Camcorders
Panasonic HC-X920, V720, V520, V210, V110 Camcorders
Panasonic HC-X920
For 2013, Panasonic announced five new Full-HD camcorders (HC-X920, HC-V720, HC-V520, HC-V210 and HC-V110) priced from $199 to $1,199. The high-end HC-X920 model (pictured above) is equipped with the New 3MOS System PRO with BSI (Backside Illumination) Sensor to enhance the three MOS sensors for excellent shooting performance even in dim lighting situations. The use of the BSI Sensor reduces noise to 50% of previous models. The X920 captures and records momentous scenes in high-definition in any environment, including the bright outdoors to dimly lit indoors.
The X920, V720 and V520 all feature the new Level Shot function, which automatically adjusts tilting images, in addition to 5-Axis Correction HYBRID O.I.S., which thoroughly suppresses blurring. The camcorders also offer Built-in Wi-Fi functions that allow live view control from a smartphone and enable Real Time Broadcasting to family and friends who live far away. These models allow users to shoot, play and share images more easily and conveniently. All of the new models also offer new levels of performance and function. Panasonic’s wide lineup of camcorders meets the diverse lifestyles of consumers. The cutting-edge technologies incorporated in Panasonic camcorders add to the fun of capturing, viewing, archiving and sharing images.
[youtube id=”4zPBVEOy_FI” width=”610″ height=”373″]
HC-X920 ($1,199 – Available March 2013)
Ultrafine Image Quality
  • 1080 TV Lines Horizontal Resolution
  • 20.4-Megapixel Still Picture Recording
Assist Functions for Professional Shooting
  • Manual Ring satisfies the needs of high-end amateur photographers wanting full control of camcorder operation. The large manual ring allows intuitive operation of zoom, focus, iris, shutter speed and white balance.
  • Level Gauge to detect the horizontal/vertical angle of view with its internal level working with an acceleration sensor. This function corrects even slight tilting that is difficult to see with the naked eye.
  • Electronic Viewfinder (EVF) is an extendable 263,424-dot equivalent viewfinder is easy to use and convenient for focusing and other adjustments. The EVF makes it easy to see the shooting scene under bright sunlight when the LCD might be difficult to view.
Built-in Wi-Fi Functionality
  • Built-in Wi-Fi function enables Real Time Broadcasting of important events via Ustream, while recording images in Full-HD. This lets users deliver live images to people with Internet access around the world. There is also a function to send
  • e-mail to notify the start of streaming to preregistered e-mail addresses.
  • By using the dedicated Panasonic Image App, users can remotely check audio recording, zoom In/Out and shutter ON/OFF, while viewing the live image on a smartphone or tablet. Highlight Playback of recorded images is also possible with a smartphone or tablet. Favorite scenes can be shared on SNS with simple drag-and-drop operation.
  • Home Monitoring lets users check on pets or family at home from the outside. They can even talk to their pets or family while viewing them on the screen, and record images remotely from a smartphone.
  • DLNA / Wi-Fi Compatible via an access point at Home that can be used to transfer data wirelessly to the TV or a tablet in the living room, kitchen or other rooms in the home and play back images on the large-screen TV. (DLNA wireless playback availability depends on the Recording Mode)
Dynamic Wide 29.8mm to 25x Zoom Shooting with Tilt and Blur Correction
  • The wide shooting range expands the breadth of photographic expression, extending from 29.8mm wide angle to Intelligent 25x zooming. This makes it possible to capture everything from panoramic scenery to telephoto images for obtaining dynamic images of subjects at a distance.
Other Beneficial Features
  • 1,152,000-dot 3.5-inch Touch LCD
  • Full HD 3D Recording with Optional 3D Conversion Lens VW-CLT2
  • 5.1ch Surround, Zoom and Focus Microphone and New Wind Noise Canceler
  • Plug and Copy to External HDD
HC-V720 ($549 – Available February 2013)
New High Sensitivity Sensor Records Clear, Beautiful Images Even in Dim Lighting Situations. Versatile Camcorder with Wi-Fi Functions for Easy Image Sharing.
Panasonic HC-V720
High-Quality Images Even in Dim Lighting Situations
  • The combination of the newly developed New High Sensitivity Sensor and the Crystal Engine PRO, with its superb noise reduction performance, records bright, high-quality, and low-noise images in both bright and dim lighting situations. Beautiful images can be recorded under a variety of situations, including indoor shooting and night scenery shooting.
  • Horizontal resolution of 1080 TV lines makes it possible to shoot high-resolution Full-HD images that express even extremely small details.
  • 20.4-megapixel Still Picture Recording with high resolution
  • Dynamic Wide 28 mm to 50x Zoom Shooting with Tilt and Blur Correction
  • Built-in Wi-Fi Functions for Extra Convenience and Shooting, Viewing and Sharing of Images
  • Real Time Broadcasting with Full-HD Recording
  • NFC (Near Field Communication) and Remote Shooting with Smartphone
  • Highlight Playback and Easy Share
  • Home Monitoring and Remote Video Recording
  • 3.0-inch Touch Wide LCD
  • 5.1ch Surround, Zoom and Focus Microphone and New Wind Noise Canceller
  • 2D to 3D Conversion Function
HC-V520 ($399 – Available March 2013)
Super-Powerful Optical 50x/Intelligent 80x Zoom in a Compact Body.
Panasonic HC-V520
Built-in Wi-Fi Functions Allow Highlight Playback and Image Sharing the Easy Way.
  • Equipped with Intelligent 80x Zoom/Optical 50x Zoom, these models can capture even the images of craters on the moon in Full-HD image quality. The V520 Series lets users easily shoot distant subjects that are too far away to capture clearly with conventional zoom functions.
  • 5-Axis HYBRID O.I.S. + and Level Shot
  • DLNA / Wi-Fi Compatible (DLNA wireless playback availability depends on the Recording Mode.)
  • 2.25-Megapixel BSI Sensor with 10-Megapixel Still Images
  • New Wind Noise Canceller
HC-V210 ($299 – Available March 2013)
Light Weight and Compact Size for Extra Portability, and a 135-Minute Battery (135 minutes of recording time with a fully charged battery (HG mode) in NTSC areas) for Extended Shooting. Full-HD Camcorder with a Wealth of Convenient Functions Including Intelligent 72x Zoom and POWER O.I.S.
Panasonic HC-V210
Intelligent 72x Zoom with POWER O.I.S.
  • The HC-V210/V210M enables ultra-telephoto Intelligent 72x zoom shooting with a compact body. These models are also equipped with POWER O.I.S. that eliminates blurring without any degradation in image quality. As a result, the original image quality captured by the lens remains intact, all the way from wide-angle to powerful zoom.
  • 32.3mm wide-angle lens will fit an expansive landscape or a large group of people into the frame. This lens boasts F1.8 brightness to allow shooting in dim lighting situations.
  • Full-HD 1920 x 1080/60p Recording and 10-Megapixel Still Pictures with
  • 2.20-Megapixel BSI Sensor
  • Eye-Fi Compatible
HC–V110 ($199 – Available March 2013)
Full-HD Recording and Intelligent 72x Zoom Compact Camcorders Suitable for Easy Recording of High-Quality Images.
Panasonic HC-V110
  • Intelligent 72x Zoom
  • Full-HD Recording and 8.9-Megapixel Still Pictures with 2.07-Megapixel BSI Sensor
  • Image stabilizer to suppress blurring
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
HDTV 4K & 8K TV
Panasonic is releasing two 65-inch OLED TVs along with four Mini LED TVs (55 - 85-inches) with Amazon's Fire TV built-in.
HDTV 4K & 8K TV
North American videophiles are out of luck again when it comes to Panasonic's OLED, Mini-LED, and LED TVs for 2023. Japanese, European, and Middle...
Headphones
Qatar Airlines will be the first to offer in-flight spatial audio, but will passengers flock to it?
HDTV 4K & 8K TV
2023 European energy regulations have put the future of 8K TVs (and some 4K TVs) in jeopardy due to their high power consumption.
HDTV 4K & 8K TV
Despite its reputation for making excellent TVs, Panasonic has retreated from several TV markets over the past several years, including the U.S. Now it...
Panasonic announced a compact, durable and portable wireless speaker system that is ideal for outdoor use. The SC-NT10 is Splash Proof which enables use...
Panasonic today announced four new sleek, compact stereo systems, two of which play Internet radio and boast a remarkable Bluetooth function and Bluetooth Re-Master...
HDTV 4K & 8K TV
For 2011 Panasonic introduced three VIERA Full HD 3D Plasma model lines, the VT30 series, GT30 and ST30 series. Panasonic's Full HD 3D televisions...
