Outlaw Audio Announces Model 2150 Retro Receiver
The Last Great Stereo Receiver
The Outlaws are pleased to invite you to be among the first to experience what we feel will be one of the most talked about products we have ever introduced – the Model 2150 Retro Receiver, or as you will see us refer to it, “The Last Great Stereo Receiver”. More than two years in the making, the RR 2150 will be available for shipment in early November.
In a departure from our normal process, we will begin accepting orders for the RR 2150 immediately, without the traditional reservation list. This eliminates some of the steps in the process we normally use for new product introductions so that the units can go out to you as soon as they hit our warehouse. As always, your credit card will not be charged until just before shipment.
It is no secret that the gestation process for this product has been a long one, but that is due to the fact that, perhaps more than any of our other products, the RR 2150 has truly been a labor of love. With over ninety man-years in product design and over one hundred two-channel products among us, the Outlaw team working on this product would accept nothing less than perfection. Growing up listening to and selling “pure two-channel stereo,” we knew that there probably wouldn’t be another chance to create a product like this. Everything: the industrial design, the fit and finish, the circuit topology, the feature list and, of course, the sonic performance, had to be “just right”.
At the start of this special project, we thought about all the two-channel products we had designed for other companies and asked ourselves, “If we had to do it all over again what would we have done differently with two-channel receivers? What would we want if we could design it for ourselves, from the ground up?”. The RR 2150 answers those questions.
The first requirement was a timeless industrial design, and for inspiration we researched extensively the classic industrial designs of the past. The RR 2150 is reminiscent of the golden age of art deco radios, coupled with design elements traditionally found only in high-end, two-channel products. A thick, multi layered, brushed aluminum front panel combined with custom tooled knobs and a precision, motorized volume control helps to capture all of these elements.
Along with an elegant appearance, the RR 2150 has a simple and intuitive design, as one look at the front panel will tell you. Yes, we still recommend that you read the Owner’s Manual to find out how to take advantage of all the unique features, but most users will be able to get their RR 2150 up and running right out of the box.
Features and Performance
As you would expect from the Outlaws, the RR 2150 delivers solid, no-compromise two-channel performance. The robust amplifier section delivers 100 watts per channel into 8 ohms (20 Hz – 20 kHz, less than 0.03% THD, both channels driven), and 160 watts into a 4-ohm load. Because this is a product designed for music listening, even the most demanding musical peaks are not a problem, thanks to ample filter capacitor reserves.
A “music” product places different demands on the inputs than a multichannel “home theater” product. For example, for vinyl purists the RR 2150 includes a MM/MC phono stage with signal-to-noise and distortion performance rivaling expensive stand-alone phono preamplifiers. At the same time, the RR 2150 steps into the future, with a USB input that will allow you to connect your computer or other compatible product to a “real” music system. This will make your MP3s and streaming audio programs sound better than you ever imagined possible.
We recognize that, while the sonic requirements for high quality audio may not have changed, the types of speakers used to reproduce sound have. Therefore, the RR 2150 acknowledges that some modern two-channel audio systems use “sub/sat” speakers as an alternative to more traditional full-range models. As a result, the RR 2150 is the first two-channel receiver with built-in analog bass management that allows you to integrate virtually any subwoofer with your bookshelf speakers. True to our goal of building a product we would want in our own home system, the RR 2150 has finally given Outlaw Peter the perfect product in which to use some circuits he developed more than a decade ago, but which had to wait until now for product execution. Making practice of theory, extensive beta testing confirmed what he suspected all along: with a quality subwoofer like either of the Outlaw LFM models, seamless deep bass with “monitor” speakers is an audiophile reality.
There is much more to the RR 2150 that makes it the best sounding, most musical two-channel receiver ever, such as defeatable tone controls, an external processor loop, trigger controls for use with external amplifiers, a separate record output bus, A/B speaker outputs and the use of specially selected components. However, the proof is in the listening, and that is something you’ll want to experience yourself.
Indeed, a sample of the RR 2150 is already out for review with one of the most demanding critics in the two-channel world. Preliminary reports confirm that the RR 2150 delivers as advertised, even when used with source components and speakers normally reserved for products costing many times the RR 2150’s $599 price.
For those of you who still cherish the pleasure of two channel recordings, be they old or new, we encourage you to audition this remarkable product. Yes, we selfishly designed it for ourselves, but we believe that many of you share our passion for music. If that sounds like you, you’re in for quite a treat. Go to http://www.outlawaudio.com/products/rr2150.html to find out more about the RR 2150.
NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Samsung Neo QLED TV 2025 with Vision AI Samsung Neo QLED TV 2025 with Vision AI
HDTV 4K & 8K TV
Samsung just unveiled pricing and availability details for its full line of Neo QLED TVs in both 4K and 8K resolution. Potential buyers may...
Samsung HW-Q990D. Samsung HW-Q990D.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
Focal Bathys MG Wireless Headphone in-hand Focal Bathys MG Wireless Headphone in-hand
Focal has upped the ante with the flagship Bathys MG wireless headphones and that includes a $600 increase in price over the base model.
FiiO FX17 IEM FiiO FX17 IEM
Earbuds & In-Ear Headphones
Universal IEMs with 13 drivers? FiiO's FX17 integrates electrostatic and dynamic drivers, and balanced armatures in a titanium ear shell.
