OWC SuperSlim External Drive Enclosure
Turns any 9.5mm SATA Slot Loading Internal Optical Drive into an External Enclosure for Plug And Play CD, DVD, and/or Blu-ray Disc Burning/Playing
Other World Computing (OWC) announced the OWC SuperSlim, a USB 2.0 bus powered optical drive enclosure for turning any 9.5mm SATA slot loading internal optical drive, even those with mounting tabs, into an external Plug and Play CD, DVD, and/or Blu-ray disc burning /playing solution for Macs and PCs.
The OWC SuperSlim, available now for $49.99, is ultra thin, weighs only 4.2 ounces, and is bus powered (no AC adapter is needed), for easy transport in any gear bag.
OWC SuperSlim External Drive Enclosure - Ports
Ideal Solution For Macs That Have An OWC Data Doubler Installed
The OWC SuperSlim is the ideal solution for MacBook and MacBook Pro owners that installed the OWC Data Doubler to replace their infrequently used optical drive. Now, while enjoying up to 750GB additional internal storage capacity in the optical drive bay, users can install the replaced Apple SuperDrive into the OWC SuperSlim to create an external Plug and Play CD and DVD burning/playing solution.
Data Doubler Offers Custom Drive Configuration
The custom engineered, blue anodized aluminum OWC Data Doubler gives 2008-2010 MacBook and 2009-2011 MacBook Pro users the flexibility to uniquely configure their computer's internal drive array. Any SATA 2.5″ hard drive or SSD of up to 9.5mm height can be mounted onto the bracket with the entire assembly then user installable in a MacBook or MacBook Pro optical drive bay. 9.5mm SATA 2.5″ hard drives, currently available in capacities of up to 750GB, are fully “Plug and Play” recognized via the Apple Disk Utility program with standard configuration options just like any typical drive including, but not limited to:
  • Creating an individual volume with its own desktop icon.
  • Combining a new drive with the existing internal drive for one larger volume (SPAN).
  • Combining a new matching drive with existing internal for high-performance RAID-0 Stripe volume.
  • Configuring a new drive as a Time Machine backup drive.
  • Formatting one drive for the Mac OS and the other dedicated for Windows.
“The OWC SuperSlim completes an upgrade path for MacBook and MacBook Pro owners that begins with the OWC Data Doubler,” said Larry O'Connor, Founder and CEO, Other World Computing. “In addition, any slot loading type 9.5mm height optical drive whether from a Mac, PC, or sourced new can be installed in the SuperSlim to create an ultra portable, Plug and Play USB 2.0 solution.”
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
