Outlaw Audio Model 975 Home Theater Surround Processor
outlaw-model-975
Outlaw Audio has announced a budget-priced home theater surround processor for $549. The new  Model 975 Surround Processor allows for the creation of a state-of-the-art-home theater, without the added complexity and extraneous features typically associated with modern home theater receivers and processors.
Outlaw’s Scott Jackson says, “We looked at today’s A/V processors, and identified the essential elements: high-performance A/V switching and reproduction, the latest digital surround processing technologies, HDMI with 3D compatibility, support for legacy components, 1080P video scaling, and of course, a simple-to-use interface. By delivering these capabilities in an elegant, slim-line chassis, and by pushing our own price-performance ratio to an unprecedented level, we could provide an incredible opportunity for home theater enthusiasts to step from the world of A/V receivers to that of high-performance separates.”
Delivering upon that goal, the Outlaw Model 975 supports all of the latest Dolby and DTS formats including Dolby TrueHD and DTS-Master Audio, along with Pro Logic IIz and DTS Neo:6 post-processing. Its precision surround decoding is enhanced by the inclusion of highly flexible bass management controls using Quad-crossover settings from 40Hz to 200Hz with 12dB/octave (2nd order) high-pass and 24dB/octave (4th order) low-pass slopes. Once decoded, the signals travel through an ultra low-noise signal path, driven by a robust power supply with a compact Torroidal transformer.
The Model 975 has four 3D ready HDMI inputs and an HDMI output with Audio Return Channel (ARC) for sending soundtracks back to the processor from the streaming content on your smart TV. Now, there is no longer any reason to use a separate audio cable for this purpose. In addition to the Model 975’s HDMI connections are: two inputs and one output each for component video, as well as “legacy “composite and S-video inputs and outputs. With the inclusion of these legacy video connections, the Model 975 also employs a high-performance 480i to 1080p video scaler that meets all of the industry standard tests with flying colors.
On the audio side, there are two optical and two coaxial digital inputs, five stereo inputs, a record output, a low-noise 1/4-inch headphone jack, and a configurable 7.1-multichannel output for use with surround back or front height enhanced speaker systems.
Key Features:
  • 4 HDMI inputs with 3D compatibility, Deep Color and ARC
  • 2 each Component, S-Video and Composite Video inputs
  • 5 Stereo Analog Audio inputs and 2 each Optical and Coaxial Digital inputs
  • Dolby Digital, Dolby Digital Plus, Dolby True HD, DTS, DTS-HD and DTS-Master Audio decoding
  • Pro Logic IIz, Pro Logic IIx, and DTS Neo:6 post-processing
  • Full Bass Management with Quad-crossover settings from 40Hz to 200Hz with 12dB/octave (2nd order) high-pass and 24dB/octave (4th order) low-pass slopes
  • High performance FM Stereo/AM tuner
  • Video scaling to 1080p, 100Mhz Component Video inputs and video by-pass setting
  • Comprehensive, yet easy-to-use menus
  • Front panel headphone jack, analog record output and a 12VDC sequential trigger output on rear panel
  • Black aluminum front panel with Video Fluorescent Display (VFD)
  • An unusually comprehensive owner’s manual that intuitively guides you through setup and system configuration using both traditional text and innovative visual instructions
Price and Availability
The Model 975 Home Theater Surround Processor is expected to ship soon for $549 at OutlawAudio.com. A 30-day in-home audition period in included.
Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
