Panasonic DMC-FZ70 Lumix Digital Camera
Panasonic LUMIX DMC-FZ70 Digital Camera with 60x zoom
Panasonic just announced the LUMIX DMC-FZ70 (FZ70), a 60x superzoom, 16.1-megapixel digital camera, with optical image stabilization assures that both long zoom photos and videos are sharp and free from blur. The FZ70 offers Full HD 1080/60i video recording and a unique microphone that claims to better eliminate ambient noise and wind sound, while being able to precisely zoom the audio with the video as you zoom.
With a 60X optical zoom (20 to 1,200mm), the lens in the FZ70 is the widest and longest zoom in its class. Its stunningly versatile ultra-wide 20mm to 1,200mm range makes it possible to capture dynamic landscapes, wildlife and almost any scene when traveling. At 20mm the lens captures a nearly 140% wider angle of view compared with a 24mm lens. Comprised of 14 elements in 12 groups, including 6 aspherical lenses with 9 aspherical surfaces and 3 ED (Extra-Low Dispersion) lenses, this advanced lens unit delivers exceptional optical performance by suppressing distortion at the wide end and color bleeding at the tele end.
Panasonic LUMIX DMC-FZ70 Digital Camera top
Thanks to its Intelligent Resolution technology, the FZ70 can extend the zoom ratio up to 120X equivalent while maintaining the picture quality. An optional optical lens adapter can further extend the FZ70s range.
Recorded videos come with the highly realistic Dolby Digital Stereo Creator and its sound quality is further improved in the DMC-FZ70 thanks to a newly developed Wind Shield Zoom Microphone that minimizes wind noise by approx. 70% compared to prior models. Externally, the sealed structure prevents wind from hitting the microphone directly and the draft structure suppresses retention of air internally. As a result, the sound is clear and comfortable to listen to even it if was recorded on a windy day.
Panasonic LUMIX DMC-FZ70 Digital Camera with flash up
The FZ70 records full-HD 1920 x 1080 videos in both AVCHD and MP4 formats. A special, separate button on the top lets you instantly start recording videos while shooting photos without having to make any extra changes. The Creative Video Mode lets you adjust the shutter speed and aperture any way you like when shooting videos. The powerful 60x optical zoom with POWER O.I.S. is available in video recording as well.
A newly integrated 16.1-megapixel High Sensitivity MOS sensor and the advanced image processor Venus Engine feature high speed response and high quality image even in high sensitivity recording. This contributes to enabling high speed burst shooting at 9 fps in full resolution (max 3 images) and the Light Speed AF to catch the most fleeting shooting opportunities together with the quick start-up time of less than a second.
Panasonic LUMIX DMC-FZ70 Digital Camera back
The POWER O.I.S. (Optical Image Stabilizer) effectively suppresses hand-shake vibration. The angular width that the FZ70 can compensate for is more than 200% wider than previous models at the tele-end, which allows for superior handheld 1,200mm super telephoto shooting. The Active Mode equipped allows for active video recording at wide angle such as shooting while walking without causing deterioration of image quality.
While the FZ70 offers a bright F2.8-5.9 lens, it’s the new 16.1-megapixel High Sensitivity MOS sensor that cuts noise by 10-15% and dramatically improves images in high-sensitivity shooting. Together with the Venus Engine, it elevates the response, sensitivity and image quality of the LUMIX DMC-FZ70 to even higher levels.
In the iA (Intelligent Auto) Mode, the camera does all the work, leaving you free to compose shots and capture moments in both photo and video recording. In addition, the iA Plus Mode enables you to adjust defocusing area, exposure compensation and white balance by just moving the slider.
Price and Availabililty
The Panasonic DMC-FZ70 Lumix Digital Camera will be available September 17, 2013 for $399.99.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
HDTV 4K & 8K TV
North American videophiles are out of luck again when it comes to Panasonic's OLED, Mini-LED, and LED TVs for 2023. Japanese, European, and Middle...
Headphones
Qatar Airlines will be the first to offer in-flight spatial audio, but will passengers flock to it?
HDTV 4K & 8K TV
2023 European energy regulations have put the future of 8K TVs (and some 4K TVs) in jeopardy due to their high power consumption.
HDTV 4K & 8K TV
Despite its reputation for making excellent TVs, Panasonic has retreated from several TV markets over the past several years, including the U.S. Now it...
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use...
Panasonic today announced four new sleek, compact stereo systems, two of which play Internet radio and boast a remarkable Bluetooth function and Bluetooth Re-Master...
HDTV 4K & 8K TV
For 2011 Panasonic introduced three VIERA Full HD 3D Plasma model lines, the VT30 series, GT30 and ST30 series. Panasonic's Full HD 3D televisions...
