Mirrorless Cameras
Panasonic DMC-GX1 Lumix Micro Four Thirds Digital Camera
Panasonic announced the LUMIX DMC-GX1 Micro Four Thirds Digital Camera to their interchangeable lens capable LUMIX G Series. The DMC-GX1 features a 16.01-megapixel Live MOS sensor and Venus Engine, helping to ensure real-to-life images through excellent resolution, image rendering and color reproduction. Even in low-light situations and at maximum 12800 high ISO sensitivity, the LUMIX GX1 can produce stunning photos and videos, and because of its compact size it can be easily carried for daily use.
The LUMIX GX1, like all the models in Panasonic’s LUMIX G Series of Compact System Camera (CSC), adopts Contrast AF for its focus system, so focusing is controlled by the image sensor. When compared with the Phase difference system AF, Contrast AF achieves higher accuracy especially when shooting with a bright lens with small F value. For instance, the accuracy of Contrast AF is approximately 90% while Phase difference AF is approximately 60% at F1.4. Additionally, with the precise Contrast AF system, the LUMIX GX1 achieves high resolution through an optimal balance of resolution and noise reduction, thus producing lifelike image rendering and highly precise Auto Exposure and white balance. To further advance the Contrast AF, the LUMIX GX1 incorporates full-area focusing, making it possible to set focus on any point in the field of view. With the LUMIX GX1’s 3.0-inch touch LCD screen, frame composition is intuitive and easy.
The LUMIX GX1 features an ultra high-speed Light Speed AF, which means it can Auto Focus in approximately 0.09 second. This is achieved by reducing the detection time for focusing by the synchronizing the lens and sensor at 120 fps. Plus, the newly-added focus mode AFF (AF Flexible) locks on the focus when the shutter button is half-pressed, however, if the subject moves, the focusing is reset to get the best results. Combined with the Touch AF control, setting and focusing on the subject is incredibly easy and quick.
The touch-control system of the LUMIX GX1 lets users set the focus on the subject by simply touching it on the large, 460,000-dot wide-viewing angle LCD. Users can even release the shutter by touching the screen. Once locked on the subject with a touch, the LUMIX GX1 tracks the subject, even when it moves, using the AF tracking function. With a touch on the screen, users can select the part and the size of the AF area, choosing from 1-area AF, Multi-area AF with 23 AF areas and Pinpoint AF, which allows extremely precise focus setting.
Panasonic DMC-GX1 Lumix Micro Four Thirds Digital Camera - Top
Despite its compact size, the LUMIX GX1 is extremely intuitive to operate, with an optimized layout of control buttons, a mode dial and dedicated function buttons. Users can customize the two external buttons and two menus tabs to settings they most frequently use so they are easily accessible. In addition, a total of four custom setting patterns can be stored to the camera’s model dial — one on ‘C1’ and three on ‘C2.’ Furthermore, the LUMIX GX1 was designed to enhance its ergonomics, with a grip that fits naturally and comfortably in the hand, despite its flat profile and compact design. Plus, the LUMIX GX1 has a more tactile texture and the mode dial is easy to turn and features print that is easy to read and won’t easily wear.
The LUMIX GX1 can record 1920 x 1080 at 60i, with sensor output of 30p, full-High Definition videos in the AVCHD format which excels in both compression efficiency and compatibility with AV equipment for playback. In addition to the practical full-time AF, the Touch AF in video recording also lets users enjoy professional-like rack focusing. Just by pointing at the subject, the focus is shifted so it stands out. With a dedicated video record button on the top, users can instantly start recording videos while shooting photos without any having to make any extra setting adjustments. Along with the full-HD video capabilities, the LUMIX GX1 also features high-quality sound, recorded with Dolby Digital Stereo Creator. Videos can also be recorded in MP4 format for playback on a PC or other portable electronic devices without having to convert the files.
Panasonic DMC-GX1 Lumix Micro Four Thirds Digital Camera - Back
Other features of the new Panasonic LUMIX GX1 compact system camera include:
  • A new Level Gauge, which lets the camera detect the horizontal/vertical angle of view with its internal level working with the sensor. In addition, photos shot in portrait aspect will be automatically displayed vertically, regardless of which lens is used.
  • One Push AE adjusts exposure with a single press of the “Fn” (Function) button when it is over/under exposed, which is especially useful when shooting outdoors with open aperture or indoors with fast shutter speed
  • Dust Reduction System helps to eliminate dust or foreign matter getting inside the LUMIX GX1 when lenses are being changed. By placing a supersonic wave filter in front of the Live MOS sensor that vibrates vertically around 50,000 times per second, the filter repels dust and other particles effectively.
  • Zoom operation can be controlled with touch control when either of Panasonic’s new LUMIX X Power Zoom lenses are attached. And the zoom speed can also be adjusted in two steps for more precise control.
  • Popular iA and iA Plus modes for beginners looking for automatic shooting in both still and video modes.
  • Increased energy consumption and an approximately 11% longer battery life when compared to the LUMIX DMC-G3, which also uses the same battery pack DMW-BLD10.
The LUMIX G Series is a robust system of bodies and lenses, featuring a total of 14 Micro Four Thirds lenses including the new power zoom X lens — standard zoom lens, telephoto zoom lens, single focal length lens, wide-angle lens, fish-eye lens, macro lens, and even a 3D lens — to fit a variety of shooting scenarios and occasions.
Panasonic DMC-GX1 Lumix Micro Four Thirds Digital Camera - Side
The Micro Four Thirds System products are joining today’s Four Thirds System products to provide customers with even higher levels of performance in a digital interchangeable lens camera. In addition to LUMIX G lenses, the LUMIX DMC-GX1 can use any interchangeable lens that complies with the Four Thirds System standard via an optional mount adapter for the unlimited number of lens properties. The LUMIX GX1 system camera offers a wide variety of options to choose from to match every shooting situation and shooting style, including: external flashes, PL filters, ND filters, MC protectors, remote shutter, zoom level, battery packs, AC adaptor, DC coupler, straps, cases, bags and more. Plus, with the LUMIX GX1’s hot shoe on the top, users can attach the optional tilt-shift Live View Finder (DMW-LVF2), with approximately 1.4x and 1,440,000-dot equivalent, 100% field of view.
Price and Availability
The Panasonic LUMIX DMC-GX1 will be available in black and silver bodies in mid-December 2011 and in the following kit options:
  • DMC-GX1-X with the LUMIX G X VARIO PZ 14-42mm / F3.5-5.6 ASPH. / POWER O.I.S (H-PS14042) lens → $949.99
  • DMC-GX1-K with the 14-42 standard zoom → $799.99
  • DMC-GX1 (body only) → $699.99
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
HDTV 4K & 8K TV
North American videophiles are out of luck again when it comes to Panasonic's OLED, Mini-LED, and LED TVs for 2023. Japanese, European, and Middle...
Headphones
Qatar Airlines will be the first to offer in-flight spatial audio, but will passengers flock to it?
HDTV 4K & 8K TV
2023 European energy regulations have put the future of 8K TVs (and some 4K TVs) in jeopardy due to their high power consumption.
HDTV 4K & 8K TV
Despite its reputation for making excellent TVs, Panasonic has retreated from several TV markets over the past several years, including the U.S. Now it...
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use...
Panasonic today announced four new sleek, compact stereo systems, two of which play Internet radio and boast a remarkable Bluetooth function and Bluetooth Re-Master...
HDTV 4K & 8K TV
For 2011 Panasonic introduced three VIERA Full HD 3D Plasma model lines, the VT30 series, GT30 and ST30 series. Panasonic's Full HD 3D televisions...
