OtterBox Impact Series Case for BlackBerry Curve 8520
Ready to take on all the bumps of life, the OtterBox Impact™ Series case for the BlackBerry Curve™ 8520 smartphone provides the perfect amount of protection while still keeping a sleek look and feel.
Durable silicone safeguards from impact and a self-adhering clear protective screen shields from scratches.* Case also includes a cleaning cloth and installation card.
“The Impact Series offers our customers a skin-like design, but the real protection can be found on the inside of the case. Inner coring lines the back and corners to help absorb bump and shock and safeguard the Curve 8520 smartphone from accidents,” said Curt Richardson, OtterBox CEO.
This latest addition to the Impact Series line allows complete interaction with all the functions and buttons of your BlackBerry Curve 8520 smartphone; it’s so sleek, you’ll barely know it’s there.
Additional Information:
  • Environmental Protection: Added protection against bump and shock.
  • Colors: Black
  • Dimensions (Case Only): 4.42 x 2.55 x 0.78 in (112.25mm X 64.77mm X 19.94mm)
  • Approximate Weight (Case Only; including layer 1): 0.8 oz (22.71 grams)
About OtterBox
Founded in 1996, OtterBox is highly respected in the design and production of rugged and semi-rugged cases to safeguard technology and other valuables.
Built upon fundamentals of hard work, creativity and perseverance, OtterBox is the innovator of premier protective solutions for leading global handheld manufacturers, wireless carriers and distributors.
Notes: *Case NOT protected against water. Will provide some added protection against bump and shock.
Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
