Digital Cameras
Panasonic DMC-GF3 Lumix Micro Four Thirds Digital Camera
Panasonic today announced the 12.1-megapixel, mirror-free LUMIX DMC-GF3, their smallest and lightest digital interchangeable lens camera with a built-in flash. Its body size is comparable to that of a smartphone and weighing just 7.83oz (body only), less than a standard 8oz cup of coffee. The Panasonic's LUMIX GF3 realizes all the features desired from a traditional DSLR interchangeable lens camera, only it accomplishes them in an ultra-compact body that is lightweight and simple to master.
This remarkable reduction in size and weight is thanks to advancements in new mirror-free camera technology, and large DSLR format sensors that are more compatible with a new class of compact Micro Four Thirds (MFT) System lenses. This new class of Compact System Cameras offers a weight and compactness not seen in traditional DSLRs, yielding greater portability and creative control. The DMC-GF3's image quality comes from a large DSLR-sized 12.1-megapixel sensor and newly advanced image processing technologies.
Panasonic DMC-GF3 Lumix Micro Four Thirds Digital Camera - Silver
The LUMIX GF3 digital camera is based on the Micro Four Thirds standard of lenses, which includes Panasonic's 3D lens, thus the LUMIX GF3 not only provides outstanding still photos, full-High Definition 1080/60i video, but is also capable of shooting 3D still photos.
The Panasonic LUMIX GF3 produces high-quality photos with true-to-life details, thanks to excellent resolution, image rendering and color reproduction; high-grade lens options; and extremely precise Auto Focus (AF). Plus, the LUMIX GF3 creates the right balance between resolution and noise reduction, thus producing life-like images with accurate auto exposure and white balance, creating rich colors. Taking a page from the renowned LUMIX GH2's image quality, the LUMIX GF3 boasts full sized DSLR like Image quality thanks the same Venus Engine FHD image processor. The Venus Engine FHD image processor makes impressive low noise images from its 12.1-megapixel Live MOS sensor. Notably, images shot in low-lit situations at high ISO sensitivity setting, are stunningly clear with extremely sharp resolution. The image processor also excels in energy consumption by extending the battery life, despite its smaller size.
Panasonic DMC-GF3 Lumix Micro Four Thirds Digital Camera - Top
Thanks to a new mount, the LUMIX GF3 is approximately 16.7% smaller and 16.2% lighter than its predecessor, the LUMIX GF2. Despite its small size and unlike many CSC cameras in this class, the LUMIX GF3 still maintains a built-in flash and features a new pop-up mechanism that helps prevent the vignetting effect due to short distances between the flash unit and the interchangeable lens. With a newly-designed aluminum body that incorporates an ergonomic grip, and a well-designed control dial combined with a 3-inch touch enabled screen, the LUMIX GF3 is extremely intuitive and easy to use.
“The Panasonic GF3 compact system camera is extremely small and its newly-designed rounded body is quite attractive, which we expect to be popular among those users wanting to step-up from a point-and-shoot, yet who view traditional DSLRs as bulky and overly complex,” said Darin Pepple, Senior Product Manager, Imaging, Panasonic Consumer Electronics Company. “While the size and weight of the GF3 has been greatly reduced, Panasonic does not compromise what is at the core of every LUMIX, which is exceptional photo and video quality with an easy-to-use interface.”
Panasonic DMC-GF3 Lumix Micro Four Thirds Digital Camera - Back Angle
All models in Panasonic's LUMIX G Series of digital cameras feature Contrast AF for their focus system, as opposed to phase-difference AF systems, used in traditional DSLRs, which is susceptible to a mechanical margin of focus errors at wide apertures. With a Contrast AF system, focusing is controlled by the image sensor so that mechanical margin of error is reduced to achieve precise focusing, thus boosting higher number of in focus shots, especially when shooting in low light with wide open lens aperture. As a result, when the LUMIX GF3 is used with Panasonic's new wide aperture interchangeable lens, the LEICA DG SUMMILUX 25mm / F1.4 ASPH, also announced today, the performance of the Contrast AF system is optimally maximized.
The Panasonic LUMIX GF3 features a high-speed and extremely precise Contrast AF system that locks in approximately 0.18 seconds. Taking further advantage of Contrast AF, the LUMIX GF3 incorporates full-area focusing which makes it possible to set focus on any point in the field- of-view. The LUMIX GF3 also features Light Speed AF, an extremely fast AF which measures at approximately 0.1 seconds, which is achieved by reducing the detection time for focusing by doubling the sensors drive speed from 60 fps to 120 fps. With the combination of touch-control shooting, focusing on close up macro or still life objects is evermore quick and accurate thanks to the newly adopted Pinpoint AF that unlike a DSLR, offers near pixel level touch control focusing.
Manual control over focus is available in the DMC-GF3 and now features a quick 4x magnification feature. By simply touching the subject, that subject is then enlarged in a small window, allowing you to keep the rest of the image in view as a framing reference. Beyond 4x, that small window fills the monitor so even more control over focus fine-tuning can be achieved. This handy feature is available from both the MF (Manual Focus) Assist and AF + MF focus modes.
At the heart of the LUMIX GF3's simplified functionality is a large 3.0-inch touch enabled LCD (460k- dot) that allows for intuitive touch control of menus and most shooting, focusing, playback and effects controls. Menus can be customized using simple drag-and-drop actions similar to those on some touch-enabled smartphones. This allows for a custom user interface, giving Quick Menu access to functions that can be tailored to any user's expertise level. Users can also release the shutter using the touch-screen. Once locked onto a subject, the LUMIX GF3 tracks the subject with the AF Tracking feature and another touch allows the user to select the size of the AF area. In addition, Pinpoint AF function allows even more precise focus setting by further enlarging the focusing area. With increased customization, users can set the touch shutter and touch AF ON/OFF based on their preference. Touch-control also makes playback of photos and videos easy to flip through like pages in a book.
For those who miss the tactile feel of a traditional DSLR mode dial, the DMC-GF3 offers an innovative mode thumb wheel that quickly cycles though all available modes with visual feedback provided on the large 3″ touch-enabled LCD.
The LUMIX GF3 records 1920 x 1080 full-HD video in the AVCHD format, which features almost twice the recording time in HD quality than the conventional Motion JPEG. A dedicated video record button on the top lets users instantly start recording video, without having to hassle with any menu settings. The LUMIX GF3 allows for Touch AF in video recording, enabling professional-like features, such as rack focusing. For instance, by touching the subject on the screen, the focus is shifted to the subject.
Contributing to its ease-of-use, the LUMIX GF3 features Panasonic's acclaimed iA (Intelligent Auto) mode – and the new advanced iA Plus mode – are automatically engaged once the iA button is pressed, helping to make shooting video and photos with the LUMIX GF3 extremely simple – even to users new to compact system cameras. Panasonic's iA features include MEGA O.I.S. (included in several lenses), Intelligent ISO Control, and Intelligent Scene Selector, Face Detection, AF Tracking, Intelligent D-range Control and Intelligent Resolution. With the new iA Plus mode, the LUMIX GF3 easily enables commonly desired manual enhancements not available from standard camera auto modes such as peripheries defocusing around faces, exposure compensation, and color balance adjustments which are visually adjusted by moving an on screen slider with the user's finger or the thumb wheel.
The LUMIX GF3, like all CSCs in the Panasonic LUMIX G Series, is equipped with a highly-efficient Dust Reduction System. In some system cameras, if dust or other foreign matter gets inside the digital camera while the lenses are being changed, it's possible that the debris could cling to the image sensor and show up as a spot in your photos. However, the Panasonic Dust Reduction System helps to eliminate this problem by placing a supersonic wave filter in front of the Live MOS sensor that vibrates vertically approximately 50,000 times per second – thus repelling dust and other particles from the LUMIX GF3's sensor.
Two modes – Photo Style and Creative Control – let users at any skill level get creative with their photos. With Creative Control, the user can choose the most-frequently-used color modes (Expressive, Retro, High Key, Sepia, High Dynamic and newly added Miniature Effect mode) with easy access. In Miniature Effect mode, the peripherals are defocused while saturation and contrast is emphasized so the photos look like a diorama. The Photo Style mode revitalizes the conventional film mode with settings in Standard, Vivid, Natural, Monochrome, Scenery, Portrait presets while enabling finer adjustment of contrast, sharpness, saturation and noise reduction.
The LUMIX GF3, like all the CSC in the LUMIX G Series of digital cameras, is compatible with other Micro Four Thirds lenses and the full sized Four Thirds System standard via an optional mount adaptor. Other accessories available to the LUMIX G Series include external flashes, PL and ND filters, leather cases, straps, and more.
Price and Availability
The Panasonic LUMIX GF3 will be available in black, white, red and brown bodies for a suggested retail prices of $699.99 with the 14mm lens kit system starting in July 2011, and $599.99 with the 14-42mm lens kit system starting in late August 2011.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
HDTV 4K & 8K TV
North American videophiles are out of luck again when it comes to Panasonic's OLED, Mini-LED, and LED TVs for 2023. Japanese, European, and Middle...
Headphones
Qatar Airlines will be the first to offer in-flight spatial audio, but will passengers flock to it?
HDTV 4K & 8K TV
2023 European energy regulations have put the future of 8K TVs (and some 4K TVs) in jeopardy due to their high power consumption.
HDTV 4K & 8K TV
Despite its reputation for making excellent TVs, Panasonic has retreated from several TV markets over the past several years, including the U.S. Now it...
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use...
Panasonic today announced four new sleek, compact stereo systems, two of which play Internet radio and boast a remarkable Bluetooth function and Bluetooth Re-Master...
HDTV 4K & 8K TV
For 2011 Panasonic introduced three VIERA Full HD 3D Plasma model lines, the VT30 series, GT30 and ST30 series. Panasonic's Full HD 3D televisions...
