OtterBox Defender Series Case for Samsung OMNIA
At work, home or anywhere in between, your Samsung OMNIA allows you to send an email, take a business call or view a power point, but your busy lifestyle also increases possibilities for mishaps. Always stay connected by protecting with the OtterBox Defender Series™ case and rest assured your Samsung OMNIA remains safe from drops, dirt and scratches.
Three innovative layers combine to provide unbeatable protection:
  • Layer one: clear polycarbonate window protects against scratching as well as dust intrusion
  • Layer two: hi-impact polycarbonate shell
  • Layer three: silicone skin wraps over the device to absorb bump and shock*
“This new addition to our Defender Series line is an ideal accessory for OMNIA users,” said Curt Richardson, CEO of OtterBox. “These customers are always on-the-go and this mobile device is continually at risk for damage. Expensive repairs and replacements can easily be prevented by protecting with the OtterBox.”
The OtterBox provides access to sync/charge, lanyard anchor and headphone jack through silicone plugs. Silicone buttons enable use of camera, volume, menu and power functions. The hard reset button and light sensor also remain accessible.
Easily take pictures and use navigation keys right through the case. Acoustic vents on speakerphone and headset speaker enable clear sound transmission and for easy carrying, the OtterBox Defender Series for the Samsung OMNIA also includes a holster style, ratcheting belt clip.
Environmental Protection:
  • Drop and Shock- Protection against drop, bump & shock
  • Water Protection- Not tested or recommended for water protection
  • Dust Intrusion- Dust does not enter in a sufficient quantity to interfere with satisfactory operation of equipment
Colors:
  • Layer 2: black
  • Layer 3: black
  • Belt Clip: black
Dimensions (case only):
  • 4.76 inches X 2.61 inches X 0.83 inches
  • 11.02 cm X 6.55 cm X 2.31 cm
Approximate Weight (case only, including layer 1):
  • 2.75 ounces (78.02 grams)
About OtterBox:
Founded in 1996, OtterBox is highly respected in the design and production of rugged and semi-rugged cases to safeguard technology and other valuables.
Built upon fundamentals of hard work, creativity and perseverance, OtterBox is the innovator of premier protective solutions for leading global handheld manufacturers, wireless carriers and distributors.
* Case NOT fully protected against water. Will provide some added protection against drop, bump and dust. NOT intended for protection against water intrusion.
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
