iPhone Apps
OtterBox Commuter TL Series Cases for iPhone 3GS
Introducing two new case lines from OtterBox for the Apple iPhone 3G and iPhone 3GS: the Commuter™ and Commuter™ TL Series. Fusing rugged elements from the Defender™ Series line and sleek characteristics from the Impact™ Series, the Commuter and Commuter TL offer the best of both worlds.
Otterbox Commuter TL iPhone Case
“These new cases combine the most innovative features from previous lines to give customers style and protection,” Curt Richardson said, founder and CEO of OtterBox. “The Commuter Series is an inverse design of the Defender; the hard plastic is now on the outside of the case with protective silicone on the inside. This new design slims-down the size and changes the look and feel of the case.”
Both case lines were custom designed to highlight the true beauty of the iPhone in three slender, yet sturdy layers*:
  • First, a self-adhering screen cover protects from scratches (touch screen remains completely functional).
  • Second, a silicone skin wraps over the device to protect corners from bump and shock. Dust intrusion is reduced with the use of silicone plugs over audio port and dock connector.
  • Finally, a smooth one-piece, custom molded polycarbonate shell hugs tightly around the silicone allowing the case to slide easily into a pocket or purse.
Looking for a case to sport during the workweek? The OtterBox Commuter Series is the perfect sidekick for a lunch meeting, business trip or workout. A fortified polycarbonate shell wraps around the top, bottom and side grip areas of the case for a sleek feel, which also enables a smooth transition in and out of a purse, pocket or briefcase. The corners of the iPhone are protected with durable silicone to safeguard against bumps and shocks. Users can also choose between two optional accessory kits; each kit includes three interchangeable colored shell options, coming soon!
Want to individualize your iPhone? The OtterBox Commuter TL Series will be sure to draw attention from every trendsetter in town, available now in black and coming soon in six eye-catching colors. Inner coring along the vertical sides offers added protection and the textured exterior side grips provide an ergonomic feel and stylish detailing. Don’t worry Apple lovers; the logo is safe and protected by a transparent polycarbonate shield.
“Color has been a huge interest for our iPhone customers and we’re eager to fill that need,” Richardson said. “The new Commuter Series offers optional, interchangeable color shells and the Commuter TL comes in a variety of colorful choices that enable users to individualize their OtterBox.”
Both Commuter and Commuter TL Series cases come with a microfiber cleaning cloth and installation card for easy application of the self-adhering screen.
For more information about the OtterBox Commuter and Commuter TL Series, check out www.otterbox.com/iphone-commuter-case-comparison.
Additional Information for the Commuter Series for iPhone 3G & iPhone 3GS:
  • Environmental Protection: Added protection against bump and shock.
  • Colors: Black/Black (silicone/plastic)
  • Dimensions (case only): Height: 4.71″, Width: 2.61″, Depth: 0.62″
  • Approximate Weight (case only): 0.75oz (21.11g)
  • Optional Accessories: 2 colored pack options with 3 interchangeable plastic shells
    • Pack 1: navy, maroon, grey
    • Pack 2: white, yellow, green
Additional Information for the Commuter TL Series for iPhone 3G & iPhone 3GS:
  • Colors: Black/Clear (silicone/plastic)
  • White/Clear (silicone/plastic)
  • Green/Clear (silicone/plastic)
  • Blue/Clear (silicone/plastic)
  • Red/Clear (silicone/plastic)
  • Yellow/Clear (silicone/plastic)
  • Pink/Clear (silicone/plastic)
  • Dimensions (case only): Height: 4.73″, Width: 2.63″, Depth: 0.66″
  • Approximate Weight (case only): 0.74oz (20.87g)
  • Optional Accessories: 3 pack of adhesive screen protectors
*Case NOT protected against water. Will provide some added protection against bump and shock.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
