a result, the Panasonic SDT750 produces beautiful images with rich color quality, detail and gradation. Adding to the quality, the SDT750 also features a large-diameter (46mm) F1.53 Leica Dicomar lens and Crystal Engine PRO, a high-speed processing unit — both components which contribute to the effectiveness of the camcorder's light gathering, increased sensitivity, and reduced noise when shooting, even in dim lighting.
Users can play back 3D videos recorded on the Panasonic HDC-SDT750 on 3D-capable televisions, such as Panasonic VIERA® Full HD 3D televisions, including the TC-P50VT25, TC-P54VT25, TC-P58VT25, TC-P65VT25 and the TC-P50VT20 models. Playback using a VIERA TV is done by connecting the 3D camcorder to the television using an HDMI cable. In addition, it is also possible to play 3D images recorded on SD Memory Cards by using an AVCHD compatible player,4 such as a Panasonic 3D Blu-ray Disc player — the DMP-BDT350 or DMP-BDT300 models are currently available. When watching 3D content recorded by the SDT750 on any of the Panasonic Full HD 3D VIERA televisions, users can view the true-to-life content and the VIERA television will automatically engage the side-by-side method for smooth viewing of 3D content — no change of settings necessary.
The SDT750 comes with HD Writer AE 2.6T PC editing software, which allows users to easily edit recorded 3D images, and save them onto PCs or Blu-ray/DVD discs. HD Writer AE 2.6T features a “Smart Wizard” that starts as soon as the SDT750 is connected to the USB port of the computer, which gives simple on-screen guidance. HD Writer AE 2.6T also enables easy uploading and sharing online without the need for any cumbersome processes, so that even an inexperienced user can post video clips on the web. When uploading 3D images from a PC onto the web, they must first be converted into 2D images.
Panasonic HDC-SDT750 Camcorder
Even without the 3D conversion lens attached, the Panasonic SDT750 is an innovative and high-performance Full HD camcorder that is equipped with a wide range of sophisticated functions, including the 3MOS System, which features improved noise reduction (NR) technologies, and a wide-variety of manual adjustments controlled by a manual ring for easy, creative shooting. The manual ring provides convenient, fingertip control of the focus, zoom, exposure (iris), shutter speed and white balance settings. Using the ring is extremely intuitive, comfortable, and user-friendly. Only the white balance setting is available when the 3D conversion lens is attached. The SDT750 can shoot 1,080/60p recording (Full-HD 1,920 x 1,080, 60 progressive recording) and produces rich expressive images, with no detail loss and flickering.
Panasonic's Intelligent Auto (iA) function makes the SDT750 extremely easy to use. When the 3D lens is not attached and iA is engaged, the SDT750 automatically selects the most suitable shooting mode with the press of a button. While shooting HD video, the Panasonic SDT750's iA function offers the following six functions: Face Recognition, the new HYBRID O.I.S., AF/AE Tracking, Intelligent Scene Selector, Face Detection and Intelligent Contrast Control. HYBRID O.I.S., a new feature, provides extremely accurate hand-shake correction with its four-axis blur detection, resulting in steady images while zooming or shooting on the move.
Other features of the Panasonic HDC-SDT750 include:
  • Auto Power LCD automatically adjusts the brightness of the screen according to the shooting environment for comfortable use in a variety of different lighting situations.
  • Large 3.0″ touch-screen LCD allows icons to be easily operated by touching them with a fingertip. On the LCD, recorded 3D images are displayed only as the 2D images that were recorded with the left lens.
  • Eco Mode automatically turns off the power when the camcorder is not operated for five minutes, reducing wasteful energy use and saving battery power.
  • Pre-Rec allows for the camcorder to continuously record three seconds of content into internal memory. Then, when the record button is pressed, the three seconds immediately prior will have been recorded.
The Panasonic HDC-SDT750 will be available in October 2010 with a suggested retail price of $1,399.95.
“As a result of research conducted through Panasonic Hollywood Laboratory, Panasonic developed a professional 3D system camera and successfully brought high-quality Full HD 3D images to the home for viewing on Panasonic VIERA Full HD 3D televisions. But now, Panasonic has taken it one step further and developed the world's first consumer 3D camcorder, the HDC-SDT750 — creating a 3D ecosystem available for consumers in the home. Incorporating Panasonic's professional broadcast technology and bringing it to an easy-to-use consumer model, the SDT750 makes high-quality 3D video content a reality in the home.”
— Chris Rice, Senior Product Manager, Imaging, Panasonic Consumer Electronics Company
Vertere DG-X Turntable Red
With a precision main bearing, cutting-edge motor drive, and advanced Groove Runner X Tonearm, the DG-X delivers unparalleled sound clarity and resonance elimination. Explore...
Campfire Audio Axion IEM Connected USB-C with Controller Campfire Audio Axion IEM Connected USB-C with Controller
Earbuds & In-Ear Headphones
Offering premium sound quality, USB-C connectivity with a DAC, and seamless integration with iPhones and Android smartphones, the Axion IEMs are Campfire Audio's most...
Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Wattson Audio Madison Power Amplifier Front Wattson Audio Madison Power Amplifier Front
Discover the new Madison Power Amplifier from Wattson Audio — a Swiss-engineered Class A/B amp delivering rich harmonics, ultra-low distortion, and dynamic performance in...
WiiM Voice Remote 2 with components lifestyle WiiM Voice Remote 2 with components lifestyle
With WiiM's continuing quest to improve the music listening experience, the upgraded Voice Remote 2 improves control for WiiM devices.
Sharp TIVO TV Lifestyle Man View Sharp TIVO TV Lifestyle Man View
HDTV 4K & 8K TV
Would you buy a 55-inch Sharp 4K TV with built-in TiVo for $299.99? Let's take a look at what it offers.
