Mirrorless Cameras
Panasonic DMC-G5 Lumix Micro Four Thirds Digital Camera Announced
Panasonic today announced the LUMIX DMC-G5 Digital Single Lens Mirrorless (Micro Four Thirds) camera offering a new 16.05-megapixel Live MOS sensor and redesigned Venus Engine to render clear, crisp images in both photo and video recording. Featuring a compact, lightweight body with built-in flash, the LUMIX G5 boasts ultra-high mobility while offering users powerful camera performance and better image quality over its predecessor, the LUMIX DMC-G3. New features include a better LCD screen, faster burst shooting, greater ISO, and improved video recording.
The LUMIX G5's high-grade lens and precision AF (Auto Focus) achieves high resolution, optimal balance of resolution and noise reduction to produce lifelike image rendering and high precision auto exposure and white balance for faithful color reproduction. A redesigned Venus Engine features exceptionally advanced signal processing capabilities, producing clear, crisp images in both photo and video recording. The 3DNR detects smooth areas or edges in photos and adjusts the strength of noise reduction (stronger for smooth portion, milder for edge portion) to maintain object descriptiveness. The Multi-process NR quickly detects brightness in each part of a picture and applies optimal noise reduction in multiple steps. The newly incorporated HDR (High Dynamic Range) allows for several pictures consecutively shot at different exposure levels to be overlaid, producing a single composite picture to eliminate over-exposure or under-exposure.
Panasonic DMC-G5 Lumix Micro Four Thirds Digital Camera - Top
Like all cameras in the LUMIX G series, the LUMIX G5 adopts Contrast AF (Auto Focus), so focusing is controlled by the image sensor. Compared with the Phase difference system AF, Contrast AF boasts higher accuracy, especially when shooting with a bright lens with small F values. To further advance the Contrast AF, the G5 incorporates full-area Touch AF, making it possible to set the focus on any point in the field of view. Additionally, ultra high-speed Light Speed AF, quickly locks onto a subject, making it possible to capture even fast moving subjects clearly. Combined with Touch AF control and high-speed burst shooting at six frames per second in 16.05-megapixel full resolution captures fast-moving objects clearly.
The LUMIX G5 adds a new function lever conveniently located near the shutter release allows for direct adjustment of zoom, exposure or aperture control and can be used to magnify images in playback mode and page flip in menu mode. Additionally, the combination use of the function lever and turn-and-push rear dial allows users to adjust major shooting settings, accelerating the camera's simple, intuitive operation.
Panasonic DMC-G5 Lumix Micro Four Thirds Digital Camera - Back
The LUMIX G5's large, bright 1,440,000-dot equivalent LVF (Live View Finder) retains outstanding viewability and features approximately 100% field of view. Suppressing color breakup, the LVF assures stunning image view for any subject or scene. The LVF is newly designed to integrate an eye sensor for the LUMIX G5, which allows image output between the LVF and LCD screen to be switched automatically with the eye sensor on the LVF (which features optional sensitivity of high, low and off). Additionally Eye Sensor AF (Auto Focus) automatically starts focusing when the photographer looks into the EVF to capture spur-of-the-moment shooting opportunities.
A large, 920,000-dot high resolution LCD screen with wide-viewing angle rotates 180 degrees to the side, tilts 270 degrees up and down and offers approximately 100% field of view. Touch screen operation on the LCD screen allows for simple shooting or playback of images and the new Touch Pad function enables the use of both LVF and LCD simultaneously, which encourages more intuitive shooting. Lag time of image output has been minimized by approximately 18% compared to the LUMIX G5's predecessor, the LUMIX G3, making it easier to monitor fast-moving subjects. The Level Gauge give the camera the ability to automatically detect the horizontal or vertical angle of view so that photos shot in a portrait aspect will automatically be displayed vertically, no matter which lens is used. The newly added Electronic Shutter mode allows silent operation which is helpful in areas where silence is needed.
Panasonic DMC-G5 Lumix Micro Four Thirds Digital Camera - Back LCD
Creative Control Mode has been upgraded in the LUMIX G5 with an increase of filter options from five options to 14, adding Soft Focus, Dynamic Monochrome, Impressive Art, One Point Color, Cross Process, Low Key, Toy Effect and Star Filter, in addition to the conventional Expressive, Retro, High Key, Sepia, Hi Dynamic, Miniature Effect modes. With the new GUI menu tab, switching filter effects is seamless. A preview of filter effects can be seen on the large LCD screen via Live View mode and the camera intuitively recommends filters depending on the scene that the camera detects in iA (Intelligent Auto) or iA Plus mode. Furthermore, iA Plus mode allows users to adjust defocusing area in the background, exposure compensation and white balance for more flexible control while activating automatic shoot assist functions such as AF Tracking, Intelligent ISO Control, Intelligent D-range Control, Face Recognition and Intelligent Scene Selector.
For beginner users of interchangeable lens system cameras, the LUMIX G5 features the new Scene Guide which offers 23 sample pictures shot by professional photographers. Users can choose the photo closest to the situation that they are shooting and optimal parameters for shooting the scene will be set automatically. Additionally, procedures, technical advice and recommended interchangeable lens options for the scene can be shown to allow users to better understand and learn photography.
Not only does the LUMIX G5 produce stunning still imagery, but it also records high quality video. With the ability to record high-resolution full-HD 1920×1080@60p videos in AVCHD Progressive (MPEG-4) or MP4 format, subjects with fast motion and fine details are reproduced clearly. In addition to practical full-time AF, the Touch AF in video recording also lets the user enjoy professional-like selective focusing which allows the focus to be shifted while shooting video and AF Tracking easily locks onto a subject to focus, even when it moves. The Extra Tele Conversion function extends zoom range Max 4.8x without deterioration of image quality. The LUMIX G5 features a dedicated video record button on the top of the camera body so users can instantly start recording videos while shooting photographs without changing any settings. The camera can also take photos while recording video live just by hitting the shutter button. Along with full-HD video capabilities, the LUMIX G5 also features high-quality sound, recorded with Dolby Digital Stereo Creator and noise from background wind is minimized with the Wind Cut function.
Price and Availability
The LUMIX DMC-G5 will be available in black, white and silver in various kit options. Pricing and availability will be announced approximately 30 days prior to shipping. See more digital cameras.
LG StanbyME 2 Portable TVs
HDTV 4K & 8K TV
LG's new StanbyME 2 is a portable smart touchscreen TV with a detachable design, QHD screen, built-in battery, and flexible placement.
Pro-Ject E1.2 Turntable Top Black Pro-Ject E1.2 Turntable Top Black
Pro-Ject E1.2 delivers audiophile-grade performance at a budget price. A real entry-level winner with serious upgrades and no gimmicks—just sound.
Cambridge Audio Melomania P100 SE White Headphones in hand Cambridge Audio Melomania P100 SE White Headphones in hand
Cambridge Audio's Melomania P100 SE brings audiophile-grade ANC, 100-hour battery life, and aptX Lossless Bluetooth in a sleek £249/$299 package.
Audio Advice Revelation Luxury Home Theater Chairs with Underneath Lighting On Audio Advice Revelation Luxury Home Theater Chairs with Underneath Lighting On
A/V Furniture & Accessories
Tired of sharing a stained IKEA couch with your dog? The Revelation Luxury chair from Audio Advice brings heat, massage, USB-C, and legit comfort...
Epson ProCinema LS9000 projector. Epson ProCinema LS9000 projector.
With true 4K resolution, a bright colorful image and a motorized lens for maximum flexibility, Epson's new Pro Cinema LS9000 offers a lot of...
Onkyo C-30 CD Player Black Front Onkyo C-30 CD Player Black Front
CD Players
Onkyo's new Icon C-30 CD player brings audiophile tech at a surprising price. Discover why physical CDs still matters at Audio Advice Live 2025...
Amazon Prime Day is July 8-11, 2025
Daily Deals
Amazon Prime Day is a four-day shopping event from July 8-11, 2025 offering the biggest discounts of the year on consumer electronics.
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
HDTV 4K & 8K TV
North American videophiles are out of luck again when it comes to Panasonic's OLED, Mini-LED, and LED TVs for 2023. Japanese, European, and Middle...
Headphones
Qatar Airlines will be the first to offer in-flight spatial audio, but will passengers flock to it?
HDTV 4K & 8K TV
2023 European energy regulations have put the future of 8K TVs (and some 4K TVs) in jeopardy due to their high power consumption.
HDTV 4K & 8K TV
Despite its reputation for making excellent TVs, Panasonic has retreated from several TV markets over the past several years, including the U.S. Now it...
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use...
Panasonic today announced four new sleek, compact stereo systems, two of which play Internet radio and boast a remarkable Bluetooth function and Bluetooth Re-Master...
HDTV 4K & 8K TV
For 2011 Panasonic introduced three VIERA Full HD 3D Plasma model lines, the VT30 series, GT30 and ST30 series. Panasonic's Full HD 3D televisions...
