DAPs
Otterbox for iPod Defender Series Cases
Now available for the iPod nano 4th generation & iPod touch 2nd generation
Take your tunes around town with cases that protect against dust, drops and shock; the OtterBox Defender Series™ line expands with two new cases for the iPod nano 4th generation and iPod touch 2nd generation.
“The Defender Series line is great for any lifestyle,” said Curt Richardson, CEO of OtterBox. “The case designs are extremely durable, yet small enough to slide in your pocket or throw in your gym bag.”
Compatible with 8 and 16 GB iPod nano 4th generation models and 8, 16 and 32 GB touch 2nd generation models, these fully interactive cases offer three sleek layers of protection* without adding bulk:
Layer one:
  • OtterBox for iPod nano 4th generation: A clear polycarbonate membrane covers the screen and Click Wheel to safeguard against scratching and dust intrusion.
  • OtterBox for iPod touch 2nd generation: A clear polycarbonate membrane protects screen and light sensor against scratching, as well as dust intrusion.
Layer two: Hi-impact polycarbonate shell (same on both cases)
Layer three: Silicone skin to absorb bump and shock (same on both cases)
The OtterBox for iPod nano 4th generation Defender Series offers a built in kickstand on the back of the case so users can bring the “big screen” virtually anywhere. The Click Wheel remains accessible through a thin, protective membrane and the screen stays safe from scratches so you can enjoy podcasts or your favorite TV show on-the-go. Silicone plugs provide accessibility to sync/charge, hold button and headphone jack.
The Defender Series case for the iPod touch 2nd generation offers a wide screen window for easy interaction as well as complete protection. Sync/charge and headphone jacks are accessible via silicone plugs and all device buttons remain usable through the case.
Take your iPod nano 4th generation or iPod touch 2nd generation out on the town without fear of damage or destruction; protect with a Defender Series case from OtterBox!
Additional Information:
OtterBox for iPod nano 4th generation Defender Series™:
  • Environmental Protection: Drop and Shock – Protection against drop, bump & shock
  • Water Protection – Not tested or recommended for water protection*
  • Dust Intrusion – Dust does not enter in a sufficient quantity to interfere with satisfactory operation of equipment
  • Colors: Black/Black, Pink/Pink
  • Optional Accessories: Armand kit
  • Dimensions (Case Only): 4.05″ (102.8 mm) X 1.83″ (46.5 mm) X 0.55″ (14 mm)
  • Approximate Weight (Case Only; including layer 1): 1.18 oz (33.6 grams)
OtterBox for iPod touch Defender Series™:
  • Dust Intrusion – Dust does not enter in a sufficient quantity to interfere with satisfactory operation of equipment.
  • Dimensions: 4.68″ X 2.74″ X 0.65″
  • Weight (case only): 1.8oz (50 grams)
About OtterBox:
Founded in 1996, OtterBox is highly respected in the design and production of rugged and semi-rugged cases to safeguard technology and other valuables.
Built upon fundamentals of hard work, creativity and perseverance, OtterBox is the innovator of premier protective solutions for leading global handheld manufacturers, wireless carriers and distributors.
For more information, visit www.otterbox.com or call 888-695-8820.
OtterBox, never out of its element!
*Notes: Cases do NOT protect against water. Will provide some added protection against drop, bump and dust.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
