Compact Cameras
Panasonic DMC-FZ2500 Lumix Digital Camera has Large, 1-inch MOS Sensor
Panasonic LUMIX DMC-FZ2500
Panasonic just announced the LUMIX DMC-FZ2500 Hybrid Compact Digital Camera for prosumers and advanced amateur photographers shooting video or stills. The $1200 camera features a newly developed 20x optical zoom LEICA DC VARIO-ELMARIT lens and a large 1-inch 20.1-megapixel High Sensitivity MOS Sensor. The camera also boasts ultrafast auto focus at approx. 0.09 sec with burst shooting performance at 12 fps (AFS) / 7 fps (AFC), for up to max.100 (JPEG) / 30 (RAW) images. In addition, it shoots Cinema 4K: 4096×2160 / 24 fps and QFHD 4K: 3840×2160 / up to 30 fps) in MOV/MP4, and can save images as a 4K PHOTO.
Panasonic LUMIX DMC-FZ2500 back view
The FZ2500 features an OLED LVF (Live View Finder) with 2360K-dot equivalent high resolution with approx.2.18x / 0.74x (35mm camera equivalent in 4:3) magnification capability. The large, free-angle 3.0-inch approx.1040K-dot touch-control monitor with approx. 100% field of view makes shooting easier at either a high or low angle. Wi-Fi connectivity is built-in for flexibility in shooting, storing, and sharing images.
New Photo/Video Hybrid Lens
The LUMIX FZ2500 features a LEICA DC VARIO-ELMARIT lens system with 20x optical zoom (35mm camera equivalent: 24-480mm) and high-speed F2.8-4.5. Comprised of 16 lenses in 11 groups including 1 UHR (Ultra High Refractive Index) lens, 4 ED (Extra-low Dispersion) lenses and 5 aspherical lenses, the lens system boasts high optical performance with minimum ghosts and flaring. This lens system adopts an inner zoom structure with guide-pole mechanism. The guide-pole mechanism minimizes image shifts in zooming and is commonly used in professional camcorders. Together with the inner zoom structure, which realizes exceptional barycentric stability, image shift is dramatically suppressed by 80% compared with the FZ1000 to offer smooth, stable zooming. A coreless DC motor also enables slow, constant zooming from wide to 20x telephoto. Focus tracking performance in zooming is also improved.
A 9-blade aperture diaphragm achieves a soft, rounded defocus, smoothly catching up with sudden changes in brightness thanks to the use of a new galvanometer-type actuator, which is also used in professional camcorders. It assures smooth, seamless iris control even while zooming.
By combining the built-in ND filters, 4 setting modes for ND filters are available with direct switch operation: -2EV(1/4), -4EV(1/16), -6EV(1/64) and AUTO (Works for still image recording). Users can record videos while keeping the exposure level the same with a fixed shutter speed or with a fully open aperture even in high brightness.
High Quality Video Recording
The LUMIX FZ2500 boasts an exceptional video recording performance that has never been seen before in any compact digital camera. It is capable of unlimited 4K video recording (Cinema 4K: 4096×2160 / 24 fps and QFHD 4K: 3840×2160 / up to 30 fps) in MOV/MP4. The LUMIX FZ2500 is also capable of Full-HD video with an ultrahigh bit rate of 200 Mbps (ALL-Intra) or 100 Mbps (IPB), with no limit on recording duration. Users can freely choose the format from MOV, MP4, AVCHD Progressive and AVCHD at a variety of frame rates according to the application. For the global business of professional users, the system frequency can be flexibly selected from between 59.94Hz (23.98Hz) / 50.00Hz / 24.00Hz.
The LUMIX FZ2500 is also capable of live image output to the external monitor in 4:2:2 / 8-bit via an optional micro HDMI cable simultaneously while recording video. Even 4:2:2 / 10-bit is available which is suitable for professional video making that requires serious monitoring of footage. Users can choose to output only the recording content or the content with setting menus individually depending on the display.
Panasonic LUMIX DMC-FZ2500 top view
To elevate the video expression performance even more, a variety of effects are available on the LUMIX FZ2500. The VFR (Variable Frame Rate) lets users record overcranked / undercranked video, all in Full-HD. Max.5x slower effect is available in 24p at 120 fps. With the newly added Slow & Quick, users can apply a slow or quick motion effect with a press of the Fn button during recording. It is easy to activate 50% slow motion (120 fps) or 200% quick motion (30 fps) recording mode while recording at 60 fps. It is also possible to change the background’s angle of view and make it wider without changing the size of the main subject with a Dolly Zoom. Time Lapse/ Stop Motion Animation video can also be produced inside the camera.
In response to the demands of the cine production market, Panasonic offers a paid software upgrade service for the LUMIX FZ2500 to comply with V-LogL video recording with the purchase of Upgrade Software Key DMW-SFU1. Log recording offers exceptional flexibility as well as a wider dynamic range for color grading in the post-production process and V-LogL features log characteristics with 12 steps. V-Log / V-LogL have been developed to feature a similar characteristic curve to Cineon, which is a characteristic curve of film digitalization. Both V-Log and V-LogL have the same characteristic curve, and the LUT (Look Up Table) can be utilized in common.
Capture Unmissable Moments in Stunning Photo Quality
The LUMIX FZ2500 incorporates a large, 1-inch High Sensitivity MOS Sensor with 20.1-megapixel high resolution. This large MOS Sensor boasts a high S/N ratio, resulting in a dramatic reduction of noise even when shooting at ISO 12,800. The rich amount of light helps to produce an impressive defocus with a shallow depth of field. Together with the high-performance image processor Venus Engine, high image quality is achieved by optimizing sensitivity, resolution, color reproduction and gradation. The advanced noise reduction system detects edge parts, smooth parts and gradation parts and applies appropriate noise reduction individually. The result is sharp, clear images with precise color reproduction.
The LUMIX FZ2500 incorporates a dedicated linear motor into the focus system to achieve ultrahigh-speed AF with DFD (Depth From Defocus) technology which shortens the focus time. It calculates the distance to the subject by evaluating two images with different sharpness levels at a high 240-fps signal exchange speed. As a result, the LUMIX FZ2500 achieves ultrahigh-speed AF of approx.0.09 sec and high speed burst shooting at 12 fps (AFS) / 7 fps (AFC) to capture fast-moving subjects in crisp focus up to 100 (JPEG) / 30 (RAW) images.
Panasonic LUMIX DMC-FZ2500 side view zoom
Thanks to this 4K technology, users can experience 4K PHOTO to capture fleeting photo opportunities at 30 fps by extracting the frame with the most photogenic image out of the 4K burst file to save as a photo. Plus, multiple images can be saved as 4K PHOTO shots all at once in the LUMIX FZ2500. A maximum of 150 frames in five seconds following a designated frame can be saved. Users can check these images on a large PC monitor and select the best shot after shooting.
The LUMIX FZ2500 comes with the Post Focus function that lets users select the in-focus area even after shooting. This is helpful especially in macro shooting where strict focusing is required or for changing expressions by changing the focused subject. This function was developed by combining high-speed, high-precision DFD (Depth From Defocus) auto focus technology and 4K technology.
The newly integrated Focus Stacking function enables users to adjust the depth of field after shooting by combining multiple images shot with Post Focus function inside the camera. Users do not need to focus severely while shooting because they can get the image with the defocus that they want, or a pan-focused image, by simply selecting the focus area after shooting. This is beneficial when shooting macro shots of insects, small accessories and so on.
The 4K PHOTO and Post Focus menus are available on the drive dial for users to activate them more quickly.
Solid Design with Intuitive Control
The LUMIX FZ2500 offers both a sleek, solid exterior design and intuitive control. The dual dial control system around the barrel of the large-diameter LEICA DC lens enables focusing and zooming, and the 4 ND filter setting modes can be changed quickly with a switch that is also located on the lens barrel. The well-defined grip provides a stable hold with minimum fatigue despite its substantial weight. The front/rear dual dial system enables direct setting of the shutter speed and aperture. And the optimal dial, button, lever and switch layout allow intuitive control with comfort in both photo and video shooting.
The LUMIX FZ2500 has a large LVF (Live View Finder) with a high magnification ratio of approx. 2.18x / 0.74x (35mm camera equivalent in 4:3). The high-precision, high-speed OLED (Organic Light-Emitting Diode) display features 2,360K-dot high resolution and 100% field of view. Adoption of the OLED for the LVF achieves high-speed response with minimum time lag of less than 0.01 sec as well as 10,000:1 high contrast for exceptional visibility. With an eyepoint of approximately 20 mm, it also offers high visibility with comfort for users wearing glasses. It is always sharp and clear from the center all the way to the corners.
Panasonic LUMIX DMC-FZ2500 back angle view with LCD flip out
Equipped with a static-type touch-control system, the 3-inch free-angle rear monitor with 1040K-dot high resolution features approx.100% field of view. It tilts up and down by 270 degrees, which enables shooting at either a high or low angle even easier. The touch-control system lets the user immediately focus on the subject and even release the shutter by simply touching the screen. Touch Pad AF makes it possible to change the focus point while keeping an eye on the subject through the viewfinder when the frame is fixed. It is also useful in after-shooting operations such as cropping 4K PHOTO shots or setting Post Focus.
Other Features
  • 3.5 mm Microphone Jack / 3.5 mm Headphone Jack
    The LUMIX FZ2500 comes with a variety of connection terminals for more flexible shooting options. The 3.5 mm microphone jack is for high-quality audio recording using an external microphone, and the 3.5 mm headphone jack lets the user monitor the audio recording while shooting video in real-time.
  • SD Card Compatibility and Side SD Card Slot
    For reliable recording of rich video, the LUMIX FZ2500 complies with UHS-I Speed Class 3 (U3). The UHS-I Speed Class 3 (U3) guarantees a constant minimum write speed of 30 MB/s to respond to market needs for 4K video. The SD Card slot is located at the side of the camera for users to change smoothly even when the camera is on a tripod.
  • Easy Wireless Connectivity via Wi-Fi with Smartphones
    The LUMIX FZ2500 features Wi-Fi connectivity (IEEE 802.11 b/g/n) to offer a more flexible shooting experience and instant image sharing with easy operation. Once the camera is connected to a smartphone or tablet installed with Panasonic’s dedicated application software Panasonic Image App for iOS / Android, users can shoot, browse, and share images remotely.
Optional Accessories
A variety of optional accessories are available for the new LUMIX FZ2500, including an External Flash (DMW-FL580L / DMW-FL360L / DMW-FL200L), Stereo Shotgun Microphone (DMW-MS2), LED Video Light (VW-LED1), and Remote Shutter (DMW-RSL1). The 67mm diameter of the PL Filter (DMW-LPL67) and MC Protector (DMW-LMCH67) are also offered for more creative freedom.
Price and Availability
The Panasonic DMC-FZ2500 LUMIX will be available in November 28, 2016 for $1,199.99. Pre-orders are now being accepted.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
HDTV 4K & 8K TV
North American videophiles are out of luck again when it comes to Panasonic's OLED, Mini-LED, and LED TVs for 2023. Japanese, European, and Middle...
Headphones
Qatar Airlines will be the first to offer in-flight spatial audio, but will passengers flock to it?
HDTV 4K & 8K TV
2023 European energy regulations have put the future of 8K TVs (and some 4K TVs) in jeopardy due to their high power consumption.
HDTV 4K & 8K TV
Despite its reputation for making excellent TVs, Panasonic has retreated from several TV markets over the past several years, including the U.S. Now it...
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use...
Panasonic today announced four new sleek, compact stereo systems, two of which play Internet radio and boast a remarkable Bluetooth function and Bluetooth Re-Master...
HDTV 4K & 8K TV
For 2011 Panasonic introduced three VIERA Full HD 3D Plasma model lines, the VT30 series, GT30 and ST30 series. Panasonic's Full HD 3D televisions...
