Camcorders
Panasonic HC-X900M HD 3D Camcorder
Panasonic announced their top-of-the-line full-High Definition (HD) HC-X900M camcorder, which can record 1920 x 1080, 60 progressive, and builds on the success of last year’s HDC-HS900 by adding the new 3MOS System Pro to help achieve dramatic increases in performance thanks to a re-engineering of all the core imaging components: the lens, sensor and engine. Panasonic’s 3MOS System Pro is a next-generation imaging system that powers the HC-X900M to produce bright, outstanding video even under dim lighting, while also minimizing noise. Plus, with professional-like features such as a manual ring, a 5.1-channel surround sound, an advanced Optical Image Stabilization (O.I.S) system called Hybrid O.I.S. +, the HC-X900M is a feature-rich camcorder with endless capabilities.
The HC-X900M can also shoot full-HD 3D (in the AVCHD 3D format) with the new optional conversion 3D lens, the VW-CLT2, which is smaller than last year’s model (VW-CLT1) and has an increased brightness from F3.2 to F2.0. In addition, the new VW-CLT2 has 1.5x digital zooming.
Panasonic has shifted the green MOS sensor of the red, green and blue MOS sensors by half a pixel, thus helping to achieve more life-like colors, detail and gradation. Thanks to the advanced 3MOS sensor’s unique pixel shift technology that runs at high speed and with superb accuracy, the HC-X900M further reduces noise by 40% when compared to last year’s HDC-HS900/TM900. The HC-X900M’s new Crystal Engine Pro II can achieve high-speed processing that is approximately equivalent to four times the pixel count of full-HD pixels, thus producing superb full-HD image quality, even in the most detailed images.
The HC-X900M features a bright F1.5, 12x optical zoom and 29.8mm wide-angle LEICA DICOMAR lens, meaning it allows for a wider-framed shot, which is convenient when shooting wide landscapes and large groups of people. The lens also features a new Nano Surface Coating Technology, which dramatically reduces ghosting and flaring. With an Octagon Iris Diaphragm, the user can apply a defocusing effect, so it is possible to shoot at a close distance from the subject while fitting both the subject and the surrounding area into the frame. This is beneficial so the voice of the subject is clearly recorded, but a full and wide frame is captured.
The HC-X900M features an improved O.I.S. system called, HYBRID O.I.S. +, which uses five-axis correction to help thoroughly suppress blurring all the way from wide-angle shots to powerful zoom shots — allowing for steady images over the entire zoom range. It even achieves superb effects when shooting while walking or otherwise moving, thanks to a function known as Active Mode. This lets the user capture crisp, clear images, without blurring, in nearly every shooting situation. In addition to the HYBRID O.I.S. + system, the HC-X900M provides even more powerful stabilization correction with O.I.S. Lock. By pressing the O.I.S. Lock button on the LCD monitor, the blur detection sensitivity is maximized and camera movements are detected and corrected without image degradation. O.I.S. Lock is ideal for applications like bird watching, which call for zooming at a fixed angle.
The Panasonic HC-HX900M features a manual ring for easy and convenient fingertip-control of commonly-used settings, like focus, zoom, exposure, shutter speed and white balance. Using the ring is now much more intuitive, comfortable, and user-friendly for settings that are often adjusted as opposed to accessing through the menu screen every time one of those features need to be changed. Plus, with manual operation, the HC-HX900M gives the user freedom to craft creative and expressive videos with ease. For those beginner users looking for a more intuitive setting, the HC-X900M also includes the iA function which automatically selects the most suitable shooting mode. Panasonic’s iA consists of six functions: Face Recognition, the new HYBRID O.I.S. +, AF/AE Tracking, Intelligent Scene Selector, Face Detection and Intelligent Contrast Control.
When the HC-X900M has the optional VW-CLT2 3D Conversion Lens (check price) attached, it can record full HD 3D images with the MVC (Multiview Video Coding) recording system of the AVCHD 3D format. During 3D recording, the right-eye and left-eye images are both recorded and played in Full-HD quality, using the Frame Sequential Method to produce FULL HD 3D images, which results in a lifelike ambience. The HC-X900M is equipped with a 1,150,000-dot 8.8-cm/3.5-inch LCD that allows 3D viewing without the need for special eyewear, so 3D images can be viewed on the spot. Naturally, the display can also be switched between 2D and 3D. And intuitive touch operation enables extremely easy control on the LCD. The Touch Zoom function allows the user to simply touch the LCD to activate slow zooming. The LCD also supports Touch Shutter, which automatically focuses and takes a still photo when the user touches the subject on the screen.
“Panasonic has really improved the core components of the HC-X900M, from its lens to its processor to its engine to ensure that it can power full 1080/60p at a 28-Mbps bit rate, thus resulting in absolutely stunning video, but also capturing rich deep sound,” said Chris Rice, Senior Product Manager, Imaging, Panasonic Consumer Marketing Company of North America.
Other features of the Panasonic HC-X900M include:
  • 32GB of built-in memory, plus an SD Memory Card slot that supports SD/SDHC/SDXC Memory Cards.
  • The Zoom Mic function links the microphone’s capability to the camera’s zoom action and helps to reduce surrounding noise. The HC-X900M with a 5.1-channel surround sound, noise is reduced by -20 dB while zooming.
  • The Wind Noise Canceller automatically detects and suppresses only the wind noise to ensure natural sounds with lifelike ambience, thus recording human voices clearly even on a windy beach or elevated location.
  • Pre-Rec function, when turned on, allows the camcorder to continuously record three seconds of video to an internal buffer memory, thus helping to capture sudden shooting opportunities. Provided that the camcorder is aimed at the subject in advance, the HC-X900M can actually record three seconds prior to pushing the record button.
  • Eco mode automatically turns off the power when the camcorder is not operated for five minutes, reducing wasteful energy use and saving battery power.
Price and Availability
The Panasonic HC-X900M will be available spring 2012 for $1,199.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
HDTV 4K & 8K TV
North American videophiles are out of luck again when it comes to Panasonic's OLED, Mini-LED, and LED TVs for 2023. Japanese, European, and Middle...
Headphones
Qatar Airlines will be the first to offer in-flight spatial audio, but will passengers flock to it?
HDTV 4K & 8K TV
2023 European energy regulations have put the future of 8K TVs (and some 4K TVs) in jeopardy due to their high power consumption.
HDTV 4K & 8K TV
Despite its reputation for making excellent TVs, Panasonic has retreated from several TV markets over the past several years, including the U.S. Now it...
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use...
Panasonic today announced four new sleek, compact stereo systems, two of which play Internet radio and boast a remarkable Bluetooth function and Bluetooth Re-Master...
HDTV 4K & 8K TV
For 2011 Panasonic introduced three VIERA Full HD 3D Plasma model lines, the VT30 series, GT30 and ST30 series. Panasonic's Full HD 3D televisions...
